Using WMC to record first time
eknirb
heck I've had the thing since 2007, too. But my VCR/DVD combo player bought the farm, so until we buy a new one- probably a new recordable DVD player, since the one I had doesn't seem to exist..
Anyway, I've set it up to record, followed the instructions, etc.
I would ASSUME the PC has to be ON for it to record, right? (I am saying this since a VCR isn't on when you set it to record, it comes on at the scheduled time.)
WMC doesn't have to be running @ the time of record, does it?
Do you set it to the specific channel you want, IE I want to record TVLand, which is "channel 72," or is it set to the default for cable TV setups, IE "channel 03."
And where in the PC does the recorded file live once done? IE, it will take up a lot of drive space I would think.
    HP m8200n Windows Media Center
    AMD Athlon 64x2 Dual Core Processor 6000+ 3.00GHz
    3.00 GB
    HP widescreen w1907
hi eknirb, your PC does need to be on to record, which i found out trying to record the X-files when i was away one week, the file lives in this directory> c:\users\public\recorded TV, windows media center doesn't need to be running all the time, a little red record icon will appear when it is recording and will happily do it in the background while taking up minimal resources, a very well done program i might say.
family guy episode recorded on my system takes up 660MB which is a lot, but you can set media center to allocate a certain amount of hard drive space.
As to channel recording, it will need to be set through the digital channels, you just go through the guide and set which program to record, i'll post a video of me doing a quick run down of how to record soon.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
good to know. And...do you set it to the specific channel you want, IE I want to record TVLand, which is "channel 72," or is it set to the default for cable TV setups, IE "channel 03."
    3.00 GB
    HP widescreen w1907
i've added to the post above
heres the video
[youtube]IfhehULoquo[/youtube]
    16Mb Sky bb
Thanks for the video--is there supposed to be sound?
EDIT
I admit defeat. HOW do you find the listing of TV shows?
    3.00 GB
    HP widescreen w1907
It plays in the background when you're still on the app if you press the media center logo, or is that not what you meant?
MrNeeds
    16Mb Sky bb
I mean, there's an image on that video of a whole bunch of TV shows and channels, IE a TV listing guide. How do you find that?
    3.00 GB
    HP widescreen w1907
On the main menu, just go to TV and Movies, and in that section will be "Guide" that's where the tv listings are, providing you've set it up correctly, there's a first time setup available where you can configure the TV signal and TV guide
    16Mb Sky bb
huh. well, mine is set up correctly, but I sure don't see GUIDE. I know there are ^ and < > to scroll thru- but I don't see it. However, I did try a manual setup, and it recorded fine. So I am definately ahead of the game, thanks!
    3.00 GB
    HP widescreen w1907
have you enabled the guide? it asks you if you want to use the guide when you set up initially, i answered yes, so maybe it just needs to be enabled, it will download the listings from there on.
just go to the Tasks menu>Settings>TV>Guide>Set Up Guide Listings, follow the on screen instructions and you should be good to go
MrNeeds
    16Mb Sky bb
That was a good choice to record South Park. Good vid
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Thanks Roger, I do try :)
Dave
    16Mb Sky bb
