two problems maybe related
bjacks16
I have two problems but i think that they are connected. When my computer starts up i see the blue hp invent screen for about a minute and then it goes to the screen with the bar at the bottom. It takes about a minute before the green bar starts to move and then it takes about two minutes for it to start going normally. After this it starts up normally. While the time doesn't bother me that much, when it starts up like this my dvd drive isn't recognized. On a normal startup it takes about 30 seconds for it to be fully loaded and the dvd drive is recognized.
I thought that the slow startup may be because of one of my start up programs but i started up in safe mode and it still took a long time. It used to take a long time very rarely but here for the past week it happens almost every time. My computer is a HP, amd phenom quad core,with vista home 64 bit.
Any help would be greatly appreciated
    Intel Pentium D 2.8ghz
    MSI Ms-7301
    2GB DDR2
    Asus HD4670 1gb DDR3
    Realtek HD audio Onboard
    Samsung 19" widescreen
    Seagate 250Gb Internal Western Digital 320Gb External Maxtor 40Gb Internal (Win 7)
    EZ Cool 700W
    Coolermaster Elite 334
    x1 90mm blue LED front, x1 120mm blue LED rear
    Logitech mx620 wireless
    Dell Media Keyboard
Sounds like you got frag (default defrag isnt very good), integrity violations, or disk/file attribute errors.
Try this to scan for and fix. (do all the steps)
http://www.vistax64.com/tutorials/165576-how-make-vista-more-responsive-faster.html?filter
before full defrag command [defrag c: -w] scan for system file integrity issues [sfc /scannow]
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
i just uninstalled itunes and it seems to have worked...fast startup and dvd drive everytime. i'll keep my fingers crossed...if problem comes back i will try both fixes
thanks rive0108 and stew
this is driving me crazy ....my computer loaded up about 5 times perfect and then right back to the way it was...i tried all the steps above and the only problem i had was 5 files called windows sidebar that were corrupted...but what doesn't make sense to me is sometimes it will boot up fine which makes me belive its something small...i've only had this computer about 6 months so its really frustrating me.... any ideas would be welcomed
Sidebar are Windows components.
You performed a disk check and a system file check? Another option may be a system restore to undo the corruption or a re-install of Vista.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
i ran both of those and still nothing...here is one of the files that was in the sfc details ...don't know if this really helps or not but
2009-05-03 10:23:39, Info CSI 0000011c [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
Have you used registry cleaners/optimizers on this computer?
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
the only thing i have used is auslogic registry defrag but that was just two days ago ...i thought it may fix the problem
all the files that are corrupted are windows sidebar ...is there any way to just reinstall windows sidebar to fix these files...or do you even think that this would be the cause
