Using UDF media
Howard Kaikow
Vista Pro
On a Windows 2000 system, I created a CD-RW thatr uses the UDF 1.02 file system.
How does one use such media in Vista?
I thought that Vista had the built-n capability to read/write UDF formats.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Howard Kaikow:
You may need to change a setting.
In your Video folder, click on Burn. Then click the arrow to open up
Show formatting options. Live file system should be ticked. Click on
Change version. Next to UDF Version, change from default to the lowest numbered version and try your UDF/RW.
If you aren't going to be working with older systems in the future, you might want to convert your data over to the Vista default version.
Let us know if this helps.
Edit: According to the literature, Vista should work with all versions of
UDF so long as Live File system is selected.
http://en.wikipedia.org/wiki/Universal_Disk_Format
Ardneh
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
You might be missing the ISO file system. Look here:
Why Won't my DVD Play?
Thanx for pointing me to that article, but that was not my entire problem, I'll decribe my problem in another post.
Let me tell you who I am.
I was one of the designers of the High Sierra format, ISO 9660, and ISO/IEC 13346 (the basis for UDF), and the, in effect defunct, ISO/IEC 13490 (but this is where multisession was actually defined).
It upsets me to see articles that include significant misstatements about the relevant standards, but I can no longer take the time to offer corrections.
Please take care when reading articles that purport to explain these standards.
I do not even recall the last time I saw such an article that did not have errors.
Hey Howard, you are a dummy!
I realize that you have had the Vista system for a bit over a year, and that you have not been using it to create optical media.
If you check, you will find that the drive that came with the Vista notebook will write CD-R and DVDs, but NOT CD-RW. I guess that, at some point, you must have known that, but as one ages, brain cells wear out.
Of course, Vista, an dthge software supplied with the notebook, does not use a UDF format prior to UDF 1.50, and your Windows 2000 CD-RW drive can read, but not write, that format using Roxio's Drag 2 Disc 7.1.0.189. Not worth updating the software on the Windows 2000 desktop, is it?
