use TV as monitor
airhud86
I just bought a HDMI cable to use tv as my monitor. I plugged it in correctly at the pc and on the TV but nothing is coming up. Any help would be much appreciated.
Thanks
Phil
Take a look in your TV settings menu. Somewhere in there you will find an input selector. Look for HDMI and select it as the input. My Samsung has an HDMI shortcut on the remote.
The tv is already on HDMI. Thats how my comcast box connects. I disconnected the comcast HDMI cable and plugged in the one connected to the computer and nothing.
do you have a laptop or a desktop?
is it set up for multiple monitors?
    Aleinware Area-51
    core 2 extreme x9000 2.8 Ghz
    4 Gig
    (2) Nvidia 8800m GTX in Sli
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    (2) seagate 7200rpm in RAID 0 (1) maxtor external 1 terabyte firewire
    laptop
    logitech Anywhere Mouse and built-in touchpad
    a really spiffy backlit one that i can change color ;>)
    Cable
Are the display settings on your PC set to match your television
in terms of screen resolution and refresh rate?
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
Which Graphic Card Do you have ATi or nVidia
    HTPC/Desktop PC/Gateway LT2104u
    Intel Pentium 4 2.8Ghz with HT/3.0Ghz with HT/Atom N450
    GIGABYTE GA-81915ME-C/Intel D865GBF/Acer LT21
    2x1GB DDR 400Mhz/512x2GB DDR 400Mhz/1GB DDR2-800Mhz
    ECS 9800GT 512 DDR3/ Sapphire HD3650 AGP 8x 512MB/Intel 3150
    Turtle Beach RIVERIA 5.1 SPDIF Out/SoundMAX AD1985/Realtek H
    SONY BRAVIA KLV-32V300A V-Series/ KLV-19T400A/ Built-in
    1920x1080/1980x1080/1024x600
    MAXTOR 40GB WD ESSENTIAL EDITION 1TB USB Hitachi HDT721010SLA360 1TB SATA 150/ 250GB Toshiba
    OCZ Fatal1ty 550W/
    Lian-Li v351, Lancool K-62 DragonLord
    Logitech Combo
    Logitech Combo
    512 Kbps
if the graphics card is onboard, check the BIOS settings and see if it can be enabled/disabled, otherwise use the app that comes with the graphics card to detect the TV, NVidia control Panel, or ATI Catalyst, apparently some cards need to be forced to rigorously search for the HDMI monitor.
Thanks
Phil
    Home Built
    AMD 6000+
    ASUS M3N78-VM
    Kingston 8GB
    NVIDIA 8800GT
    VIA
    CIBOX 22" Flatpanel & Panasonic Viera 42" Plasma
    Maxtor 250GB Samsung 250GB Samsung 320GB
    500W
    XCLIO
    Air / Fan
    Logitech MS Revolution
    Logitech G15
    10MB
