TV Tuner help...
BiG TuNa
Hey guys..
I'm looking into buying a Tv tuner but im a total noob when it comes to them...
Can anyone help or recommend a decent tuner or tell me what 2 look for in a tv tuner...
Thanks..:)
I recently installed a Leadtek DTV 2000-H PCI TV Tuner and have had no problems at all. Everything runs smoothly and the Winfast PVR2 software functions perfectly and is relatively easy to navigate through.
Only typical issues with the initial set-up such as not properly reading the instruction manual, but I have never had to reset anything since set-up.
Quality is excellent and all functions perform well.
No compatability issues whatsoever with Vista X64 Home Premium. Driver updates were straightforward and some optional updates are available via Windows Update.
http://www.leadtek.com/eng/tv_tuner/overview.asp?lineid=6&pronameid=252
