USB 2.0 problem
Sherdalock
Well, im having another problem now. When i try to connect a keyboard or a outside hard drive to my pc it wont recognize it. This motherboard has 4x USB 2.0 slots so that shouldnt be a problem.
My OS : windows vista home premium 64bit
Motherboard : Abit ip35-e
E: The hard drive works on my other computers. And i have XP in em', and i just cant get it work on this computer.. really annoying
    Q9300
    Abit ip35-e
    8GB 800 MHz DDR2
    8800 GTS 512mb
    Samsung 500 GB
Both of them are there. And i think all drives that has been installed are for 64bit, i havent installed any drivers because they installed them in the store that i bought this pc. but where can i check this ?
    Q9300
    Abit ip35-e
    8GB 800 MHz DDR2
    8800 GTS 512mb
    Samsung 500 GB
Device manager would be a good place to start. See what is not installed.
    16GB DDR667
    SAS RAID
Are you using a USB hub? Try connecting a USB mouse directly to the motherboard USB port.
    16GB DDR667
    SAS RAID
Im not using a usb hub. I have connected it always drectly to the motherboards usb port. I have tested all of the ports. Now i will shut down my comp and connect it again and then start up again and then i hope it works
E: Doesnt work.
    Q9300
    Abit ip35-e
    8GB 800 MHz DDR2
    8800 GTS 512mb
    Samsung 500 GB
Make sure in your CMOS that the USB is enabled and legacy USB is enabled.
    16GB DDR667
    SAS RAID
Where i can find it. :o
E: Got this from another forum : "Try turning off the power, unplugging the power cable, unplugging ALL USB input devices, and let it sit for 1-5 minutes."
    Q9300
    Abit ip35-e
    8GB 800 MHz DDR2
    8800 GTS 512mb
    Samsung 500 GB
Reboot. Enter your CMOS on startup usually f2 or del. Not sure check each menu. Usually on Integrated devices but could be elsewhere.
    16GB DDR667
    SAS RAID
I still dont get it.. Where should i click f2 or del. When i boot my pc Abit thing pops up and when i click del it will go to the bios and there was another opinion tab = show post something, cant remember it.
E: When i got the computer and connected the keyboard first time it worked fine, but when i unplugged it and plugged another keyboard that isnt connected to the usb port. Since then usb hasnt worked.
    Q9300
    Abit ip35-e
    8GB 800 MHz DDR2
    8800 GTS 512mb
    Samsung 500 GB
In the BIOS, sorry.
    16GB DDR667
    SAS RAID
Nothing happend when i went to BIOS and i clicked F2. Now i will test to shut down my comp. for a 20 mins. and hold down the on/off button for 30 secs. Then i will to plug it back to my computer again.
    Q9300
    Abit ip35-e
    8GB 800 MHz DDR2
    8800 GTS 512mb
    Samsung 500 GB
Michael was saying that to get *into* your BIOS you either press DEL or F2. Once in the BIOS, you then look for those options in one of the menus.
The F2 / DEL was only for trying to get into the BIOS, nothing more.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
ok sorry i found this :
Usb functions -> disabled
Usb storage -> disabled
other like keyboard and mouse were enabled
    Q9300
    Abit ip35-e
    8GB 800 MHz DDR2
    8800 GTS 512mb
    Samsung 500 GB
try enabling USB functions
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I went through the same thing this weekend with my USB devices. I went into the BIOS to enabled a USB DVD to install XP x64 from. I had to enable a bunch of USB settings to get it to function. Look for legacy settings so your USB mouse and keyboard will work on POST.
    16GB DDR667
    SAS RAID
Thanks alot for u guys again. Keyboard works now, gotta test the outside hard drive later.
There was something about recognizing mouse it was : OS
and keyboard was : BIOS
So i changed that keyboard section to OS and it works now
E: Yep the hard drive works too. Thanks again
    Q9300
    Abit ip35-e
    8GB 800 MHz DDR2
    8800 GTS 512mb
    Samsung 500 GB
For future reference, when trying to post info, be as specific as you can - in this case, when in the BIOS, grab a pen and paper and start writing down *exactly* what you see - otherwise anyone trying to help you is going to be playing a guessing game as to whether you're really in the right spot or not.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
