I wonder if anyone can help me with the following: I am new to Vista and only installed it on my new system about a week ago so I expect there is a simple solution to everything!
When I first downloaded and installed all the recommended updates I kept having problems restarting Vista and had to boot from the DVD and repair/restore. Eventually I worked out that installing the updates in similar groups (e.g. all the x64 updates, then drivers etc) and shutting down the system after each install and then turning it back on seemed to enable them to install properly.
When I had eventually finished this (it took a while) I turned the computer off happy! However, when I turned it back on the next day and looked at the available ones - most of them were the ones I'd installed the day before! Mostly x64 and security updates but also 9600GT driver updates and my wireless LAN driver update - all of which had installed successfully the day before.
I've refreshed the list to check it's not old and have double checked the updates installed and they did.
Any help in resolving the above woul be much appreciated. (SP1 is also not offered for update yet)
- Intel Q9550
- Asus
- 2GB DDR2
- NVidia 9600GT
- 22" LG
- 2x 320GB
- PSU
- 500W
