Urgent help please!!
emanz187
im tryn to update my vista to try stop my BSOD problem..but wen i go to install the update it tells me this..
error Code 8000FFFF?
Help please?
    Gigabyte
    AMD Athlon(tm) 64 X2 Dual Core Processor 6400+ 3.20 GHz
    ASUS Gigabyte S
    3.5Gb
    Nvidia GeForce 9600Gt 512mb
    Realtek high Definition
    VeiwSonic 22" LCD
    1024 by 768 pixels
    320Gb
    Logitec
    Logitec
    1.5mbs
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Help please?
This error have many various meanings,more aspects than MS say in his article.If suggestions from @stoneys-nutz post don't help follow below:
1.Make sure with which one hotfixes do you have problem,only with few hotfixes or with all.
2.Find all DMP files from C:\Windows\Minidump folder
3.Find CBS.log file from C:\Windows\LOGS\CBS folder
4.Find setupapi.dev.log file from C:\Windows\Inf folder
Pack all required files and upload on RapidShare: 1-CLICK Web hosting - Easy Filehosting
well your right, it didn't help? can I just upload those files on here and you can have a look at them?
    Gigabyte
    ASUS Gigabyte S
    3.5Gb
    VeiwSonic 22" LCD
    1024 by 768 pixels
    320Gb
    Logitec
    Logitec
    1.5mbs
sorry there was no minidump folder? I searched it up on my pc but no luck? i need to be abl to install SP1 so i can install SP2..hope this helps
    Gigabyte
    ASUS Gigabyte S
    3.5Gb
    VeiwSonic 22" LCD
    1024 by 768 pixels
    320Gb
    Logitec
    Logitec
    1.5mbs
here they are
    Gigabyte
    ASUS Gigabyte S
    3.5Gb
    VeiwSonic 22" LCD
    1024 by 768 pixels
    320Gb
    Logitec
    Logitec
    1.5mbs
You didn't run SFC command.Neverless there are something interesting things in your logs.
First your setupapi.dev.log filtered: View attachment setup.txt
In this log is full errors like "file does not contain CatalogFile directive for the specified processor architecture <path to any WinSxS component>".But Readiness Tool which can also detect any issues with these folders don't see nothing wrong in your system.Strange :sarc:.
Apart in setupapi.dev.log there are some errors "ACCESS DENIED"
filtered CBS.log View attachment report.txt.As I said before you didn't run SFC command neverless it also interesting.
My suggestions:
1.Because CBS.log report some issues with KB955430 I suggest first uninstall this hotfix,besides run this tool Rizone Security Restore 0.2.2.228 | Rizone Technologies due to "ACCESS DENIED" in setupapi.dev.log.Next,from your CBS.log I think you have already installed SP1 but you don't have installed SP2,so if I have right please install SP2 standalone version http://www.vistax64.com/windows-updates/229199-download-available-standalone-vista-sp2.html
2.If point 1 will fail:
I found on MS Technet a bit similar problem to you:the same error code :0x800f0805 and also CheckSur.log don't report any issues Installation of SP2 requests SP1, which is already installed
It turned out solution is uninstall comletely SP1 and next reinstall SP1 and install SP2.If you can't uninstall SP1 classic method you will have to do through command prompt (read thoroughly @Anand Chinivar and @gnvdk2 posts).
My privates warnings:
If cannot uninstall SP1 classic method,before follow @Anand Chinivar and @gnvdk2 posts you have to create C:\Temp folder ,download SP1 standalone version and place it into C:\Temp folder
Windows6.0-KB936330-X86.exe =SP1
See also MS article about unistalling service pack How to uninstall Windows Vista service packs as a troubleshooting step
If you will have any problems with reinstalling SP1 try it through command prompt like did @gnvdk2 (last his post)
