Video Card and Monitor Defaults mixed up.
vwayne
Been googling for days on this issue.
I have an 8800GT and a 7600 GT Geforce card. The 8800 is for my primary monitor, a Nec, and also runs a small Dell. The 7600 is for two Dells. But when I go to Preferences in CS3 and check "GPU Settings" it says it detects the 7600 card, not the 8800.
So then I looked at Vista color management and there it shows the monitor connected to the 7600 card as my default monitor.
How can I change the default monitor to make it the Nec, which is already the primary? And will that cause Photoshop to then detect the 8800 card instead of the 7600?
Thanks.
    Homebuilt
    i7 930
    Gigabyte GA-X58A-UD3R
    12 GB
    GTX 470, Geforce 8800 GT
    Spectraview 26 inch, Dell 24 inch, Dell 19 inch, Dell 15 inch
    SSD, several Seagates
    Silent wave 750
I'll re-phrase. How do I change the default monitor in Vista 64?
    Homebuilt
    i7 930
    12 GB
    Silent wave 750
Right-click on the desktop, go to 'personalize', then display settings.
Amplid
    Asus ROG Striker 2 Extreme
    2 x 2Gb Patriot DDR3
    XFX GeForce 9800 GTX+
    Creative Supreme FX 2
    Neovo F417 17''
    Samsung SP2504C SATA 7200rpm
    Pc Power & Cooling 750
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
    Homebuilt
    i7 930
    12 GB
    Silent wave 750
Click on the drop down box underneath the monitors and select the graphics card you want.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
That is how to select the primary and secondary monitors/video cards. It does not select default monitor as shown in Display Settings>advanced settings>color management>color management tab> and then under, Name/ICC Profiles
    Homebuilt
    i7 930
    12 GB
    Silent wave 750
Yes it does:
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Not mine. I wish it did. Any ideas?
    Homebuilt
    i7 930
    12 GB
    Silent wave 750
