Maximum PC Essentials: Ultimate BIOS Tweaking Guide
Written by Gordon Mah Ung 10/06/08 at 01:00:00 PMWhen man first booted the PC, he saw the BIOS screen: a jumble of monochromatic numbers that made about as much sense as the binary language of load lifters. Sadly, not much about the BIOS has changed since the DeLorean and skinny ties were cool. Decades later, in our modern, visual-based world, we’re still greeted with a screen full of text from machines 1,000 times faster than those that were around when the ol’ BIOS was born.
Most PC lightweights simply ignore the BIOS and wait for their OSes to take over. Power users, however, know that the BIOS can be a friendly and rewarding place to go spelunking.
So just what the hell is the BIOS? Short for Basic Input Output System, the BIOS is a tiny bit of software embedded in your motherboard that gets executed when your PC is turned on. The BIOS is responsible for chores such as sizing up the amount of available RAM, detecting the hard drives, and setting the CPU speed. Once the system house-cleaning is done, the BIOS boots the OS from the hard drive and hands over control.
Even though there are only two BIOS makers for consumer desktops today, AMI and Award/Phoenix, a multitude of BIOS variants exists. In fact, a Gigabyte board using an Award BIOS can bear little resemblance to an Asus board using an Award BIOS.
In motherboards designed for enthusiasts, board makers typically unmask as many controls as possible. Unfortunately, the dizzying array of options includes both safe and unsafe tweaks. While some tweaks will just leave you with a system that refuses to boot, others can do long-term harm.
So if you feel the least bit uneasy about even changing the boot order of your rig’s drives, you may not want to muck around too much in the BIOS. If, however, you’re comfortable with the prospect of a little trial and error, it’s time you dive in and discover the many secrets your BIOS holds.
Read more at the Source:
Maximum PC Essentials: Ultimate BIOS Tweaking Guide | Maximum PC
- Operating System
- Windows 10 Pro 64-bit
- Custom
- Intel i7-8700K 5 GHz
- ASUS ROG Maximus XI Formula Z390
- 64 GB (4x16GB) G.SKILL TridentZ RGB DDR4 3600 MHz (F4-3600C18D-32GTZR)
- ASUS ROG-STRIX-GTX1080TI-O11G-GAMING
- Integrated Digital Audio (S/PDIF)
- 2 x Samsung Odyssey G7 27"
- 2560x1440
- 1TB Samsung 990 PRO M.2, 4TB Samsung 990 PRO PRO M.2, 8TB WD MyCloudEX2Ultra NAS
- PSU
- Seasonic Prime Titanium 850W
- Case
- Thermaltake Core P3
- Cooling
- Corsair Hydro H115i
- Logitech MX Master 3
- Logitech wireless K800
- 1 Gb/s Download and 35 Mb/s Upload
- Other Info
- Logitech Z625 speaker system, Logitech BRIO 4K Pro webcam, HP Color LaserJet Pro MFP M477fdn, APC SMART-UPS RT 1000 XL - SURT1000XLI, Galaxy S23 Plus phone
- Operating System
- Windows 10 Pro
- HP Envy Y0F94AV
- i7-7500U @ 2.70 GHz
- 16 GB DDR4-2133
- Conexant ISST Audio
- 17.3" UHD IPS touch
- 3480 x 2160
- 512 GB M.2 SSD
