Since successfully restoring my laptop to factory settings I have been unable to connect using my Intel PRO/Wireless 3945ABG Network Connection.
Initially it worked, but after a while it stopped. I have completed several system restores, and the wireless connection works for a few days. On the last occasion (after installing windows updates) I received the dreaded blue screen and have been unable to connect.
On Saturday, my wireless connection suddenly starting working, 24 hours later it stopped.
I am not sure if it is related to installing new windows updates as prior to restoring to factory settings I had no issues with my wireless connection.
I am able to connect using the ethernet cable and I am currently able to connect using Pluscom wireless usb adapter.
I would be grateful for any suggestions as its driving my insane.
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . :
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Con
nection
Physical Address. . . . . . . . . : 00-1C-BF-5F-C6-9B
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 00-03-0D-84-69-82
Link-local IPv6 Address . . . . . : fe80::5d3e:14dd:2a75:953%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 03 May 2011 13:23:21
Lease Expires . . . . . . . . . . : 04 May 2011 13:23:21
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 134218509
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-15-4C-61-91-00-03-0D-84-69-82
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:2427:a1a:3f57:fffd(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::2427:a1a:3f57:fffd%14(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
nection
rred)
