USB Stick with Finger Print - x64 Problem
jan112112
Hi!
I just bought a new USB Flash drive (Apacer 8GB), which features a finger print reader. The reason: I want to store my Outlook / OneNote files on it, so I can use them on different computers in different networks.
Now the problem: On the box it says "Vista 32bit". Unfortunately this was never mentioned on the web, where i bought it.
I started the Fingerverify.exe and it loads, however after loading it just ends itself without showing the verification diaglog.
Does anybody know, if (and) how i can get around this?
I tried to open in XP and even Win98 compatibility mode but it does not help either.
Google does not show anything as well...
Thanks for your help,
Jan
That is going to be a driver issue - you'll need to locate Vista x64 compatible drivers for that stick for that to work.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
