Ultimate x64 Sleep Mode Troubles
CyborgCat
I'm running Ultimate x64 with:
Intel Core 2 Quad
EVGA GEForce GTX 280
4 Gigs of RAM
GIGABYTE GA-X48-DS4 LGA 775 Intel X48 ATX Intel Motherboard
Western Digital Caviar SE16 WD7500AAKS 750GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
(2, running in RAID)
Whenever the computer goes into sleep mode and i try to wake it up, the fans run for about five seconds then shut off, the computer stays silent for about 10, then the fans run again. This keeps on happening until I have to turn off the power on the surge protector, wait a little bit, then boot it up. The computer then asks me to run it in safe mode and such, and i'm worried about hurting my set up becuase it's brand new.
Is there anything I can do to make it wake up smoothly?
Intel Core 2 Quad
4 Gigs of RAM
Western Digital Caviar SE16 WD7500AAKS 750GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive (2, running in RAID)
Welcome to the Vista Forums :party:
There's an excellent tutorial here that talks about sleep related issues and may help you.
Here's the URL: http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
I hope this helps.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main 500 GB USB External 160 GB USB External 2TB USB External
    DSL 3MB
Hello CyborgCat, and welcome to Vista Forums.
Using Option Two in this tutorial below, double check to see if your sleep settings are like the recommended ones. You should also check your sleep state settings in the BIOS (Step Three) to see if it set to S3.
Also, check to make sure that you have the latest BIOS and chipset driver versions installed for your motherboard.
BIOS:
GIGABYTE - Support - Motherboard - BIOS - GA-X48-DS4 (rev. 1.3)
Chipset Drivers:
GIGABYTE - Support - Motherboard - Driver - GA-X48-DS4 (rev. 1.3)
