Solved Upgrade problem
cthornton1966
I just joined today after finding this online earlier and have a few questions before I proceed.
My system is the HP M9350f Quad Core AMD
6GB of RAM
750GB HD
Home Premium 64 bIT
I have a Vista anytime upgrade cd but I am downgrading to 32 bit. Using this guide will it keep me from getting the error that I need to install the "nvidia serial ata controller driver"
I also have a copy of Vista that was used by us techs at the now defunct Circuit City that is an enterprise edition.
Is it true I need to remove some of the RAM to complete the install? or is this trial and error?
If I chose to do a dual boot of 32 and 64 bit (if possible) would I still need to uninstall the RAM
The reason for my wishing to to downgrade to 32 bit is I am a web designer and none of my software (dreamweaver, CS4 suite, cuteFTP) will run on 64 bit.
Thanks and if I didn't provide enough info let me know and I will try and update it!
    HP Pavillion Elite M9350F
    AMD Phenom X4 9850 Quad
    NVIDIA GeForce 8200 Chipset
    6GB
    NVIDIA GeForce 9800GT graphics card 512MB dedicated
    High Definition Audio
    LG 22"
    Internal: 750GB 7200 160GB 7200 External: WD 500GB
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
    Canon MP500 Printer 3-n-1 Dell 5.1 Sound
Thank all of you very much, I tried Paint and it worked great, I will check with canon and see if they have a driver yet as for Dreamweaver 8 they are saying to upgrade to CS4 I can only wounder why, maybe $200.00 dollars. Maybe I will find a fix for that too.
CS4 doesn't work on 64 bit either, that's why I am trying to downgrade to 32 bit or set up a dual boot. I wasted too much money on dreamweaver cs4 when it came out and now they have no help for me, Photo shop is the only one that states 64 bit computability
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
If you want to go back to 32bit you could jump on eBay and usually get Vista Home Basic Upgrade for $40 or so. It will not upgrade over your 64bit though so you would have to format your drive and reinstall everything. I have 4 installations of Home Basic and it works fine for everything I do, as long as you don't have to have Aero.
I have tried this 3 times and keep getting the same errors/notations:
1. Upgrade has been disabled
The upgrade cannot be started because are running a 64 bit version of windows and are trying to upgrade to a 32 bit version of windows.
Cancel this and start over. (I need 32 bit for web design reasons)
[You cannot upgrade from a non-staged build to a staged build.]
2nd error
Windows cannot be installed in this disk (C://)
Needs driver for device [NVIDIA nForce Serial ATA Controller]
I have searched everywhere for a 32 bit version of this driver and everyone I download says its compatible when I try to load it from my jump drive.
I have tried every tutorial on this site pertaining to me.
I have an AMD Pnenom Quad Processor
6GB of RAM (4GB removed for install)
Home Premium 64 Bit
HP M9350F
As stated above I own Adobe CS3 and CS4 and dreamweaver will not run from either, CS4 is the trial edition. I am pulling my hair out because I am losing money by not being able to do design work.
Thanks for any guidance you can give me!
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
Hello CThormton,
You cannot do a upgrade from a 64-bit to a 32-bit OS, or the other way around. You can only do a clean (formatted) install instead. I'm not familiar with how a Anytime Upgrade CD works though. I believe you have to have the previous OS installed first for it work, but it still needs to be a same 32-bit or 64-bit as the previous version.
The driver mentioned should be with your motherboard's chipset drivers. You may need to go to your motherboard's manufacturer's website to download a copy that you can load during the installation of Vista at the point where you select which drive to install Vista on.
They work fine on Vista x64 for me.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
z3r010
The problem I am having is when I edit a file locally then upload to my server they go from 7kb's to 0kb's any suggestions would be tested?
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
Thats very strange, have you tried playing with your firewall settings for port 21 ?
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Yes I have and still can't get it to working and the techs at adobe are not helping either, everyone is confused. I'd love to stay with 64 bit and keep all my RAM but I am having issues and can't afford to lose scripted pages on some of my stores
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
Are you uploading directly with dreamweaver? if so have you tested the ftp with filezilla to see if that has the same problem.
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
I have tested with Filezilla, CuteFTP 8 Pro and a few others that names escape me now. The only way to upload is using my cpanel, which if you are a designer you know that using multiple programs is a PITA.
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
Have you tried turning passive on/off?
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Temporarily it is working, now time to test a css file which was giving me problems as well. It worked on an html page just now.
Thanks z3
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
I have dreamweaver 8 and I have finally figured out everything it takes to get it working on 64bit. It wasn't easy and it took almost a month but it is configured correctly and working fine. I had to upgrade to access 2007, cs3 or cs4 should work fine they came out after vista.
Welp back to the drawing board. It is now breaking my css and php files. on the HD everything edited and in tact. Upload to server and get a blank page.....any more suggestions?
    6GB
    LG 22"
    460W
    Factory
    MX Laser 1000
    Logitech MX3200
