JuniperGreen
I have been using a VBScript to extract a list of any hyperlinks and their associated "Display Text" where they occur in MS Word docs. I have been asked to set this up for someone else but discovered a hitch because they do not have MS Word but OpenOffice (.odt docs). I understand that it is quite possible to extract the hyperlinks but I have not been able to do so so far. Does anyone know how to modify my VBScript so that it will work with OpenOffice? I have appended the script I use with Word (it ain't great but it does the business!).
I have managed to get the script to open an "odt" file in OpenOffice but that is as far as it goes. I'm stumped and there does not appear to be much in the way of info as to how the hyperlinks can be extracted although I understand VBS is more or less compatible.
I would appreciate any help on this or a script if anyone has achieved this
Thank you
Thank you
Code:
For Word
'To be run at CMD Prompt: cscript ExtractHyperLinks.vbs >> HyperOut.txt
Set objWord = CreateObject("Word.Application")
objWord.Visible = True
Dim Gap
Dim Item
Dim Ref
Gap = " "
Item = "Item: "
Ref = "URL: "
Set objDoc = objWord.Documents.Open("F:\sun-130113\Atlantis - Wiki.doc")
Set colHyperlinks = objDoc.Hyperlinks
For Each objHyperlink in colHyperlinks
Set objStdOut = WScript.StdOut
objStdOut.Write Item
objStdOut.Write objHyperlink.TextToDisplay
objStdOut.write Gap
objStdOut.Write Ref
objStdOut.Write objHyperlink.Address
objStdOut.WriteBlankLines(2)
Next
Code:
For OpenOffice
Set objServiceManager= WScript.CreateObject("com.sun.star.ServiceManager")
Set objDesktop= objServiceManager.createInstance("com.sun.star.frame.Desktop")
Dim args()
Set objDocument= objDesktop.loadComponentFromURL("private:factory/swriter",_
"_blank", 0, args)
Set objText= objDocument.getText
Set objCursor= objText.createTextCursor
Sub Run(ByVal sFile)
Dim shell
Set shell = CreateObject("WScript.Shell")
shell.Run Chr(34) & sFile & Chr(34), 1, false
Set shell = Nothing
End Sub
Run "F:\Sun-130113\MyFile.odt"
Set objODT = objswriter.documents.Open("F:\sun-130113\MyFile.odt")
Set colHyperlinks = objOdt.Hyperlinks
objStdOut.write Gap
objStdOut.Write Ref
Next
