Vacuum vs Blower
panais
Power User
Which is the best way to clean a pc from dust?
Vacuum or Blower?
Thanks!
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter KINGSTON HYPER X FAN +Cordless Rumblepad 2
Compressed air would be safer to do initial then you can use a vac to suck up the dust made by the compressed air.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Vacuum or Blower?
Thanks!
A nicely ventilated room (or preferably outdoors) and a blower will do nicely. With a vacuum, you risk knocking something out of place, whereas a blower can be kept a safe distance from the internal components. With one exception:
When you blow out the dust, use your finger or a piece of plastic to temporarily obstruct the fans, because they can act as a dynamo when forced to rotate from the blower air pressure, and can cause some serious damage to your components if you're not careful.
As an experiment, take a fan that has vanity LEDs attached, and disconnect it from the computer entirely. Use a blower to force the fan to spin at a high speed. Lo and behold, the LEDs will light up. You don't want to eisk that power generation to fry some critical component.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
I would assume as well that the static electricity from a vacuum too near delicate computer components could prove fatal.
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
I think you are spot on Joan.
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
And if you can't take it outside a combination of what Dzomlija said and the vacuum; just set the hose close enough (without setting it inside) to the case to suck up the dust as you blow it out.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
You are right Joan. I was told by a technician at work to never under any circumstances blow the vacuum cleaner on any computer parts, for that very reason.
    qx6700
    intel badaxe2
    6 Gig Corsair ddr2 800
    Nvidia 9600GT 512
    OB
    BenQ24 Princeton19
    1920X1200 1280X1024
    8 X 500 Gig 3X 1TB RAID 0 and 2X 500 GB
    Rosewill 950
    Thermaltake
    Chilltec
    Kensington Expert
    MS Natural Ergonomic 6000
    DSL
i use a compressor with around 35-45 PSI of pressure to blow out all the nooks and crannies and at the same time hold the hover hose just outside the case to suck away the flying dust
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
I use shop air with a 1/16 nipple reglated at 30psi. I have a inline dryer. The cans of compressed air work fine but be carefull about using a vac as the static discharge can bite. Many a board or cpu has been replaced and a strap will not help if it is caused buy the vac. Be sure your system is off and unplugged and grounded.
usmc_nam_vet, Thats the best advice yet.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Ever Try Useing A Paper Styrafoam Cup Poke a Hole In The Bottom Use heave Dudy Book Scatch Tape Between the Straw And Bottom Of The Paper Cup.
Presto Supper Computer Suction VAcume Cleanner ,,
Ever watch Dotto's CAFE Steve Dotto ahahahah.
Except that Styrafoam can also hold and discharge static electricity....
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
