Urgent Help need with my network!! PLease!
roberthowdle
Hey all, new to the forum here so can you help me out. I have just replaced my motherboard and cpu as i dropped my otherone and broke the legs, so new motherboard and cpu. ~i have reinstalled windows vista and it is working fine except i cannot connect to the internet. i cannot connect to update the network driver. when i am in command prompt i ran it as administrator and tried 'ipconfig' then 'ipconfig /release' but after that operation has failed as no adapter is in the state permissible for this operation. I have tried changed the cable and still nothing. please help!!
Thanks Robert
Thanks Robert
robert have you installed the driver for the new network card/wifi?
ken J
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Thanks Robert
Check in device manager (Control Panel > System > Device Manager) for any devices with a yellow exclamation point. Specifically look in the 'Network Adaptors' section.
if vista did not automatically install the drivers for your network card, you'll have to find out the model and download the drivers on another computer. if you have a usb thumb drive or something similar, use that to bring the drivers over.
    P4 3.40 ghz
    ASrock ConRoe1333-D667 R2.0
    4GB OCZ 667MHZ
    GeForce 8500 GT
    M-Audio Delta 44
    Dell E172fp
    WD 500GB SATA
    CoolerMaster Elite 330
    Razer DeathAdder
    Nexxtech
    3mb DSL
