USB Issue
Pretty strange that I couldn't find one google result about WHERE a USB 2.0 port is, everything is "how do I know I have USB 2.0" and not actually where they are on the computer.
Some may say well, just plug in a USB 2.0 usb and see what happens.
However my USB Drive has ALWAYS been saying I'm plugging it in in a port that does not support USB 2.0. I've done this at my college and the same bs occurs. This does not occur for any of my USB drives, not even my 16G one.
Should also mention that whenever I try to access the USB drive, it says "Drive E not formatted, would you like to format it now?" Obviously I click no.
This by the way has nothing to do with my recent virus issues. This particular USB drive has been like this for years now.
Help.
But it is very important now to find out which port on a computer is 2.0. Is there a logo/identifier or something?
Look at your device manager and go down to universal serial bus control.
If you see Standard PCI to USB Host Controller , then you have USB 1.x
If it's Standard Enhanced, then it's 2.0
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Help.
Computer specs on the mfr page will tell you, or the owners manual.
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
I did that, went to control panel and followed the instructions on how to find out if you have USB 2.0.
However it giving me a list of what USB ports I have isn't telling me which ports on the PC is USB 2.0 or 1. There isn't like a diagram showing you if the ports on the side, back, etc. are 2.0 or not. That is the problem, and also because my laptop showed like...20 available ports when I only saw 3 on my entire laptop. That's why the specs are useless (IMO).
Could be infected with the similar crap as well. Malware makers are like online Hitlers or something.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Will this tell me which ports on my laptop is 2.0 or will it list me all the ports I have (which control panel said was over like, 20, 20 "unused ports" but I only saw 3 on my laptop).
My goal is to be able to pinpoint which port on my laptop is 2.0.
No, but it will fill in your system specs and your mobo details.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
I don't see why it is apparently so hard to tell which visible port on a PC is 2 or 1.0.
The problem with diagnostics is they for some reason list ports you never though existed on your computer (i.e. way more ports than you can actually see) not to mention does not let you know which of the ports are in fact USB 2.0 and so on.
It's not like it lets you know once you put a USB drive in one.
