You should upgrade or use an
alternative browser .
ok this may sound dumb, but how do i change blabla.zip.txt file in to blabla.zip?
because for some reason, i can only change this blabla.zip,,because the txt extension is hided from the file's name...
When i try to rename it i can only rename the name of the file, not the extensions, there will probably be an easy solution, but im stuck right now
any help is appreciated
Gigabyte Technology / P35-DS3L
Intel Quad Core Q9550 2.83 GHz
3070 mb
Nvidia Gforce 8800 GT
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
3070 mb
Operating System
Operating System
