You should upgrade or use an
alternative browser .
Uh-Oh are my main components too hot!?!
I have a question about hardware which I am not to savvy with yet. What are the healthy temps for each? And the max? Are the temperatures too high?
Intel Core 2 Duo E6400
Intel DG965WH
3 Gigs
PNY Nvidia 9800GTX
Exelstar 160 GB 7200 spin rate Serial ATA (SATA)
they are a little warm but id say nothing to worry about
61.4 KB
Me :P
Core 2 Quad Q6600
Abit IN9 32X MAX
Realtek 7.1 CH HD Audio
1280x1024 + 1360x768
150GB Raptor HDD
500GB Caviar HDD
Thermaltake W0133RB 1200W PSU
Antec 900
Stock + Antec 900 case fans
Logitech MX Revolution
Logitech G15 (full layout)
To xor or not to xor
CPU just a bit too warm I think, but rest seems alright to me really.
Intel Core 2 Quad Q9550
XFX MB-750I-72P9 NF750i
4096MB Corsair XMS2 PC-5400
ASUS Nvidia Geforce GTX470
ASUS Xonar DX
1920x1080 & 1680x1050
Logitech G11 Keyboard
100Mbps
those temps are fine
make sure to clean the fans with compressed air often just to make sure you always have them clean
Is there a better/cheaper fan I can invest in? nor is it not necessary? it is pretty hot in my room probably thats why.
Intel DG965WH
3 Gigs
PNY Nvidia 9800GTX
that will do it however be sure to do what motarola2 said and blow out you PC with compressed air to stopp the fans and cooling radiators from clogging up
Me :P
Core 2 Quad Q6600
Abit IN9 32X MAX
150GB Raptor HDD
500GB Caviar HDD
Antec 900
it hasn't even been a month since i built this computer and i built it in a clean enviorment i doubt its dust also that is all idle while running firefox a movie using vlc on my hd sidebar on hardware monitor and thats about it
this is it now..idle with firefox
38.9 KB
Intel DG965WH
3 Gigs
PNY Nvidia 9800GTX
Intel DG965WH
3 Gigs
PNY Nvidia 9800GTX
How are your case fans set up? Front and side (if present) blowing in, and rear and top (if present) blowing out?
Me
Athlon x2 7750 BE
Asus M4A78 Pro
2x2gb Kingston
Sapphire HD 4830
X-Fi Xtreme Music
Acer P221w and Acer 1916w
1680x1050 and 1440x900
Antec Earthwatts 500W
Antec Sonata III
Logitech G5 v2
Logitech Wave
actually screw it if it is screwed it will auto shutdown i did sum research this can be deleted
Intel DG965WH
3 Gigs
PNY Nvidia 9800GTX
I Click Home To Much
get a better cooler, those temps are ok. but once it gets above 68 or so I'd be worried. a better cooler is a good investment. it always helps. I have a Q6700 with all 4 cores staying under 40C overclocked to 3.5 GHz with a Tuniq Tower Cooler, but you could get by with much cheaper of one.
Or an even better idea. keep the cooler, just take the stock one off, clean it and the CPU off with some Isopropyl Alcohol and some Q-tips. and add Better Thermal Paste.
I got some Artic silver 5. for a few dollars. and replaced my thermal grease with that on my AMD 5400+ 2.8 GHz CPU. and the temps went from high 30's idle to 19C idle.
that was a big differrence. results vary, but a cheap and easy way to get better temps is to get better thermal paste for it. type Thermal paste in Youtube.
Q9650 E0 4.0 GHz @1.304v
eVGA 750i FTW
eVGA/MSI GTX 260 SLI
X-Fi XtremeGamer
Samsung T240 & 226BW
1920x1200 & 1680x1050
PC P&C 750w Silencer PSU
Logitech MX-518
Logitech G11
im coming for cake
though within thermal limits...those temps are pretty high for a 6400 @ about 2ghz
invest in an aftermarket cooler if you have not already done so
the stock intel one is pants!!
mine idles around 35c & loads around 65-67c OCed @ 3.2ghz
ME.....
Q9450 @ 3.6ghz
P5K PREMIUM
8GB 1066mhz buffalo firestix
HD 5970
20'' syncmaster
XCILIO 850w
unknown ATX
Arctic cooler pro 775
logitech cordless optical
logitech EX110
2mb
