TV tuner
chinga69
hi all
anyone got a pci-e tv card working with 4 gig of ram or more?:cry:
when i try to use the tv with 4 gig of ram the picture is very jurky.
if i go back to 3 gig of ram everything works fine:D
doesn't matter what prog i use to watch tv it happens and also changing codecs doesn't help
cheers brad :(
    PHENOM II X4 Quad Core 965 Black Edition CPU, 3.40 GHz
    GA-MA790FXT-UD5P
    G.Skill 4GB (2x XMS3 2GB) PC-12800 (1600MHz
    nvidia 9500 gt
    on board
    T231H / X243H ACER
    1980x1050
    Hitachi 500 samsung 1terabyte wd 750
    550 watt
    cooler master
    stock
    logitech
    microsoft
    8000 dl 356 ul
    booting xp32 2x dual pci-e digital tv tuners xp pro v 1xpci digital tv tuners vista ultimate 64 1x pci sat tuner win7 64 win8 64
I have a an ATI TV Wonder Pro 650HD (PCI) running under Vista 64 with 4gig of RAM without issue. It's not a PCI-e though.
With regards to the jerkiness, I've seen this when, a-the drivers are not loaded, or b-the drivers are loaded but the system hasn't been restarted.
Also, are you overclocking? If so, try turning it down and check the results.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
yes also have apci card digital and a sat card there are no problems with these
its something with the way pci-e cards access the extra ram
drivers are fine with less then 4 gig of ram
no overclocking at all
cheers brad
    GA-MA790FXT-UD5P
    nvidia 9500 gt
    on board
    T231H / X243H ACER
    1980x1050
    550 watt
    cooler master
    stock
    logitech
    microsoft
    8000 dl 356 ul
I was just curious, my systems moderately OC, but I don't have any issues. Note the word moderately :)
At any rate, did you figure out your TV tuner problem? And what card do you have? I hear the ATI TV Tuner cards seem to be problematic, especially VisionTek's. I will say I’ve had my VisionTek RMA'd twice, and though I don't have any "problems" per se, I'm not exactly impressed with this replacement's image quality. :(
And VisionTek's tech support? Well...
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
no only it has to do with running 4 gig or more of ram and its only pci-e cards that seem to have the problem
pci cards are twinhan
pci-e cards are digitalnow cards
digital now cards are exellent price and pic quality im hoping they figure the problem soon
the biggest problem is not enough people using them in vista64 with 4 gig or more of ram so its not a high priority for anyone
    GA-MA790FXT-UD5P
    nvidia 9500 gt
    on board
    T231H / X243H ACER
    1980x1050
    550 watt
    cooler master
    stock
    logitech
    microsoft
    8000 dl 356 ul
Whats the best way to watch TV on my Laptop ?
something that we can just put in usb & its set
I have Vist Ultimate 64 bit
usb stick will work
depending on how good your reception is in your area as you might not be able to pick up a good enough signal on the small aerial that you uasally get when you buy a usb dvb-t
so you could be stuck having to watch tv near your main antenna outlet
cheers brad
    GA-MA790FXT-UD5P
    nvidia 9500 gt
    on board
    T231H / X243H ACER
    1980x1050
    550 watt
    cooler master
    stock
    logitech
    microsoft
    8000 dl 356 ul
