Update problem
Jthom203
i run Vista home x64, and when the updates download and install everything works until the restart. After the bios and windows screen i get a blue screen telling me that windows is unable to restart and to either restart the computer or contact the administrator. So i restart and i get the option to start windows normally or run the repair, if i select normal i get the same blue screen, so i run the repair and it does the system restore which only partially works. i have to run another restore with a point that i have selected for everything back to normal...i have disabled the auto updates and have been hiding new ones because i'm sick of sitting through two restores...any one have any ideas?
:cry::cry: Anyone know how to fix this missing or corrupt start file on vista ultimate after 'the update'from hell? oh, i forgot to add that i dont have the disk or know what im doing. Thanks
well method one takes me to a site that says this project is not published yet. Methods 2 and 3 didn't work
Did you try registering
Check that all device drivers are up to date
Check That you have the latest Bios installed
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
