Coolgrandma
I have never seen this before. Is it correct or is there something wrong? I bought a new computer with Vista Home Premium. The USB ports are showing on the bottom Task Bar (the way it usually shows a Flash Drive when plugged in), with a little computer and a green check. I have not seen this before for USB drives not in use. If you right click it you get the message "Safely Remove Hardware" and if you go further it is called USB Mass Storage Data at Port_#0005.Hub_#0008. This relates to my Drives G,H,I,J. Can someone clarify this?
