TV Tuner Help
Ace_Muska
I recently got a new PC and I was just curious to see wether or not i could hook up my Wii or PS3 to it since it appears to have the same video and video inputs in the front. :confused:
Newegg.com - HP Pavilion M8330F(GX612AA) Phenom X4 9500(2.2GHz) 3GB DDR2 640GB NVIDIA GeForce 8500 GT Windows Vista Home Premium - Desktop PCs
If this is possible would any1 have any recommendations as to what type of software i should use to make this work? I have tried with windows media center and it doesnt seem to do the job. :cry:
I am not sure you can - I think that is for *recording* multimedia, like from a video camera.
Have you tried contacting HP technical support?
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
No I haven't called yet but I knda figured it was possible, aren't you suposed to be able top see the image while recording? :confused: Is There any good software for recording? Im trying to use Chris TV but i just cant work it correctly. I plugged in my Wii and was actualy able to see the Wii menu during the channel scan but at the end of the scan it said there was no channels available. Can anyone help with Chris TV configuraton?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
You're welcome - it took the right combination of search words in Google to find those links, but as soon as I got the combo right for one console, the same set worked for all three, just replacing the console name each time.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
