using task scheduler
fieseler
can i use task scheduler to empty only my temp folder once a week?
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
Yes you can, you need to create a batch file which can be done using notepad.
You will have to find the location of the folder but the command would be;
Del C:\folder path *.*
You can then tell tell task scheduler to run the script once a week.
Insure the batch file uses the extention .bat
A better solution would be to create a shortcut to the desktop and manually look at it once a week or use the disk cleanup tools which delete the temp files and your history amongst other things.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
