Tutorial Index
Status
Not open for further replies.
Vista Tutorials
Quick Reference
Index
A - B - C - D - E - F - G - H - I - J - K - L - M - N - O - P - Q - R - S - T - U - V - W - X - Y - Z
A:
Abort - Create Shortcut
How to Create an "Abort" Shortcut in Vista
About Windows Vista
How to See About Windows in Vista
Account Lockout when a User Fails to Logon - Enable
How to Set Account Lockout when a User Fails to Logon in Vista
Activate Vista by Phone
How to Activate Vista Normally and by Phone Activation
Activation - Extend Trial Period
How to Extend Vista Trial Period for Up to 120 Days
Activation - Reduced Functionality Mode
Your Activation Period has Expired
Activation - Uninstall Product Key Number and Deactivate Windows
How to Uninstall the Product Key Number and Deactivate Windows 7 or Vista
Add Printer Wizard Shortcut - Create
How to Create a "Add Printer" Wizard Shortcut in Windows 7 and Vista
Additional Clocks -Add
How to Add Additional Time Zone Clocks in Vista and Windows 7
Additional Clocks Shortcut - Create
How to Create a "Additional Clocks" Shortcut in Windows 7 and Vista
Address Bar in Windows Explorer
How to Use the Windows Explorer Address Bar in Vista
Administrative Tools - Restore Shortcuts
How to Restore the Administrative Tools Shortcuts in Vista
Administrator Account - Change Name
How to Rename the Vista Built-in Administrator Account
Administrator Account- Enable
How to Enable or Disable the Real Built-in Administrator Account in Vista
Administrator Account - Enable from WinRE
How to Enable the Built-in Administrator Account from WinRE
Administrator Account - Reset to Default
How to Reset User Profile of Built-in Administrator Account to Default in Windows
Adobe Illustrator CS5 - Splash Screen - Change
How to Change Adobe Illustrator Start Up Splash Screen
Adobe Photoshop - Change Splash Screen
How to Change Adobe Photoshop Splash Screen
Advanced Appearance
How to Change the Advanced Appearance Settings in Vista
Advanced Appearance Settings - Backup and Restore in Windows
How to Backup and Restore Advanced Appearance Settings in Windows
Advanced Boot Options
How to Boot Up in and Use Advanced Boot Options in Vista
Advanced Search
How to Use Advanced Search Options in Vista
Advanced Searches
How to Use the Advanced Query Language to Improve Windows Search Results
Advanced System Properties - Add to "My Computer" Context Menu
Add "Advanced System Properties" to "This PC" and "My Computer" Context Menu in Vista, Windows 7, and Windows 8
Advanced System Properties Shortcut - Create
Create an "Advanced System Properties" Shortcut in Vista, Windows 7, and Windows 8
Aero - Add "Turn Aero On or Off" to the Context Menu
How to Add or Remove "Turn Aero On or Off" from the Vista Context Menu
Aero - Enable for Windows Vista Home Basic
How to Enable Windows Aero on Vista Home Basic
Aero Glass Transparency - Enable or Disable
How to Enable or Disable Aero Glass Transparency in Vista
Affinity - Add Set CPU Affinity to Context Menu
How to Add or Remove "Run with CPU Affinity" to the Context Menu
AHCI : Enable in Windows 7 / Vista
How to Enable AHCI in Windows after Installation
ALT Key Codes for Special Characters List
How to Type Special Characters with ALT Keyboard Sequences
ALT+TAB - Use Classic Icons or Default Thumbnails
How to Use Classic Icons or Thumbnail Previews with ALT+TAB Keyboard Shortcut
"Always use selected program" - Add or Remove in Open with
How to Add or Remove "Always use selected program" in Open with
"Always use selected program" - Always Checked or Unchecked
How to Have "Always use selected program" Always Checked or Unchecked in "Open with"
Animate controls and elements inside windows - On or Off
How to Turn On or Off "Animate controls and elements inside windows"
Animate Windows when Minimizing and Maximizing
How to "Animate windows when minimizing and maximizing" in Vista, Windows 7, and Windows 8
Animations - "Turn Off All Unnecessary Animations"
How to "Turn off all unnecessary animations" in Vista and Windows 7
App Passwords in your Microsoft Account - Create or Remove
Create or Remove App Passwords in your Microsoft Account when Two-Step Verification is Turned On
Application - Add to "Open with"
How to Add a Program to "Open with" in Vista and Windows 7
Application Associations - Set in Default Programs
How to Set Default Associations For a Program in Vista
Application - Clean Up and Remove from "Open with"
How to Clean Up and Remove Programs from the "Open with" Context Menu
Application - Create Keyboard Shortcut to Open
How to Create a Keyboard Shortcut for a Program in Vista and Windows 7
Application - Desktop Composition - Disable
How to Disable Desktop Composition for a Program
Application - Elevated Shortcut without UAC Prompt - Create
How to Create a Elevated Program Shortcut without a UAC Prompt
Application Installation "Temp Folder" Error - Fix
How to Fix "Temp folder is on a drive that is full or is inaccessible" Program Installation Error in Vista
Application - Pin to Start Menu
How to Pin a Program to the Start Menu in Vista
Application - Remove from List in Default Programs
How to Remove a Listed Program in Default Programs for Windows 7 and Vista
Application - "Run as Different User" Shortcut - Create for Specified Program and User
How to Create a Shortcut to Run a Program as a Specified User
Application Shortcut- Add to Desktop Context Menu
How to Add an Application Shortcut to the Desktop Context Menu
Application - Turn DEP On or Off for
How Turn DEP On or Off for a Program in Vista
Application - Unable To Install Latest Version of in Vista
Install/Uninstall Problems with Vista
Application - Uninstall or Change
How to Uninstall or Change a Program in Vista
Applications and Documents - Run at User Logon
How to Run Specific Programs and Documents at User Logon in Windows 7 and Vista
Applications and Processes - Open and Close in Task Manager
How to Open and Close a Application and Process in Vista Task Manager
Applications - Compatibility Mode
How to Use Compatibilty Mode in Vista
Applications - Compatibility Mode List of Programs
How to See and Change the List of Programs in Compatibility Mode in Vista
Applications - Prevent Running Specified Programs
How to Prevent Users from Running Specified Programs in Windows
Applications - Run Only Specified Programs in Windows
How to Allow Users to Run Only Specified Programs in Windows
Audio Device - Enable Hidden Devices
How to Enable Hidden Audio Devices in Vista and Windows 7
Aurora Boot Screen - Enable
How to Enable the Hidden Aurora Boot Screen in Vista
Aurora Screen Saver - Customize Settings
How to Customize the Vista Aurora Screen Saver Settings
Auto Arrange - Enable or Disable in Windows Explorer
How to Disable Auto Arrange in Vista Windows Explorer to have Free Sorting
AutoComplete - Turn On or Off in Internet Explorer
How to Turn AutoComplete On or Off in Internet Explorer
AutoComplete - Turn On or Off in Windows Explorer
How to Turn AutoComplete On or Off in Windows Explorer
AutoEndTask Apps Not Responding at Shutdown in Windows
How to Turn On or Off to Automatically Close Apps not Responding at Shutdown in Windows
Automatic Logon at Startup in Vista
How to Logon Automatically at Startup in Vista
Automatic Logon at Startup - Bypass in Windows
How to Temporarily Bypass Automatic Logon at Startup in Windows
Autorun.inf Files - Completely Block
How to Completely Block Autorun.inf Files in Windows 7, Vista, and XP
Auto Suggest - Internet Explorer - Delete Typed URLs
How to Delete Typed URLs in Internet Explorer Auto Suggest Drop Down List
Auto Suggest - Windows Explorer - Delete Typed Paths
How to Delete Typed Paths in Windows Explorer Auto Suggest Drop Down List
Auto Suggest - Windows Explorer - Turn On or Off
How to Turn Auto Suggest On or Off in Windows Explorer
Auto Tuning - TCP/IP receive level - Enable or Disable
How to Enable or Disable the Receive Window Auto Tuning Level in Vista
AutoPlay - Enable or Disable for Drives
How to Enable or Disable AutoPlay for Drives in Vista, Widows 7, and Windows 8
AutoPlay - Enable or Disable Remembering User Choices
Enable or Disable AutoPlay Remembering User Choices in Vista, Windows 7, and Windows 8
AutoPlay Settings
How to Change AutoPlay Settings in Vista
Avast - Uninstall Completely
How to Completely Uninstall Avast Antivirus
AVG - Uninstall Completely
How to Completely Uninstall AVG
B:
Background Images - Remove (where available)
How to Remove Background Images to have Only Solid Colors in Windows 7
Background Inteligence Transfer Service - Fix
How To Fix the Background Inteligence Transfer Service in Vista
Backup Complete Computer
How to Create a Complete Computer Backup and Restore Image in Vista
Backup Complete PC - Reset Last Backup Listing
How to Reset the Last Backup Listing for Vista Complete PC Backup
Backup Files
How to Backup Files with Optional Automatic Backups in Vista
Backup Files - Reset Last Backup Listing
How to Reset the Last Backup Listing for Vista Back Up Files
Backup Files - Restore
How to Restore Backup Files in Vista
Backup - Make a "Create Incremental Backup" Shortcut
How to Make a "Create Incremental Backup" Shortcut in Windows 7 and Vista
Backup - Make a "Create New Backup" Shortcut
How to Make a "Create New Backup" Shortcut in Vista, Windows 7, and Windows 8
Backup - Manually Extract Files from Backup in Vista and Windows 7
How to Manually Extract Files from a Backup in Vista and Windows 7
Backup Specific Files in Vista Like NT Backup in XP
How to Backup Specific Files in Vista Like NT Backup in XP
Backup - Restore Files from Selected Backup Location - Create Shortcut
How to Create a "Restore Files from Selected Backup Location" Shortcut
Backup Status and Configuration - Enable or Disable
How to Enable or Disable Backup Status and Configuration in Vista
Basic Disk to a Dynamic Disk - Convert
How to Convert a Basic Disk to a Dynamic Disk
BAT Files - Add "Open with" to Context Menu
How to Add "Open with" to Context Menu of BAT Files in Windows 7 and Vista
Batch File - Add to "New" Context Menu
How to Add "New Batch File" to the Context Menu in Windows
Bing Desktop - Enable or Disable to Run at Windows Startup
How to Turn On or Off Bing Desktop to Run at Windows Startup
Bing Desktop Wallpaper Toolset - Turn On or Off in Windows
How to Turn On or Off Bing Desktop Wallpaper Toolset in Windows
BIOS and UEFI Firmware Version - Find in Windows
How to Find the BIOS and UEFI Firmware Version in Windows
BitLocker - Enable without TPM
How to Enable BitLocker without a Compatible TPM
Bitlocker - Remove and Repair Boot Manager
How to Remove Bitlocker and Repair Boot Manager
Blocked Files - Disable Downloaded Files from being Blocked in Windows
How to Disable Downloaded Files from being Blocked in Windows
Bluetooth File Transfer Shortcut - Create in Windows
How to Create a "Bluetooth File Transfer" Shortcut in Vista, Windows 7, and Windows 8
Bluetooth Notification Area Icon - Turn On or Off in Windows
How to Turn On or Off Bluetooth Notification Area Icon in Windows
Bluetooth Settings Shortcut - Create in Windows
How to Create a "Bluetooth Settings" Shortcut in Vista, Windows 7, and Windows 8
Boot Advanced Options - Number of Processors
How to Change the Number of Processors Used at Boot Up in Vista
Boot Animation GUI - Enable or Disable in Windows
How to Enable or Disable "GUI Boot" in Windows
Boot Information
How to See Vista or Windows 7 Boot Information at Startup
Boot Manager - Change Default Operating System to Run at Startup
How to Change the Default Operating System to Start in Windows 7
Boot Manager - Change Display Time to List OS
How to Change the Amount of Time to Display Operating Systems at Boot in Windows 7
Boot Manager - Change Listed OS Arrangement Order
How to Change the Listed OS Arrangement Order in Windows Boot Manager Screen
Boot Manager - Change OS Name
How to Change the OS Name in Windows Boot Manager
Boot Manager - Delete a Listed Operating System
How to Delete a Operating System Listed in Windows Boot Manager in Windows 7 and Vista
BootMGR Compressed Message at Boot Fix
How to Fix the BootMGR is Compressed Message at Boot
Bootmgr is missing
You get this error while booting into windows
Boot Partition - Default
How to Change the Default Boot Partition in Vista
Boot Priority - Change for Drive
How To Change the Drive Boot Priority in BIOS
Boot Process: Windows Vista vs. Windows XP
How the Windows Vista Boot Process Works
Boot Screen - Enable Aurora
Boot Screen - Change
How to Change the Default Boot Screen in Vista
Boot Time - Speed Up
How to Speed Up Vista Boot Up Time
Boot Up Time
How to See What Your Boot Up Time is in Vista
Browser Cache File Storage - Use RAM Disk
How to Install a RAM Disk for Browser Cache File Storage
BSOD Crash on Ctrl+Scroll Lock - Enable or Disable in Windows
How to Enable or Disable BSOD Crash on Ctrl+Scroll Lock in Windows
BSOD - Debugging a BSOD in Vista
How to Debug a BSOD in Vista
BSOD with netio.sys or ndis.sys - Fix
Bubbles Screen Saver - Customize Settings
How to Customize the Vista Bubbles Screen Saver Settings
Built-in Administrator Account - Change Name
Built-in Administrator - Enable from WinRE
Built-in Administrator Account- Enable
Built-in Administrator Account - Reset to Default
Burning to CD and DVD - Enable or Disable
How to Enable or Disable the Vista Built-in CD and DVD Burning Features
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
C:
CachedLogonsCount - Change
How to Change the Number of Logon Entries Allowed to be Saved in the Logon Cache in Vista
Calendar - Enable or Disable
How to Enable or Disable Windows Calendar in Vista
Cannot Rename or Move a File or Folder in Vista Fix
Caps Lock Key - Enable or Disable
How to Enable or Disable the Caps Lock Key in Vista
Caps Lock - Num Lock - Scroll Lock - Enable or Disable at Windows Startup
How to Enable or Disable a Toggle Key at Startup in Vista, Windows 7, and Windows 8
Caret Browsing - Restore Confirmation Prompt
How to Restore the Caret Browsing Confirmation Prompt
Caret Browsing - Turn On or Off
How to Turn Caret Browsing On or Off within Webpages
Catalyst Control Center - Add or Remove from Desktop Context Menu
How to Add or Remove "Catalyst Control Center" from Desktop Context Menu
Catalyst Control Center Notification Icon - Add or Remove
Add or Remove Catalyst Control Center Taskbar Notification Area Icon in Windows
CCleaner - Delete Junk Files
How to Use CCleaner to Clean Out Junk Files in Windows
CD/DVD Tray - Eject and Close - Add to Desktop Context Menu
How to Add "Eject/Close CD/DVD Tray" to the Context Menu in Windows
CD and DVD Burning to - Enable or Disable
CD and DVD Drive - "You have files waiting to be burned to disc" - Stop Message
How to Stop the "You have files waiting to be burned to disc" Message
"Change a Password" - Add or Remove from Ctrl+Alt+Delete
How to Add or Remove "Change Password" from the Vista Ctrl+Alt+Delete Screen
Character Map
How to Open and Use Character Map in Vista, Windows 7, and Windows 8
Check Disk - chkdsk
How to Run Check Disk at Startup in Vista
Check Disk (chkdsk) - "Press Any Key" Timeout Value at Startup
How to Change Vista Disk Check "Press Any Key" Timeout Value at Startup
Check Disk (chkdsk) - Read Event Viewer Log
How to Read the Event Viewer Log for Check Disk (chkdsk) in Windows 7 and Vista
Chimney Offload State - Enable or Disable
How to Enable or Disable the Chimney Offload State in Vista
Chkdsk will Not Run at Startup in Vista
How to Fix Chkdsk will Not Run at Startup in Vista
Chrome App Launcher Menu - Pin to Taskbar in Windows
How to Pin Chrome App Launcher to Windows Taskbar
Chrome Browser - Add Extensions
How to Add Extensions to Google Chrome Browser
Chrome Browser - Applying a Theme
How to Apply a Theme to the Google Chrome Web Browser
Chrome - DownTheMall Alternative
How to Get a DownTheMall Alternative for Google Chrome
Chrome Browser - Change Default Download Location
How to Change the Default Download Location in Google Chrome
Chrome Browser - Import and Export Bookmarks
How to Import and Export Bookmarks in Google Chrome Browser
Chrome Browser - Import Favorites from Internet Explorer
How to Import Internet Explorer Favorites into Google Chrome Browser
Chrome Browser Prerendering - Enable or Disable
How to Enable or Disable Prerendering in Google Chrome Browser
Chrome Browser Proxy Settings - Change to Speed Up
How to Speed Up Google Chrome with Proxy Settings
Chrome Browser - Reopen Last Browsing Session
How to Reopen the Last Browsing Session in Google Chrome Browser
Chrome Browser - Reset Theme to Default
How to Reset your Theme in Google Chrome to Default
Chrome Browser - Reset to Default
How to Reset Google Chrome Browser to Default
Chrome Browser - Turn Bookmarks Bar On or Off
How to Turn the Bookmarks Bar On or Off in Google Chrome
ChromeCast - Setup and use
How to Setup and Use Google ChromeCast
Chrome GPU Hardware Acceleration - Turn On or Off
How to Turn GPU "Hardware Acceleration" On or Off in Chrome
Citrix SSL Error 86 or 61
Certificate Installation or Verification Issue with Remote Access
Cipher Command - Overwrite Deleted Data in Windows
How to Overwrite Deleted Data using the "Cipher" Command in Windows
Clean and Clean All a Hard Disk with Diskpart Command
How to Clean or Clean All a Disk with the Diskpart Command
Clean Install From Upgrade Vista
How to Do a Clean Install of Vista with a Upgrade Version
Clean Install with a Full Version of Vista
How to Do a Clean Install and Setup with a Full Version of Vista
Clean Startup - Perform to Troubleshoot Application Conflicts
How to Troubleshoot a Problem by Performing a Clean Startup in Windows 7 or Vista
Clear Clipboard - Add to Context Menu in Windows
How to Add "Clear Clipboard" to the Context Menu in Windows
Clear Clipboard Shortcut - Create in Windows
How to Create a "Clear Clipboard" Shortcut in Windows
ClearType Font Settings
How to Change the ClearType Font Settings in Vista
ClickLock Mouse Setting - Turn On or Off
How to Turn Mouse ClickLock On or Off in Vista
Clicking Sound while Browsing Internet and Windows Exporer - Turn Off
How to Change or Turn Off the Clicking Sound while Browsing Internet and Windows Exporer
Clocks - Add Additional Clocks
Clocks - Create "Additional Clocks" Shortcut
Color and Appearance
Color Bit Depth Settings
How to Change the Color Bit Depth Settings in Vista
Color Scheme
How to Change the Color Scheme in Vista
Color Scheme - Allow or Prevent Change
How to Allow or Prevent the Color Scheme to be Changed in Vista
Column - Customize
How to Change the Windows Explorer Columns and Sort Order in Vista
Command Prompt
A List of Commands for Vista and How to Use Them
Command Prompt at Startup
How to Open a Command Prompt at Startup in Vista
Command Prompt - Elevated
How to Open a Elevated Command Prompt in Vista
Command Prompt - Elevated Shortcut - Create
How to Create a "Elevated Command Prompt" Shortcut in Vista
Command Prompt - Enable or Disable
How to Enable or Disable the Command Prompt in Vista and Windows 7
Command Prompt - Delete File
How to Delete a File from the Command Prompt
Command Prompt - Delete Folder
How to Delete a Folder from the Command Prompt
Command Prompt - Open Window Here
How to Use Open Command Prompt Window Here in Vista
Command Prompt - Uninstall Programs in Windows
How to Uninstall Programs using Command Prompt in Windows
Command Prompt QuickEdit Mode - Turn On or Off
How to Turn On or Off Command Prompt QuickEdit Mode in Windows
Common File Dialog Box - Customize Places Bar
How to Customize Default Places Bar in Windows Common File Dialog Boxes
Common Dialog Boxes - Clear Dropdown List of Recent Files History
How to Reset and Clear Common Dialog Boxes Dropdown List of Recent Files History
Common Dialog Boxes - Enable or Disable Dropdown List of Recent Files
How to Enable or Disable Common Dialog Boxes Dropdown List of Recent Files
Common Item Dialog Boxes for Open and Save As - Reset in Windows
How to Reset Open and Save As Common Item Dialog Boxes to Default in Windows
Compatibility Mode
Compatibility Properties Tab - Restore or Remove
How to Restore or Remove the Compatibilty Properties Tab in Vista
Compress a Folder or File
How to Compress and Decompress a Folder or File with NTFS Compression in Vista and Windows 7
Compression - Disable or Enable
How to Disable or Enable NTFS Compression in Vista
Computer - Add or Remove "Advanced System Properties" from Context Menu
Computer - Add or Remove "Device Manager" from Context Menu
How to Add "Device Manager" to "My Computer" Context Menu in Vista and Windows 7
Computer - Add or Remove "Search" from Context Menu
How to Add "Search" to "My Computer" Context Menu in Vista and Windows 7
Computer Case and Start Menu - Change Action of Power Button
How to Change Power Button Settings for the Start Menu and Case in Vista
Computer Folder Name - Change in Windows
How to Change "Computer" Folder Name in Vista, Windows 7, and Windows 8
Computer Management - Add to Desktop Context Menu
How to Add or Remove "Computer Management" to the Desktop Context Menu
Computer Management MMC Snap-in - Enable or Disable
How to Enable or Disable the Computer Management MMC Snap-in
Computer Name
How to Change the Computer Name in Vista
Computer Name - Hide or Unhide in Network
How to Hide or Unhide Your Vista Computer Name in a Network
Computer Name Properties Shortcut - Create
Create a "Computer Name Properties" Shortcut in Vista, Windows 7, and Windows 8
Connect to a Non-Broadcasting Network
[WIRELESS] Connecting to a Network that's not in your list
Contact Groups in Windows Mail - Create
How to Create and Use a Contact Group in Vista
Contacts and Contact Groups - Import into Windows Live Mail
How to Import Vista and Windows 7 Contacts and Contact Groups into Windows Live Mail
Contacts - Export and Import in Windows Live Mail
How to Export and Import Contacts in Windows Live Mail
Contacts - "New Contact" and "New Contact Group" Button Missing
How to Restore the Missing "New Contact" and "New Contact Group" Button in Vista Contacts Folder
Content Advisor Shortcut - Create
How to Create a Internet Explorer "Content Advisor" Shortcut
Context (Shortcuts) Menu
How to Expand the Context (Shortcuts) Menu in Vista
Context Menu - Add "COPY TO FOLDER" and "MOVE TO FOLDER"
How to Add "COPY TO FOLDER" and "MOVE TO FOLDER" to the Context Menu in Vista
Context Menu - Add "Defragment"
How to Add "Defragment" to Context Menu in Windows 7 and Vista
Context Menu - Add "Empty Folder and Subfolders"
How to Add "Empty Folder and Subfolders" to the Vista or Windows 7 Context Menu
Context Menu - Add "Encrypt" and "Decrypt"
How to Add "Encrypt" and "Decrypt" to the Context Menu in Vista
Context Menu - Add "Extract ALL" to MSI Files
How to Add "Extract All" to the Context Menu of MSI Files
Context Menu - Add "Hide - Show Hidden Files"
How to Add "Show/Hide Hidden Files" to Context Menu in Vista and Windows 7
Context Menu - Add "Hide - Show Known File Extensions"
How to Add "Show/Hide Known File Extensions" to Context Menu in Vista and Windows 7
Context Menu - Add or Remove "Clear Clipboard"
Context Menu - Add or Remove "Create Restore Point"
How to Add "Create Restore Point" to Context Menu in XP, Vista, Windows 7, and Windows 8
Context Menu - Add or Remove "Delete Files in Folder" and "Empty Folder"
Add "Delete Files in Folder" and "Empty Folder" to Context Menu of Folders in Windows
Context Menu - Add or Remove "Disk Cleanup"
How to Add "Disk Cleanup" to Context Menu of Drives in Vista, Windows 7, and Windows 8
Context Menu - Add or Remove "Enable/Disable Thumbnails"
Add "Enable/Disable Thumbnails" to Context Menu in Vista, Windows 7, and Windows 8
Context Menu - Add or Remove "List Hidden Files"
How to Add "List Hidden Files" to Context Menu in Vista, Windows 7, and Windows 8
Context Menu - Add or Remove "List Read-only Files"
How to Add "List Read-only Files" to Context Menu in Vista, Windows 7, and Windows 8
Context Menu - Add or Remove "Open File Location" and "Open Folder Location"
How to Add or Remove "Open File Location" and "Open Folder Location" from the Context Menu in Vista
Context Menu - Add or Remove "Open with"
How to Remove or Restore the "Open with" Context Menu Item in Windows
Context Menu - Add or Remove "Open with" for BAT Files
Context Menu - Add or Remove "Open with" for URL Files
How to Add "Open with" to Context Menu of URL Files in Windows 7 and Vista
Context Menu - Add or Remove "Permanently Delete"
How to Add "Permanently Delete" to the Context Menu of Files and Folders
Context Menu - Add or Remove "Register and Unregister" for DLL and OCX Files
How to Add a Register and Unregister Context Menu to DLL and OCX Files in Windows
Context Menu - Add or Remove "Restore Previous Versions"
How to Restore or Remove "Restore Previous Versions" from Context Menu
Context Menu - Add or Remove "Scan with Microsoft Security Essentials"
How to Add or Remove "Scan with Microsoft Security Essentials" from Context Menu in Windows
Context Menu - Add or Remove "Turn Aero On and Off"
Context Menu - Add "Restart Explorer" to Desktop Context Menu
How to Add "Restart Explorer" to the Desktop Context Menu
Context Menu - Add "Run as administrator" to MSI Files
How to Add "Run as administrator" to MSI File Context Menu
Context Menu - Add "Run as administrator" to VBS Files
How to Add "Run as administrator" to VBS File Context Menu
Context Menu - Add "Set CPU Affinity"
Context Menu - Add "Turn Aero On or Off"
Context Menu - Add "View and Print File Directory"
How to Add "View and Print File Directory" to the Context Menu in Vista and Windows 7
Context Menu (Desktop) - Add Application Shortcut
Context Menu (Desktop) - Add or Remove "Edit HOSTS File"
How to Add "Edit HOSTS file" to the Desktop Context Menu in Vista and Windows 7
Context Menu (Desktop) - Add "Empty Recycle Bin"
How to Add "Empty Recycle Bin" to the Desktop Context Menu
Context Menu (Desktop) - Add "Flip 3D"
How to Add "Flip 3D" to the Desktop Context Menu in Vista and Windows 7
Context Menu - Add or Remove "Open Command Window Here"
How to Add or Remove "Open Command Window Here" from the Context Menu
Context Menu - Add or Remove "Run with Priority" for EXE Files
How to Add or Remove "Run with Priority" to Context Menu of EXE Files in Windows
Context Menu - Add or Remove "Send To"
How to Add or Remove "Send To" from the Vista Context Menu
Context Menu - Add "Select All"
How to Add "Select all" to the Context Menu in Vista
Context Menu - Add "Take Ownership"
How to Add "Take Ownership" to the Context Menu in Vista
Context Menu - Change Default Program of "Edit" Context Menu Item in Windows
How to Change the Default Program of the "Edit" Context Menu in Windows
Context Menu - Enable or Disable
How to Enable or Disable the Context Menu in Vista
Context Menu Items Missing - Fix when more than 15 Files are Selected
Restore Missing "Open", "Print", and "Edit" Context Menu Items when more than 15 Files are Selected
Context Menu - "New Folder" - Fix
How to Fix New Folder in Vista
Context Menu - "New" Item - Add or Remove a Item
How to Add and Remove a Item in the"New" Context Menu
Context Menu - "New" Item - Restore or Remove
How to Restore or Remove "New" from the Context Menu in Vista and Windows 7
Context Menu - "New Shortcut" - Fix
How to Fix the New Shortcut Context Menu Item in Vista
Context Menu of Start Menu - Customize
How to Customize the Start Menu Context Menu in Vista
Context Menu - "Open Command Window Here" - Add or Remove Shift + Right Click
How to Use "Open Command Window Here" Context Menu Item without Shift+ Right Click
Context Menu - "Open with Notepad" - Add to Files
How to Add or Remove "Open with Notepad" from the Context Menu of Files
Context Menu - "Pin to Start Menu" Missing Fix
How to Restore Missing "Pin to Start Menu" Context Menu Item in Vista Shortcuts
Context Menu - Restore Default "New" Menu Items
How to Restore Missing Default "New" Context Menu Items in Vista
Context Menu - Restore "Search" After Installing Vista SP1
How to Restore the "Search" Context Menu Item after Installing the Vista SP1
Context Menus and Dragging and Dropping - Disable or Enable in Start Menu
How to Disable or Enable Context Menus and Dragging and Dropping in the Start Menu
Control Panel - Add or Remove "Advanced User Accounts"
How to Add "Advanced User Accounts" to the Control Panel in Vista
Control Panel - Add or Remove "All Tasks" (God Mode)
How to Add or Remove "All Tasks" (God Mode) from Control Panel in Windows
Control Panel - Add or Remove "Local Group Policy Editor"
How to Add or Remove "Local Group Policy Editor" from the Vista Control Panel
Control Panel - Add or Remove "Registry Editor"
How to Add or Remove "Registry Editor" from the Control Panel in Windows
Control Panel - Add or Remove "Services"
How to Add or Remove "Services" from Control Panel in Windows
Control Panel - Add or Remove "System Configuration" (msconfig)
How to Add or Remove "System Configuration" (msconfig) from Control Panel in Windows
Control Panel - Enable or Disable
How to Enable or Disable the Control Panel in Vista and Windows 7
Control Panel - Force Home or Classic View
How to Force Control Panel Home or Classic View in Vista
Control Panel - Hide or Show Icon
How to Hide or Show Icons in the Control Panel in Vista, Windows 7, and Windows 8
Control Panel - Show Specific Icons Only
How to Only Show Specified Control Panel Icons in Vista
Control Panel Desktop Icon - Change
How to Change the Desktop Control Panel Icon in Vista
Control Panel Icons
How to Change a Icon in the Control Panel in Vista
Convert a Dynamic Disk to a Basic Disk
How to Convert a Dynamic Disk to a Basic Disk
Convert FAT or FAT32 Volume to NTFS
How to Convert a FAT or FAT32 Volume to NTFS in Vista
Convert GPT Disk to MBR Disk
How to Convert a GPT Disk to a MBR Disk
Convert MBR Disk to GPT Disk
How to Convert a MBR Disk to a GPT Disk
Cookies - Allow or Block in Internet Explorer
How to Allow or Block Cookies in Internet Explorer in Vista
Cookies - Delete
How to Delete Cookies in Windows 7 and Vista
Copy as Path - Add or Remove from Context Menu
How to Add or Remove "Copy as Path" from the Vista and Windows 7 Context Menu
Copy as Path - File or Folder
How to Copy the Full Path of a File or Folder in Vista and Windows 7
Copy Content to Clipboard - Add to Context Menu
How to Add "Copy Content to Clipboard" to the Context Menu in Windows 7 and Vista
CPU Affinity Shortcut for a Program - Create in Windows
How to Create a Shortcut to Run an Application with a Set CPU Affinity in Windows
CPU - Determine if x64 (64-bit) Capable
Know if you can upgrade or install Windows Vista x64 Edition
CPU - Diagnose
How to Diagnose Intel CPU with Intel Processor Diagnostic Tool
CPU L2 Cache Memory setting in Vista
How to Set Vista for the CPU L2 Cache Memory Size
CPU Priority for Processes
How to Make a Program or Process Run with a Higher or Lower CPU Priority in Vista
CPU Priority Shortcut for a Program - Create in Windows
How to Create a Shortcut to Run an Application with a Specific CPU Priority in Windows
Crash Dumps - Analyse Bugcheck and Process
Helping others work through their BSoD and general application crash issues
Create a Recovery Disc
How to Create a Vista Recovery Disc
Credential Manager Shortcut - Create
How to Create a "Credential Manager" Shortcut in Vista, Windows 7, and Windows 8
CTRL+ALT+DEL - Require to Press to Approve UAC Elevation
How to Require Users to Press CTRL+ALT+DEL to Approve UAC Elevation
CTRL+ALT+DELETE Secure Logon - Enable or Disable
How to Enable or Disable CTRL+ALT+DELETE Secure Logon in Vista
Cursor Blink Rate - Set
How to Set the Cursor Blink Rate in Windows 7 and Vista
Cursor - Set Thickness Width
How to Adjust the Thickness of the Blinking Cursor Line in Vista
Customer Experience Improvement Program
How to Join or Unjoin the Vista Customer Experience Improvement Program
Custom Install Vista
How to Do a Custom Installation of Vista
Customize Tab - Add or Remove from Properties
How to Add or Remove the Customize Tab from Properties in Vista, Windows 7, and Windows 8
D:
Darik's Boot and Nuke - Use to Secure Wipe a Hard Drive
How to Securely Wipe a Hard Disk with "Darik's Boot and Nuke"
Date and Time - Additional Clocks
Date and Time - Additional Clocks Shortcut - Create
Date and Time - Allow or Prevent Users and Groups from Changing
How to Allow or Prevent Specific Users and Groups from Changing the Date and Time
Date and Time - Change
How to Change the Date and Time in Vista
"Date and Time" Shortcut - Create
How to Create a "Date and Time" Shortcut in Windows 7 and Vista
Date and Time - View
How to See the Date and Time on the Taskbar in Vista
Date Format - Change
How to Change the Date Format in Vista
Date Format for Taskbar System Tray - Show Full Day and Month Names
How to Show Day and Month Names in the Windows Taskbar System Tray Date
Debug Diagnostic Tool
Download Debug Diagnostic Tool v2 Update 1
Default File Type Associations - Restore
Restore Default Vista File Extension Type Associations
Default Programs - "Internet Explorer" - Restore or Remove
How to Restore or Remove Internet Explorer from Default Programs
Default Programs - Program Default Associations
Default Programs - Remove a Listed Program
Default Programs - Set File Extension Associations
How to Associate a Individual File Extension Type With a Program in Vista
Default Programs - "Windows Mail" - Restore or Remove
How to Restore or Remove "Windows Mail" from Default Programs
Default Programs - "Windows Media Center" - Restore or Remove
How to Restore or Remove "Windows Media Center" from Default Programs
Default Programs - "Windows Media Player" - Restore or Remove
How to Restore or Remove "Windows Media Player" from Default Programs
Defragment - Add to Context Menu
Defragment Boot Files - Create Shortcut
How to Create a "Defragment Boot Files" Shortcut in Vista
Defragment Boot Files - Enable or Disable
How to Enable or Disable Defrag of Boot Files at Startup in Vista
Delete Confirmation Dialog Prompt Details - Customize in Windows
How to Customize Delete Confirmation Dialog Prompt Details in Windows
Delete Button - Add to Windows Explorer Toolbar
How to Add a Delete Button to the Vista Windows Explorer Toolbar
DEP - Enable or Disable
How to Enable or Disable DEP in Vista, Windows 7, and Windows 8
DEP System Properties Shortcut - Create
How to Create a "DEP System Properties" Shortcut in Vista and Windows 7
DEP - Turn On or Off for Programs
Desktop Background Picture Location History - Clear
How to Clear the desktop background picture location history
Desktop Background Shortcut - Create
How to Create a Change "Desktop Background" Shortcut in Vista and Windows 7
Desktop Background Wallpaper
How to Change the Desktop Background Wallpaper in Vista
Desktop Background Wallpaper - Prevent Change
How to Enable or Prevent the Desktop Background Wallpaper from being Changed in Vista
Desktop Composition - Disable for a Program
Desktop Composition - Enable or Disable
How to Enable or Disable Desktop Composition in Windows 7 and Vista
Desktop Context Menu - Add Application Shortcut
Desktop Context Menu - Add "Empty Recycle Bin"
Desktop Context Menu - Add "Flip 3D"
Desktop Context Menu - Add or Remove "Catalyst Control Center"
Desktop Context Menu - Add or Remove "Computer Management"
Desktop Context Menu - Add or Remove "Create Restore Point"
Desktop Context Menu - Add or Remove "Eject and Close CD/DVD Tray"
Desktop Context Menu - Add or Remove "Kill Not Responding Tasks"
How to Add "Kill Not Responding Tasks" to Desktop Context Menu in Windows
Desktop Context Menu - Add or Remove "Lock Computer"
How to Add "Lock Computer" to the Desktop Context Menu in Vista and Windows 7
Desktop Context Menu - Add or Remove "Lock Computer and Turn Off Monitor"
How to Add "Lock Computer and Turn Off Monitor" to the Context Menu in Windows
Desktop Context Menu - Add or Remove "Log Off"
How to Add "Log Off" Computer to the Desktop Context Menu in Vista and Windows 7
Desktop Context Menu - Add or Remove "NVIDIA Control Panel"
How to Add or Remove "NVIDIA Control Panel" from Desktop Context Menu
Desktop Context Menu - Add or Remove "Restart Computer"
How to Add "Restart" Computer to the Desktop Context Menu in Vista and Windows 7
Desktop Context Menu - Add or Remove "Restart Explorer"
How to Add "Restart Explorer" to the Desktop Context Menu in Vista and Windows 7
Desktop Context Menu - Add or Remove "Safely Remove Hardware"
How to Add "Safely Remove Hardware" to the Desktop Context Menu
Desktop Context Menu - Add or Remove - Screen Saver Toggle On or Off
How to Add "Enable/Disable Screen Saver" to Desktop Context Menu
Desktop Context Menu - Add or Remove "Shut Down Computer"
How to Add "Shut Down" Computer to the Desktop Context Menu in Vista and Windows 7
Desktop Icon Labels - Turn Drop Shadows On or Off
How to Turn Drop Shadows On or Off for Desktop Icons
Desktop Icon Settings Shortcut - Create
How to Create a "Desktop Icon Settings" Shortcut in Vista and Windows 7
Desktop Icon size
How to Change the Size of Desktop Icons in Vista
Desktop Icons
How to Restore and Change a Desktop Icon in Vista
Desktop Icon Text - Hide or Show
How to Hide or Show Desktop Icon Text in Vista
Desktop Icons - View and Sort By
How to Change the Desktop Icons View Alignment and Sort By Order in Vista
Desktop Toolbar - Add or Remove
How to Add or Remove a Desktop Toolbar in Vista
Detailed Status Messages - Logon, Logoff, and Shutdown
Enable or Disable Detailed Verbose Logon, Logoff, Startup, and Shutdown Status Messages in Vista and Windows 7
Details Pane - Change Size in Windows Explorer
How to Change the Size of the Details Pane in Vista and Windows 7
Details Pane - Customize Preview Details in Windows
How to Customize Preview Details in Details Pane of File Explorer in Vista. Windows 7, Windows 8. and Windows 10
Details Pane - Enable or Disable in Windows 7
How to Enable or Disable the Windows Explorer "Details Pane" in Vista and Windows 7
Details Pane Size - Reset in Vista and Windows 7
How to Reset Details Pane Size to Default in Vista and Windows 7
Details Tab - Add or Remove from File Properties
How to Add or Remove "Details" Tab in File Properties in Windows
Device and Device Driver - Uninstall
How to Uninstall a Device and Device Driver in Vista and Windows 7
Device Manager - Add or Remove from "My Computer" Context Menu
Device Manager - Hidden Devices
How to See the Hidden Devices in Device Manager in Vista
Device Manager - Install Driver
How to Install a Device Driver in Vista Device Manager
Device Manager MMC Snap-in - Enable or Disable
How to Enable or Disable the Device Manager MMC Snap-in
Device Manager - Roll Back Driver
How to Roll Back a Device Driver in Device Manager
Device Manager Shortcut - Create
How to Create a "Device Manager" Shortcut in Vista, Windows 7, and Windows 8
Devices - Allow or Prevent to Wake Up Computer
How to Allow or Prevent Devices to Wake Up Computer
Devices and Drivers - Make Ghosts Visible
How to make Ghost Devices and Drivers Visible in Device Manager
Devices - Enable Hidden Audio Devices
Devices - See Devices that are able to Wake Up the Computer
How to See a List of Devices that are able to Wake Up the Computer
Dialog Boxes - Customize Places Bar
DirectX - Check to see which version is installed
How to Check if DirectX 10 and 10.1 is Properly Installed
DirectX Diagnostic Tool
How to Open and Use the DirectX Diagnostic Tool in Vista and Windows 7
Disconnect Network Drive and Map Network Drive - Add or Remove
How to Add or Remove "Map Network Drive" and "Disconnect Network Drive" Options
Disk Check (chkdsk) - chkdsk
Disk Check (chkdsk) - "Press Any Key" Timeout Value at Startup
Disk Check (chkdsk) - Read Event Viewer Log
Disk - Check if MBR or GPT in Windows
How to Check if Disk is MBR or GPT in Windows
Disk Cleanup
How to Use Disk Cleanup in Vista
Disk Cleanup - Add to Context Menu
Disk Cleanup - Correct Shortcut for Vista 64 bit - Fix
How to Correct the Disk Cleanup Shortcut for Vista 64 bit
Disk Cleanup - Extended
How to Run the Extended Disk Cleanup in Vista
Disk Cleanup - Last Access Limit on Temp Files
How to Set Disk Cleanup to Delete Vista or Windows 7 Temporary Files Less than a Week Old
Disk Cleanup Windows Error Reporting Bug Fix
How to Fix the Vista Disk Cleanup Windows Error Reporting Bug
Disk - Convert a Basic Disk to a Dynamic Disk
Disk - Convert a Dynamic Disk to a Basic Disk
Disk - Convert FAT or FAT32 Volume to NTFS
Disk - Convert GPT Disk to MBR Disk
Disk - Convert MBR Disk to GPT Disk
Disk Defragmenter
How to Change the Schedule for Disk Defragmenter in Vista
Disk Defragmenter - Run in Command Prompt
How to Run Disk Defragmenter from the Command Prompt in Vista
Disk - Low Disk Space Warning - Enable or Disable
How to Disable or Enable Low Disk Space Warning in Vista
Disk Management - Delete and Extend Partition
How to Delete and Extend a Partition with Disk Management in Vista
Disk Management - Shrink Partition
How to Shrink and Create a Partition with Disk Management in Vista
Disk - Set as Offline or Online
How to Change Status of a Disk to Offline or Online in Windows
Disk Quota Entries - Export and Import
How to Export and Import User Disk Quota Entries in Windows
Disk Quota - Set Space Limits for Users
How to Set Disk Quota Limits for Users in Windows
Disk Write Protection - Enable or Disable in Windows
How to Enable or Disable Write Protection for a Disk Drive in Windows
Display Language - Change
How to Change the Display Language in Vista
Display Language - Force to Overwrite All Users
How to Overwrite the Display Language of All Users with the System Display Language
Display Settings - Enable or Disable Changing
How to Enable or Disable Changing Display Settings in Vista
DLL and OCX Files - Add or Remove "Register and Unregister" to Context Menu
DNS Resolver Cache
How to See and Flush the Contents of the DNS Resolver Cache in Windows
"Do you want to scan and fix Removable Drive" Prompt - Disable in Windows
How to Disable "Do you want to scan and fix Removable Drive" Prompt in Windows
Documents and Programs - Run at User Logon
DOS USB boot drive
How to Create a DOS USB Boot Drive
DPI Scaling
How to Change the DPI Scale in Vista
DPI Scaling - Add or Remove from Desktop Context Menu
How to Add or Remove "DPI Scaling" from Desktop Context Menu in Vista
Dragging and Dropping and Context Menus - Disable
DreamScene
How to Install and Use DreamScene in Vista Ultimate
DreamScene - Enhanced by DeskScapes
How to Enhance Windows Vista DreamScene with Stardock DreamScapes
DreamScene - Install in Windows 7 and Vista non-Ultimate
How to Install DreamScene in Windows 7 and Vista non-Ultimate
Drive Access - Restrict or Unrestrict
How to Restrict or Unrestrict Drive Access in Vista and Windows 7
Drive Boot Priority - Change
Drive - Encrypt with just One Drive (Not Bitlocker)
How to Encrypt your Entire Drive or a Partition without BitLocker
Drive, File, Folder, or Program - Create Shortcut of in Windows
How to Create a Shortcut of a File, Folder, Drive, or Program in Vista, Windows 7, and Windows 8
Drive - Hide or Unhide
How to Hide or Unhide a Drive in Vista and Windows 7
Drive Icon - Change
How to Change a Drive Icon in Vista
Drive Letter - Add, Change, or Remove
How to Add, Change, or Remove a Drive Letter in Vista
Drive Letters - Hide or Show
How to Hide or Show Drive Letters in Vista, Windows 7, and Windows 8
Drive - Low Disk Space Warning - Enable or Disable
Drive or Partition - Mount or Dismount to a Folder
How to Mount or Dismount a Drive or Partition to a Folder in Vista
Drive Name - Change
How to Rename a Drive in Vista
Drive Shortcut - Create
How to Create a Drive Shortcut in Vista
Driver and Device - Uninstall
Drivers - Clean Left over Files after Uninstalling
How to Clean Left Over Driver Files with Driver Sweeper
Drives and Folders - Bypassing Log-in Passwords to Access
Drives - "Send To" Context Menu - Add or Remove
How to Remove or Show "Drives" in "Send To" Context Menu in Vista, Windows 7, and Windows 8
Dual Boot - Change OS Name in Windows Boot Manager
Dual Boot - Delete a OS
How to Properly Delete a OS in a Dual Boot
Dual Boot Installation with Windows 7 and Vista
How to Setup a Dual Boot Installation with Windows 7 and Vista
Dual Boot Installation - Windows 8 and Windows 7 or Vista
How to Do a Dual Boot Installation with Windows 8 and Windows 7 or Vista
Dual Boot Installation with Vista and XP
How to Setup a Dual Boot Installation with Vista and XP
Dual Boot Using Free Partitioning Software
Dual Boot Vista and Windows 8 - Delete Windows 8
How to Delete "Windows 8" in your Dual Boot with Windows 7 or Vista
Dump File - Change Default Location
How to Change the Default Memory Dump File Location in Windows
Dump Files - Configure Windows to Create on BSOD
How to Configure Windows to Create a Dump File when you get a BSOD
Duplicate Picture Finder
How to Find Duplicate Images in Vista
DVD/CD Tray - Eject and Close - Add to Desktop Context Menu
DVD and CD Burning to - Enable or Disable
DVD and CD Drive - Allow or Deny Read and Write Access
How to Deny or Allow Read and Write Access to CD and DVD Drives in Vista and Windows 7
DVD and CD Drive - "You have files waiting to be burned to disc" - Stop Message
DVD Drive Icon Disappeared from Computer - Fix
How to Retain the DVD Drive Icon if Disappeared from Computer
E:
Ease of Access Center Shortcut - Create
How to Create an "Ease of Access Center" Shortcut in Vista, Windows 7, and Windows 8
"Edit" Context Menu - Change Default Program in Windows
Edit - Open - Print : Fix Missing in Context Menu when more than 15 Files are Selected
Eject and Close CD/DVD Tray - Add to Desktop Context Menu
Elevated Command Prompt Shortcut - Create
Elevated Program Shortcut - Create for Standard User
How to Create an Elevated Program Shortcut Any User is able to Run in Vista, Windows 7, and Windows 8
Elevated Program Shortcut without UAC Prompt - Create
Email - Create "New E-mail Message" Shortcut
How to Create a "New E-mail Message" Shortcut in Vista and Windows 7
Email - Create New E-mail to a Common Contact Shortcut
How to Create a New E-mail Message to a Specified Contact's E-mail Address Shortcut
Emergency Kit - save your files from a dead OS
How to Create and Use a Linux Mint Mate USB Flash Drive to Recover your Files
"Empty Folder and Subfolders" - Add to Context Menu
"Empty Recycle Bin" - Add to Desktop Context Menu
Encrypt Hard Drive with just One Drive (Not Bitlocker)
"Encrypt" and "Decrypt" - Add to Context Menu
Encrypt or Decrypt a Folder or File
How to Encrypt or Decrypt a Folder or File in Vista, Windows 7, and Windows 8
Encrypted File System (EFS) Certificate Backup
How to Backup the Encrypted File System (EFS) Certificate in Vista, Windows 7, and Windows 8
Encrypted File System (EFS) Certificate Restore
How to Restore the Encrypted File System (EFS) Certificate in Vista, Windows 7, and Windows 8
Encrypted Files - Find All on the Local Hard Drives
How to Find and See a List of All Encrypted Files on All Local Hard Drives
Encrypting File System Manager Shortcut - Create
How to Create a "Encrypting File System Manager" Shortcut
Encryption - Disable or Enable
How to Disable or Enable EFS Encryption in Vista, Windows 7, and Windows 8
Enhanced Mitigation Experience Toolkit (EMET)
Error 0x8007000D When Editing MP3 Metadata - Fix
How to Fix 0x8007000D Error when Editing MP3 Metadata
Error Reporting - Disable in Windows
How to Enable or Disable Error Reporting in Vista, Windows 7, and Windows 8
Event Viewer - Email Notification
How to Setup Event Viewer in Vista and Windows 7 to Send a Email Notification
Event Viewer Error 4201
How to Fix the Event Viewer 4201 Error in Vista
Event Viewer - Fix ERROR ID 10
How to Fix the ERROR ID 10 in Vista Event Viewer
Event Viewer Log - Check Disk (chkdsk) - Read
Event Viewer Log - Memory Diagnostics Tool - Read
How to Read the Event Viewer Log for Memory Diagnostics Tool
Event Viewer - Read Wake Source Log
How to Read the Wake Source Log in Event Viewer for Windows 7 and Vista
Environment Variables Shortcut - Create in Windows
How to Create an "Environment Variables" Shortcut in Vista, Windows 7, and Windows 8
Excel - Create 3D Formulas
How to Create 3D Formulas in Excel
Explorer - Add "Restart Explorer" to Desktop Context Menu
Explorer - Restart
How to Restart Explorer in Vista
Explorer32 Shortcut in Vista 64-bit - Create
How to Create a 32-bit Windows Explorer Shortcut in Vista 64-bit
Extract Files from Vista Installation DVD
How to Extract Files from the Vista Installation DVD
F:
Fast User Switching - Add or Remove from Start Menu
How to Add or Remove "Switch User" from the Start Menu in Vista
FAT or FAT32 Volume to NTFS - Convert
Favorite Links in Windows Explorer
How to Open and Use Favorite Links in Vista
Favorite Links Empty in Windows Explorer - Fix
How to Fix Favorite Links Empty in Vista Windows Explorer
Favorite Links - Hide in Windows Explorer
How to Hide Favorite Links in a Windows Explorer Window in Vista
Favorites - Add or Remove Recycle Bin
How to Add or Remove Recycle Bin from Favorites in Navigation Pane in Windows
Favorites Favicon Icons - Reset
How to Reset the Favorites Favicon Icons in Vista and Windows 7
Favorites - Import and Export in Internet Explorer
How to Import and Export Favorites in Internet Explorer
Fax and Scan Shortcut - Create
How to Create a "Windows Fax and Scan" Shortcut in Vista, Windows 7, and Windows 8
Fax without a Fax Machine in Vista
How to fax without a fax machine in vista
Feeds - Import and Export in Internet Explorer
How to Import and Export RSS Feeds in Internet Explorer
Feeds - Subscribe or Unsubscribe to in Internet Explorer
How to Subscribe or Unsubscribe to a RSS Feed in Internet Explorer
Feeds - Use and Subscribe to in Internet Explorer
How to Use and Subscribe to RSS Feeds
File and Folder - Cannot Rename or Move - Fix
File and Folder - Compress
File and Folder - Compression - Disable or Enable
File and Folder Directory List - Print and Save
How to Save and Print a Directory List for a File and Folder in Vista
File and Folder - Hide or Unhide
How to Hide or Unhide a File or Folder in Windows 7 and Vista
File and Folder Names - Change Numerical Sort Order of
How to Change the Sort Order for Numbers in File and Folder Names in Vista
File and Folder - Read-only Attribute - Turn On or Off
How to Set and Unset the Read-only File and Folder Attribute in Vista
File and Folder Shortcuts - Change Icon
How to Change a Shortcut Folder or File Icon in Vista
File - Delete from Command Prompt
File Directory Context Menu - Add "Print File Directory" and "View File Directory"
File Extension Associations - Set in Default Programs
File Extension Type Icon - Change
How to Change a File Extension Type Icon in Vista
File Extention Type - Unassociate
How to Unassociate a File Extension Type in Vista and Windows 7
File Extension Types - Restore Default Associations
File Extensions - "Hide - Show Known File Extensions" - Add to Context Menu
File, Folder, Drive, or Program - Create Shortcut of in Windows
File, Folder, Drive, or Registry Key - Take Ownership of
How to Take Ownership of a Item in Vista and Windows 7
"File" - Menu Bar - Restore or Remove
How to Restore or Remove "File" from Windows Explorer Menu Bar
File Name Extension
How to Show and Change a File Name Extension in Vista
File Names - Hide or Show
How to Hide or Show File Names in Vista
File or Folder - Copy as Path
File or Folder - Encrypt or Decrypt
How to Encrypt or Decrypt a Folder or File in Vista and Windows 7
File Sharing (simple) - Enable
How to Enable Simple File Sharing in Vista
File Sharing - Turn On or Off
How to Turn File Sharing On or Off in Vista
File Signature Verification
How to Open and Use File Signature Verification in Vista and Windows 7
File - Unblock - Open File Security Warning
How to Unblock a File to Stop the "Open File - Security Warning" Prompt for the File
Files - Access from Vista Installation DVD
Access Files On Your Vista Install DVD
Files and Folders - Cannot Select Multiple Fix
Cannot Select Multiple Files and Folders Fix for Vista
Files and Folders - Context Menu - Add or Remove "Permanently Delete"
Files and Folders - Recover with ShadowExplorer
How to Recover Lost Files and Folders with ShadowExplorer
Files and Folders that are Hidden - Hide or Show
How to Hide or Show Hidden Files and Folders in Vista
Files and Screenshots - Upload and Post in Vista Forums
How to Upload and Post a Screenshot and File in Vista Forums
Files - Full Row Select - Disable or Enable
How to Enable or Disable Full Row Select in Vista Windows Explorer
Files - "Hide - Show Hidden Files" - Add to Context Menu
Files - Select using Check Boxes
How to Select Files Using a Check Box in Vista Windows Explorer
Find
How to Use the Find Window to Find Text on a Page
Firefox Advanced Browser Cleanup
How to Clean up Firefox Settings Changed by Browser Hijacking Attacks
Firefox and IE9 - Allow or Prevent Websites to Request Your Location
How to Allow or Prevent Websites to Request Your Location in IE9 and Firefox
Firefox Auto Suggest - Enable or Disable
How to Enable or Disable Auto Suggest in Firefox
Firefox AutoComplete in Address Bar - Enable or Disable
How to Enable or Disable AutoComplete in Firefox
Firefox Automatic Updates - Enable or Disable
How to Enable or Disable Firefox Automatic Updates
Firefox Bookmarks - Export (Backup) and Import (Restore)
How to Export and Import Bookmarks in Firefox
Firefox Bookmarks - Import into Internet Explorer Favorites
How to Import Firefox Bookmarks into Internet Explorer Favorites
Firefox - Change Default Download Save To Location
How to Change the Default Download "Save to" Location in Firefox
Firefox - Create and Run Multiple Profiles
How to Create and Run Multiple Profiles Firefox
Firefox - Customize Orange Bar
How to Customize the Orange Bar in Mozilla Firefox
Firefox - Disable New Tab Animation
How to Disable New Tab Animation in Mozilla Firefox
Firefox "Downloads Complete" Alert - Turn On or Off
How to Turn the "Downloads Complete" Alert On or Off in Firefox
Firefox Favicons - Disable
How to disable Favicons in Mozilla Firefox
Firefox GPU Hardware Acceleration - Turn On or Off
How to Turn GPU "Hardware Acceleration" On or Off in Firefox
Firefox Master Password - Create, Change, or Remove
How to Create, Change, or Remove a Master Password in Firefox
Firefox Minefield - Fix 400 Bad Request YouTube Cookie Error
How to Fix the Firefox Minefield 400 Bad Request YouTube Cookie Error
Firefox - Increase Speed
How to Speed Up Firefox
Firefox Remember Passwords for Sites Exceptions - Remove How to See and Remove "Never Remember Password for This Site" Exceptions in Firefox
Firefox Remember Passwords for Sites - Turn On or Off
How to Turn On or Off Remember Passwords for Sites in Firefox
Firefox - Reset to Default
How to Reset Firefox to Default
Firefox - Restore Previous Browsing Session
How to Restore Previous Browsing Session in Firefox
Firefox Saved Passwords for Sites - See and Remove How to See and Remove Saved Passwords for Sites in Firefox
Firefox - Search from URL Bar
How to Search Using Various Search Engines from the URL Bar in Firefox
Firefox - Set Custom URL for New Tabs
How to Set a Custom URL for New Tabs in Mozilla Firefox
Firefox - Start Firefox in "Safe Mode"
How to Start Firefox in Safe Mode
Firefox - View Cache
How to View the Mozilla Firefox Cache
Firefox - Workarounds for Add-On incompatiblities with Firefox updates
Various methods for getting incompatible Firefox Add-Ons to work in newer browser versions
Flip 3D - Add to Desktop Context Menu
Flip 3D - Enable or Disable
How to Enable or Disable Flip 3D in Vista
Flip 3D Shortcut - Create
How to Use and Create a Flip 3D Shortcut in Vista
Floppy or USB Floppy Drive - Allow or Deny Read and Write Access
How to Deny or Allow Read and Write Access to Floppy Drives in Vista and Windows 7
Folder - Change Open Folder Icon
How to Change the Open Folder Icon in Vista
Folder - Delete Folder Content Context Menu
Folder - Delete from Command Prompt
Folder - "Empty Folder and Subfolders" - Add to Context Menu
Folder - Fix "New Folder"
Folder Icon - Change
How to Change a Folder Icon in Vista and Windows 7
Folder Icon - Change Vista Default Folder Icon
How to Change the Vista Default Folder Icon
Folder - Mount or Dismount a Drive or Partition as
Folder - Open in the Same or Separate New Window
How to Open a Folder in the Same or Separate New Window in Vista
Folder Options
How to Open and Change Folder Options in Vista
Folder Options - Add or Remove Default Items from "View" Tab
How to Add or Remove Default Items from Folder Options "View" Tab in Windows 7 and Vista
Folder Options - Enable or Disable
How to Enable or Disable Folder Options in Vista and Windows 7
Folder Options - "Hidden Files and Folders" - Add or Remove
How to Add or Remove "Hidden Files and Folders" from Folder Options in Vista and Windows 7
Folder Options Shortcut - Create
How to Create a "Folder Options" Shortcut in Vista, Windows 7, and Windows 8
Folder or Shortcut Icon - Hide
How to Hide a Folder or Shortcut Icon in Vista and Windows 7
Folder Permissions
How to Change Folder Permissions
Folder - Pin to Start Menu
How to Pin a Folder to the Start Menu in Vista
Folder Preview Picture - Change
How to Change a Folder Preview Picture in Vista and Windows 7
Folder Size
How to See the Folder Size in Vista
Folder Sorting
Sort your folder views using more than one column header
Folder Type Templates- Change
How to Change a Windows Explorer Folder Type Template in Vista
Folder View Settings - Back Up and Restore in Windows
How to Back Up and Restore Your Folder View Settings in Vista, Windows 7, and Windows 8
Folder View Settings- Reset in Windows Explorer
How to Reset Windows Explorer Folder View Settings to Make Vista Remember
Folder Window Icon Text - Hide or Show File Names
Folder Windows - Restore Previous at Logon
How to Restore Previous Opened Folder Windows at Logon in Vista
Folders and Drives - Bypassing Log-in Passwords to Access
Folders - Open in a New Process - Enable or Disable
How to Enable or Disable Open Folders in a New Process in Vista
Fonts - Change Default
How to Change the Default Vista Fonts
Fonts - ClearType Font Settings - Change
Fonts - Smooth Edges - Enable or Disable
How to Enable or Disable "Smooth Edges of Screen Fonts"
Forgotten Password Wizard Shortcut - Create
How to Create a "Forgotten Password Wizard" Shortcut in Windows 7 and Vista
"Found New Hardware" Balloons - Enable or Disable
How to Enable or Disable "Found New Hardware" Balloons During Device Installation
FTP Server - Using through your Browser
How to Create a Shortcut to Open an FTP Server through your Browser
Full Row Select - Windows Explorer - Disable or Enable
Full Screen F11 Mode - Enable or Disable Auto-Hide
How to Enable or Disable "Auto-Hide" in Vista and Windows 7 Explorer Full Screen F11 Mode
G:
Gadget Not Displayed Correctly - Fix
How to Fix the Windows Sidebar Gadget not Displaying Correctly in Vista
Gadgets - Enable or Disable
How to Enable or Disable Gadgets in Windows 7 and Vista
Game Shortcut Links in Games Explorer Do Not Work
How to Fix Game Shortcut Links in Vista Games Explorer
Games Explorer - Automatic Game Updates - Enable or Disable
How to Enable or Disable Game Updates in Windows 7 and Vista "Games Explorer"
Games Explorer - Downloading Game Information - Enable or Disable
How to Enable or Disable Downloading Game Information in Windows 7 and Vista "Games Explorer"
Games Explorer Folder - Add Games To
How to Add a Game to Games Explorer Folder in Vista, Windows 7, and Windows 8
Games Explorer Folder - Delete a Game
How to Delete a Game in Games Explorer Folder in Vista, Windows 7, and Windows 8
Games Explorer Folder - Hide or Unhide Games
Hide or Unhide Games in Games Explorer Folder in Vista, Windows 7, and Windows 8
Games Explorer - Last Play Time of Games - Enable or Disable
How to Enable or Disable Last Play Time of Games in Windows 7 and Vista "Games Explorer"
Games Explorer Link - Fix
How to Fix the Games Explorer Link in the Vista Start Menu
Games Explorer Shortcut - Create
How to Create a "Games Explorer" Shortcut in Vista, Windows 7, and Windows 8
Games - Parental Controls
How to Control What Games Can be Played in Windows Vista Parental Controls
Get Programs - Create "Install Program from Network" Shortcut
How to Create an "Install Program from Network" Shortcut in Vista, Windows 7, and Windows 8
Ghost Devices & Drivers
How to Make Ghost Devices and Drivers Visible in Device Manager
Google Chrome Browser - Add Extensions
Google Chrome Browser - Applying a Theme
Google Chrome Browser - Change Default Download Location
Google Chrome Browser - DownTheMall Alternative
Google Chrome Browser - Import and Export Bookmarks
Google Chrome Browser - Import Favorites from Internet Explorer
Google Chrome Browser Proxy Settings - Change to Speed Up
Google Chrome Browser - Reopen Last Browsing Session
Google Chrome Browser - Reset Theme to Default
Google Chrome Browser - Reset to Default
Google Chrome Browser - Turn Bookmarks Bar On or Off
Google Drive - Add to "Send To" Context Menu
How to Add Google Drive to "Send To" Context Menu in Windows
Google Updater - Reschedule or Disable
How to Reschedule or Disable Google Updater
GPT Disk to MBR Disk - Convert
GPU Hardware Acceleration - Turn On or Off in Chrome
GPU Hardware Acceleration - Turn On or Off in Firefox
GPU Hardware Acceleration - Turn On or Off in Internet Explorer
How to Turn GPU "Hardware Acceleration" On or Off in IE9 and IE10
Graphics Card Problems - Diagnose
Help Diagnose Graphics Card Problems
Group Policies - Apply to All Users Except Administrators
How to Apply Local Group Policies to All Users Except Administrators
Group Policy - Apply to a Specific User or Group
How to Apply Group Policies to a Specific User or Group in Vista, Windows 7, and Windows 8
Group Policy - Backup and Restore in Windows
How to Back Up and Restore Local Group Policy in Windows
Group Policy Editor - Add to Control Panel
Group Policy Editor - Open
How to Open the Local Group Policy Editor in Vista
Group Policy Editor - Quickly View Enabled Policies in Windows
How to Quickly View Enabled Group Policies in Windows
Group Policy - Reset to Default
How to Reset Local Group Policy to Default in Vista and Windows 7
Group Policy Settings - Force Update in Windows
How to Force Group Policy Updates to be Applied Instantly in Windows
Groups - Add or Remove User Accounts from being a Member of
How to Add or Remove User Accounts from Groups in Windows 7 and Vista
Groups and Users - Allow or Deny Permissions
How to Allow or Deny Permissions to Users and Groups
Groups - Create New or Delete
How to Create and Delete a User Group in Windows 7 and Vista
Guest Account - Change Name
How to Rename the Vista Guest Account
Guest Account - Turn On or Off
How to Turn the Guest Account On or Off in Vista
GUI Boot - Enable or Disable in Windows
GUID - Generate in Windows
How to Generate a New GUID or UUID in Windows
A - B - C - D - E - F - G - H - I - J - K - L - M - N - O - P - Q - R - S - T - U - V - W - X - Y - Z
H:
Hard Disk Drive Space Quota
How to Use Hard Disk Drive Space Quota in Vista
Hard Drive speed boosts
How to Increase Hard Drive Performance in Vista
Hard Drive - Low Disk Space Warning - Enable or Disable
Hard Drive - Turn Off Hard Disk After Idle or Never
How to Turn Off Hard Disk After so many Minutes of being Idle or Never
Hard Drive - Unable to Select or Delete during Installation
You are unable to select or format hard drive partition when you try to install Vista
Hardware System Properties Shortcut - Create
Create a "Hardware System Properties" Shortcut in Vista, Windows 7, and Windows 8
"Help and Support" in Start Menu - Add or Remove
How to Add or Remove "Help and Support" from the Normal and Classic Vista Start Menu
Help and Support in Vista
How to Fix Windows Vista Help and Support
"Help and Support" Shortcut - Create
How to Create a "Windows Help and Support" Shortcut
Help Experience Improvement Program
How to Join or Unjoin the Vista Help Experience Improvement Program
Help (.hlp) Files - Cannot Open in Windows Fix
How to Open 32-bit Help (.hlp) Files that Require WinHlp32.exe in Windows
Hibernate
How to Create a "Hibernate" Shortcut in Vista
Hibernate - Change Size of hiberfil.sys File
How to Change the Size of the hiberfil.sys File in Windows 7 and Vista
Hibernate Computer - Allow or Prevent Users and Groups
How to Allow or Prevent Users and Groups to Hibernate, Restart, Shut Down, and Sleep the PC
Hibernation - Enable or Disable
How to Restore or Disable Hibernation in Vista
Hidden Files - Add "List Hidden Files" to Context Menu
"Hidden Files and Folders" - Add or Remove in Folder Options
Hide - Show Hidden Files - Add to Context Menu
Hide - Show Known File Extensions - Add to Context Menu
Hide or Unhide a File and Folder
HOSTS File - Add or Remove from Desktop Context Menu
HOSTS File - Create a "Edit HOSTS file" Shortcut
How to Create a "Edit HOSTS file" Shortcut in Windows 7 and Vista
Hosts File : Use in Windows
How to Access and Use the Hosts File in Vista, Windows 7, and Windows 8
HungAppTimeout Threshold - Specify in Windows
How to Specify HungAppTimeout Used to Determine a Hung Process in Windows
I:
Icon Cache - Rebuild
How to Rebuild the Icon Cache in Vista
Icon Cache Size - Change in Windows
How to Change the Icon Cache Size in Vista, Windows 7, and Windows 8
Icons - Harvest, Restore & Retain in Vista
How to Harvest, Restore & Retain Icons in Vista
Index - Enable or Disable
How to Enable or Disable the Search Index in Vista and Windows 7
Index - "Windows Search" Service
How to Fix the Start Error For Windows Search Service to Enable the Index in Vista
Indexing Options
How to Use the Indexing Options in Vista
Install Program from Network Shortcut - Create
"Installing device driver software" Balloon - Enable or Disable
Installing Program "Temp Folder" Error - Fix
How to Fix "Temp folder is on a drive that is full or is inaccessible" Program Installation Error in Vista
Intel CPU - Diagnose
Intel HD Graphics desktop context menu - Add or Remove in Windows
How to Add or Remove Intel HD Graphics desktop context menu in Windows
Intel Rapid Storage Technology Notification Icon - Hide or Show
How to Hide or Show Intel Rapid Storage Technology Notification Area Icon in Windows
Internet Explorer 9 - "about:Tabs" - Show More Sites
How to Show More Rows of Sites in Internet Explorer 9 "about:Tabs"
Internet Explorer - Accelerator Add-ons - Add or Remove
How to Add or Remove a Internet Explorer Accelerator Add-on
Internet Explorer - Accelerator Add-ons - Enable or Disable
How to Enable or Disable a Internet Explorer Accelerator Add-on
Internet Explorer - Accelerator Button - Turn On or Off
Turn On or Off IE8 and IE9 Display Accelerator Button on Selection
Internet Explorer - Accelerator - Set Default
How to Set a Default Accelerator in Internet Explorer
Internet Explorer Accelerators - Enable or Disable Usage
How to Enable or Disable the Use of Internet Explorer Accelerators
Internet Explorer 9 - "ActiveX Filtering" - Turn On or Off
How to Turn "ActiveX Filtering" On or Off in Internet Explorer 9
Internet Explorer - Add-ons - Enable or Disable in Add-On Manager
How to Enable or Disable Managing Internet Explorer Add-ons
Internet Explorer - Address and Search Bar - Change Size
How to Change the Size of the Windows 7 Explorer and Internet Explorer Address and Search Bar
Internet Explorer 9 - Allow or Prevent Websites to Request Your Location
Internet Explorer - "Always close all tabs" Warning - Turn On or Off
How to Turn the "Always close all tabs" Warning Message On or Off in Internet Explorer
Internet Explorer - AutoComplete - Turn On or Off
How to Turn AutoComplete On or Off in Internet Explorer
Internet Explorer - Auto Suggest - Delete Typed URLs
How to Delete Typed URLs in Internet Explorer Auto Suggest Drop Down List
Internet Explorer Browsing History - Delete
How to Delete Browsing History of IE7 and IE8
Internet Explorer 9 - Browsing History - Delete
How to Delete the Browsing History of Internet Explorer 9 (IE9)
Internet Explorer - Caret Browsing - Restore Confirmation Prompt
Internet Explorer - Caret Browsing - Turn On or Off
Internet Explorer Clicking Sound while Browsing Internet - Turn Off
Internet Explorer 9 - Command Bar - Customize
How to Customize the Commmand Bar in Internet Explorer 9
Internet Explorer 9 - Command Bar - Move to Left or Right
How to Move the "Command Bar" to the Left or Right in Internet Explorer 9 (IE9)
IE7 and IE8 - Command Bar - Remove or Restore
How to Turn the Command Bar On or Off in IE7 and IE8
Internet Explorer 9 - Command Bar - Turn On or Off
How to Turn the Command bar On or Off in Internet Explorer 9
Internet Explorer - Compatilbility View - All Websites
How to Display All Websites in Compatibility View in Internet Explorer
Internet Explorer - Compatibility View - Turn On or Off
How to Turn Internet Explorer Compatibility View On or Off for a Website
Internet Explorer - Compatibility View Websites - Import and Export
How to Import and Export Compatibility View Websites in Internet Explorer
Internet Explorer Compatibility View Updates
How to Receive Internet Explorer Compatibility View Updates
Internet Explorer - Content Advisor - Allow or Block Specific Websites
How to Allow or Block Specific Websites in Internet Explorer Content Advisor
Internet Explorer - Content Advisor - Allow or Block Unrated Websites
How to Allow or Block Unrated Websites with Internet Explorer Content Advisor
Internet Explorer - Content Advisor - Change Ratings Level
How to Change the Internet Explorer Content Advisor Ratings Level
Internet Explorer - Content Advisor - Enable or Disable
How to Enable or Disable Vista Internet Explorer Content Advisor
Internet Explorer - Content Advisor - Reset
How to Reset Vista Internet Explorer Content Advisor
Internet Shortcut - "Content Advisor" Shortcut - Create
Internet Explorer - Cookies - Allow or Block
Internet Explorer - Cookies - Import and Export
How to Import and Export Cookies in Internet Explorer
Internet Explorer - Cookies Per Site Privacy Actions - Import and Export
How to Import and Export Internet Explorer Cookies Per Site Privacy Actions
Internet Explorer - Cross-site Scripting (XSS) Filter - Turn On or Off
How to Turn the Cross-site Scripting (XSS) Filter On or Off in IE8 and IE9
Internet Explorer Delete Browsing History - Enable or Disable Access
How to Enable or Disable Access to Internet Explorer Delete Browsing History
Internet Explorer Delete Browsing History Shortcuts
How to Create "Delete Browsing History" in Internet Explorer Shortcuts
Internet Explorer - Desktop Icon Shortcut - Create
How to Create a Fully Functional Internet Explorer Shortcut in Vista
Internet Explorer Download Connections per Server - Change
How to Change Maximum Download Connections per Server Limit in Internet Explorer
Internet Explorer 9 - Download History - Delete
How to Delete and Clear the Download History in Internet Explorer 9
Internet Explorer 9 - Download Location - Change Default
How to Change the Default Download Location in Internet Explorer 9
Internet Explorer 9 - Download Speed and Time
How to See the Download Speed and Time in IE9 Download Manager
Internet Explorer 9 - Downloads - View and Track
How to View and Track Downloads in Internet Explorer 9
Internet Explorer 9 - Drag and Drop Tabs
How to Drag and Drop the Tabs in Internet Explorer 9
Internet Explorer - Empty Temporary Internet Files folder when closed
How to Set Internet Explorer to "Empty Temporary Internet Files folder when browser is closed"
Internet Explorer 9 - Enable or Disable Ability to Pin Sites
How to Enable or Disable Internet Explorer 9 Ability to Pin Sites
Internet Explorer F12 Developer Tools - Enable or Disable
How to Enable or Disable "F12 Developer Tools" in Internet Explorer
Internet Explorer Favorites Bar - Customize Title Widths
How to Customize Title Widths on Favorites Bar in Internet Explorer
Internet Explorer Favorites Center - Pin and Unpin to Left Side
How to Pin and Unpin "Favorites Center" to Left Side in IE9, IE10, and IE11
Internet Explorer - Favorites Favicon Icons - Reset
Internet Explorer - Favorites - Import and Export
Internet Explorer Favorites - Import into Google Chrome Browser
Internet Explorer 8 and 9 - First Run Set Up Pop-up - Enable or Disable
How to Enable or Disable Internet Explorer First Run Set Up Welcome Screen
Internet Explorer 9 GPU Hardware Acceleration - Turn On or Off
How to Turn GPU "Hardware Acceleration" On or Off in Internet Explorer 9
Internet Explorer History - View
How to View Internet Explorer History of Visited Websites
Internet Explorer - Home Page - Add or Change
How to Add or Change the Home Page in Internet Explorer
Internet Explorer - Home Page - Open Only First or All
How to Open Only the First or All Home Pages when Internet Explorer Starts
Internet Explorer Home Page - Specify and Prevent Changing
How to Prevent Changing and Specify a Default Home Page in Internet Explorer
Internet Explorer - InPrivate Browsing - Enable or Disable
How to Enable or Disable Internet Explorer InPrivate Browsing
Internet Explorer - InPrivate Browsing Shortcut
How to Create a Internet Explorer "InPrivate Browsing" Shortcut
Internet Explorer 8 - InPrivate Filtering Data - Enable or Disable
How to Enable or Disable InPrivate Filtering Data in Internet Explorer 8
Internet Explorer 8 - InPrivate Filtering - Keep On
How to Keep InPrivate Filtering On or Off in New Internet Explorer 8 Session
Internet Explorer InPrivate Filtering - Turn On or Off
How to Turn Vista Internet Explorer InPrivate Filtering On or Off
Internet Explorer - Maximum Download Sessions
How to Change the Maximum Download Sessions in Internet Explorer 7 for Vista
Internet Explorer - Menu Bar - Always on Top
How to Put the Menu Bar Always on Top in Internet Explorer
Internet Explorer - Menu Bar - Turn Always On or Off
How to Always Have the Internet Explorer Menu Bar Turned On or Off by Default
Internet Explorer 9 - Move, Stop, and Refresh
How to Move Stop and Refresh Buttons to Left or Right of Address Bar in Internet Explorer 9
Internet Explorer 9 - New Tab - Change What Page it Opens To
How to Change What a "New Tab" Opens to in Internet Explorer 9
Internet Explorer No Add-ons Shortcut
How to Restore the Internet Explorer No Add-ons Shortcut
Internet Explorer (No Add-ons) Shortcut - Create
How to Create an "Internet Explorer No Add-ons" Shortcut
Internet Explorer No Add-ons - Start Page
How to Change the Default Start Page for Internet Explorer No Add-ons
Internet Explorer - Notify when Downloads Complete - Turn On or Off
How to Turn On or Off Notify when Downloads Complete in Internet Explorer
Internet Explorer 9 - Open Recently Closed Tabs
How to Open Recently Closed Tabs in Internet Explorer 9
Internet Explorer - Open Selected Text into Notepad
How to Open Selected Text from Internet Explorer into Notepad
Internet Explorer - "Organize Favorites" Shortcut - Create
How to Create a "Organize Favorites" in Internet Explorer Shortcut
Internet Explorer 9 - Pin and Unpin Websites to Taskbar or Start Menu
How to Pin and Unpin Websites from IE9 to the Taskbar or Start Menu
Internet Explorer - Pop-up Blocker - Turn On or Off
How to Turn On or Off and Use IE7 Pop-up Blocker in Vista
Internet Explorer - Pop-up Blocker - Import and Export Settings
How to Import and Export Internet Explorer Pop-up Blocker Settings
Internet Explorer - Protected Mode - Turn On or Off
How to Turn Internet Explorer 8 or 9 Protected Mode On or Off
Internet Explorer - Reopen Last Browsing Session
How to Reopen the Last Browsing Session in Vista Internet Explorer
Internet Explorer - Reopen Last Browsing Session - Disable or Enable
How to Enable or Disable Reopen Last Browsing Session in Internet Explorer
Internet Explorer - Reset
How to Fix a Crashing Internet Explorer in Vista
Internet Explorer - Restore or Remove from Default Programs
Internet Explorer - Restricted Sites - Add and Remove
How to Add and Remove Vista Internet Explorer Restricted Sites
Internet Explorer - RSS Feeds - Import and Export
Internet Explorer - RSS Feeds - Subscribe or Unsubscribe
Internet Explorer - RSS Feeds - Use and Subscribe to
Internet Explorer 9 - Search
How to Search in Internet Explorer 9
Internet Explorer - Search Box
How to Change the Internet Explorer 7 Search Box Settings in Vista
Internet Explorer - Search Box - Add or Remove
How Add or Remove the IE7 and IE8 Search Box
Internet Explorer 8 - Search from Address Bar
How to Enable or Disable Search from Internet Explorer 8 Address Bar
Internet Explorer - Search Providers - Add and Remove
How to Add or Remove Search Providers in Internet Explorer
Internet Explorer - Search Suggestions - Enable or Disable
How to Enable or Disable Search Suggestions in Internet Explorer
Internet Explorer - Security Zones - Add or Remove Sites
How to Add or Remove Sites in Internet Explorer Security Zones
IE Security Zones - Enable or Disable Level Settings
How to Enable or Disable Changing Security Zone Level Settings in Internet Explorer
IE Security Zones - Enable or Disable to Add/Remove Sites
How to Enable or Disable Ability to Add or Remove Sites from Internet Explorer Security Zones
Internet Explorer - Selected Registry Addresses in Regedit
How to Open Selected Registry Address from Internet Explorer into Regedit
Internet Explorer - Selected Text in Notepad
Internet Explorer 9 - "Show tabs on a separate row" - Turn On or Off
How to Turn "Show tabs on a separate row" On or Off in Internet Explorer 9
Internet Explorer - SmartScreen Filter - Enable or Disable
How to Enable or Disable SmartScreen Filter in Vista Internet Explorer
Internet Explorer - SmartScreen Filter - Manually Check a Website
How to Manually Check a Website with IE8 or IE9 SmartScreen Filter
Internet Explorer - SmartScreen Filter - Prevent Bypassing Warnings
How to Prevent Users from Bypassing SmartScreen Filter Warnings in Internet Explorer
Internet Explorer - SmartScreen Filter - Report Unsafe Website
How to Report a Unsafe Website with IE8 or IE9 SmartScreen Filter
Internet Explorer - SmartScreen Filter - Turn On or Off
How to Turn SmartScreen Filter On or Off in Internet Explorer 8 and 9
Internet Explorer - Specify Days to Keep Pages in History
How to Specify Days to Keep Pages in History in Internet Explorer
Internet Explorer Startup - Last Session or Home Page
How to Set Internet Explorer 10 (IE10) to Start with Last Browsing Session or Home Page
Internet Explorer - Tabbed Browsing
How to Use Tabbed Browsing in Internet Explorer in Vista
Internet Explorer - Tabbed Browsing - Enable or Disable
How to Enable or Disable Internet Explorer Tabbed Browsing
Internet Explorer 9 - Tabs - Drag and Drop
Internet Explorer - Temporary Internet Files - Browse
How to Browse the "Temporary Internet Files" of Internet Explorer
Internet Explorer - Temporary Internet Files - Disk Space Usage
How to Change Disk Space to be Used by Internet Explorer "Temporary Internet Files"
Internet Explorer - Temporary Internet Files Settings
How to View the Internet Explorer Temporary Internet Files and Settings in Vista
Internet Explorer Title Bar
How to Create or Remove a Custom Title Bar in Internet Explorer 7
Internet Explorer - Toolbars and Extensions Add-ons - Enable or Disable
How to Enable or Disable Internet Explorer Toolbars and Extensions Add-ons
Internet Explorer 9 - Uninstall
How to Uninstall Internet Explorer 9
Internet Explorer - Webpage Privacy Report
How to View the Webpage Privacy Report in Internet Explorer
Internet Explorer - Webpages - Change Colors
How to Change Colors Used for Webpages in Internet Explorer
Internet Explorer - Webpages - Change Fonts
How to Change Font Styles Used for Webpages in Internet Explorer
Internet Explorer - Webpages - Change Text Size
How to Change Text Size Used for Webpages in Internet Explorer
Internet Explorer - Zoom - Enable or Disable
How to Enable or Disable the Internet Explorer Zoom Level Option
Internet Explorer - Zoom Level
How to Change Internet Explorer Zoom Level
Internet Options - Add or Remove "Advanced" Tab
How to Add or Remove the "Advanced" Tab in Internet Options
Internet Options - Add or Remove "Connections" Tab
How to Add or Remove the "Connections" Tab in Internet Options
Internet Options - Add or Remove "Content" Tab
How to Add or Remove the "Content" Tab in Internet Options
Internet Options - Add or Remove "General" Tab
How to Add or Remove the "General" Tab in Internet Options
Internet Options - Add or Remove "Privacy" Tab
How to Add or Remove the "Privacy" Tab in Internet Options
Internet Options - Add or Remove "Programs" Tab
How to Add or Remove the "Programs" Tab in Internet Options
Internet Options - Add or Remove "Security" Tab
How to Add or Remove the "Security" Tab in Internet Options
Internet Options - Enable or Disable
How to Enable or Disable "Internet Options" in Vista and Windows 7
Internet Options Shortcut - Create
How to Create "Internet Options" Shortcuts in Windows
Internet Shortcut
How to Create a Desktop Internet Shortcut without getting the Default IE Icon in Vista
Internet Time Synchronization
How to Use "Internet Time" Synchronization in Vista and Windows 7
Internet Time Synchronization Update Interval
How to Change the Internet Time Synchronization Update Interval in Vista and Windows 7
Internet Website Shortcut - Create
How to Create an Internet Website Shortcut in Windows
IObit Products - Uninstall Completely
How to Completely Uninstall IObit Products
IP Address
How to Find the Computer IP Address in Vista
ISO - Disk Image File : Extract to the Desktop
How to Extract an ISO File to the Desktop
ISO for Vista - Download and Create Installation DVD or USB
How to Download a Vista ISO and Create an Installation DVD or USB
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
K:
Keyboard Input Language - Change
How to Change the Keyboard Input Language in Vista
Keyboard - On-Screen Keyboard Shortcut - Create
How to Create a "On-Screen Keyboard" Shortcut in Vista, Windows 7, and Windows 8
Keyboard - On-Screen Keyboard - Turn On or Off
How to Turn the On-Screen Keyboard On or Off in Vista, Windows 7, and Windows 8
Keyboard Settings - Change
How to Change the Keyboard Settings in Vista
Keyboard Shortcut - Create to Open a Program
How to Assign a Keyboard Shortcut to Open a Program and Shortcuts in Vista and Windows 7
Keyboard Shortcuts
List of All Keyboard Shortcuts in Vista
Keyboard Shortcuts - Underline
How to Underline Keyboard Shortcuts and Access Keys in Vista and Windows 7
Kill Not Responding Tasks - Add to Desktop Context Menu
Keyboard - Shutdown Vista from
How to Shutdown, Restart, Switch User, Log Off, Sleep, or Lock Vista from the Keyboard
L:
Language - Change
Language - Keyboard Input Language - Change
Last Access Updating - Enable or Disable
How to Enabled or Disable Last Access Updating in Vista
Lastwake Command
How to See What Woke Up Your Computer Last
License Information for Vista
How to See Windows Vista Current License Information
License Type of Windows - Determine if OEM, Retail, or Volume
How to Determine if Windows License Type is OEM, Retail, or Volume
"List Hidden Files" - Add to Context Menu in Windows
"List Read-only Files" - Add to Context Menu in Windows
Local Group Policies - Apply to All Users Except Administrators
Local Group Policy - Apply to a Specific User or Group
Local Group Policy - Backup and Restore in Windows
"Local Group Policy Editor" - Add to Control Panel
Local Group Policy Editor - Open
Local Group Policy Editor - Quickly View Enabled Policies in Windows
Local Group Policy - Reset to Default
Local Security Policy Editor - Open
How to Open the Local Security Policy Editor in Vista
Local Security Policy Settings - Reset to Default in Windows
How to Reset All Local Security Policy Settings to Default in Windows
Local Users and Groups Manager - Open
How to Open Local Users and Groups in Vista
"Local Users and Groups" MMC Snap-in - Enable or Disable
How to Enable or Disable the "Local Users and Groups" MMC Snap-in
Location - Enable or Disable Changing in Windows
How to Enable or Disable Changing GeoID Location in Windows
"Location" Tab in Region and Language - Add or Remove
How to Add or Remove the "Location" Tab in Region and Language
Lock and Switch User - Add or Remove from Start Menu
How to Add or Remove Lock and Switch User from the Start Menu in Vista
Lock Computer
How to Create a Lock Computer Shortcut in Vista
Lock Computer - Add to Desktop Context Menu
Lock Computer - Enable or Disable
How to Enable or Disable Lock Computer in Vista
Lock Computer Screen - Display User Information or Not
How to Display User Information or Not when a Windows Session is Locked
Lock the Taskbar - Enable or Disable
How to Enable or Disable Lock the Taskbar in Vista
Logging off... Text Message - Change
How to Change the "Logging off..." Text Message at Shut Down in Windows 7 and Vista
Log Off
How to Create a "Log Off" Shortcut in Vista
Log Off - Add to Desktop Context Menu
Log Off - Ctrl+Alt+Delete - Add or Remove
How to Add or Remove Log Off from the Ctrl+Alt+Delete Screen in Vista
Log Off Local User in Task Manager
How to Log Off a Local User in Vista and Windows 7
Log Off - Start Menu - Add or Remove
How to Add or Remove Log Off from the Start Menu in Vista
Logon Automatically
How to Logon Automatically at Startup in Vista
Log On Automatically at Startup - Bypass in Windows
How to Temporarily Bypass Automatic Logon at Startup in Windows
Logon - CachedLogonsCount- Change
How to Change the Number of Logon Entries Allowed to be Saved in the Logon Cache in Vista
Logon - Enable Account Lockout when a User Fails to Logon
How to Set Account Lockout when a User Fails to Logon in Vista
Logon Information
How to Display Information About Previous Logons During User Logon in Vista and Windows 7
Logon, Logoff, and Shutdown - Detailed Status Messages
Enable or Disable Detailed Logon, Logoff, and Shutdown Status Messages in Vista
Logon - Restore Previous Folder Windows
Logon - Run Applications and Documents at User Logon
How to Run Specific Programs and Documents at User Logon in Windows 7 and Vista
Logon Screen - Change
How to Change the Logon Screen in Vista
Logon Screen - Change Text Color in Windows
How to Change the Logon Screen Text Color in Vista and Windows 7
Logon Screen Saver - Change
How to Change the Logon Screen Saver Wait Time in Vista
Log On Screen Saver - Enable or Disable
How to Enable or Disable the Log On Screen Saver in Vista
Logon - Secure CTRL+ALT+DELETE - Enable or Disable
Log On Shutdown Options - Remove or Restore
How to Remove or Restore the Vista Log On Shutdown Options
Logon Title and Text Message
How to Display a Logon Message Title and Text in Vista
Log On "Welcome" Text Message - Change
How to Change the "Welcome" Text Message at Log On in Windows 7 and Vista
Logon with Username and Password
How to Make Vista Require a User Name and Password at Logon
M:
Machine Name
How to Change the Computer Name in Vista
Machine Name - Hide or Unhide in Network
How to Hide or Unhide Your Vista Computer Name in a Network
Magnifier - Turn On or Off
How to Turn Magnifier On or Off in Vista
Malicious Software Removal Tool
How to Use the Malicious Software Removal Tool in Vista
"Map Network Drive" and "Disconnect Network Drive" - Add or Remove
Map Network Drive Shortcut - Create
How to Create a "Map Network Drive" Shortcut in Vista, Windows 7, and Windows 8
MBR Disk to GPT Disk - Convert
Media Center - Disc Playback - Create Shortcut
How to Create a Shortcut that Opens Directly to "Disc Playback" in Windows Media Center
Media Center - Favorite Pictures Slide Show Settings - Create Shortcut
How to Create Shortcut that Opens Directly to "Favorite Pictures Slide Show Settings" in Media Center
Media Center - FM Radio - Create Shortcut
How to Create a Shortcut that Opens Directly to " FM Radio" in Windows Media Center
Media Center - Live TV - Create Shortcut
How to Create a Shortcut that Opens Directly to "Live TV" in Windows Media Center
Media Center - Music Library - Create Shortcut
How to Create a Shortcut that Opens Directly to the "Music Library" in Windows Media Center
Media Center - Open with No Startup Animation - Create Shortcut
How to Create a Shortcut to Open Windows Media Center with No Startup Animation
Media Center - Picture Library - Create Shortcut
How to Create a Shortcut that Opens Directly to the "Picture Library" in Windows Media Center
Media Center - Play All Music - Create Shortcut
How to Create a Shortcut to Play All Music in Window Media Center
Media Center - Play Slide Show - Create Shortcut
How to Create a Shortcut to Play the Windows Media Center Slide Show
Media Center - Radio - Create Shortcut
How to Create a Shortcut that Opens Directly to "Radio" in Windows Media Center
Media Center - Recorded TV - Create Shortcut
How to Create a Shortcut that Opens Directly to "Recorded TV" in Windows Media Center
Media Center - Restore or Remove from Default Programs
Media Center - RSS Feeds - Setup to Read
How to Read RSS Feeds with Windows Media Center
Media Center - Scheduled Recordings - Create Shortcut
How to Create a Shortcut that Opens Directly to "Scheduled Recordings" in Windows Media Center
Media Center - Screen Saver - Create Shortcut
How to Create a Shortcut to Start the Windows Media Center Screen Saver
Media Center - Settings Menu - Create Shortcut
How to Create a Shortcut that Opens Directly to the "Settings Menu" in Windows Media Center
Media Center - TV Guide - Create Shortcut
How to Create a Shortcut that Opens Directly to "TV Guide" in Windows Media Center
Media Center Updates - Enable or Disable Waking Computer
How to Enable or Disable Windows Media Center Updates to Wake Up the Computer
Media Center - Video Library - Create Shortcut
How to Create a Shortcut that Opens Directly to the "Video Library" in Windows Media Center
How to Use the Memory Diagnostics Tool in Vista
Memory Diagnostics Tool - Read Event Viewer Log
Memory Dump File - Change Default Location
Menu Bar - "File" - Restore or Remove
Menu Bar - Internet Explorer 9 - Turn Always On or Off
How to Always Have the Internet Explorer 9 Menu Bar Turned On by Default
Menu Bar - Windows Explorer - Enable or Disable
How to Enable or Disable the Menu Bar in Vista
Menu Open Appearance
How to Change the Menu to Appear to the Left or Right of a Click in Vista
Menu Show Delay Time
How to Speed up the Menu Show Delay Time in Vista
Message Reminder - Create Task in Task Scheduler to Display
How to Display a Message Reminder in Windows with Task Scheduler
Message - Send to Local PC on LAN in Windows 7 and Vista
How to Send Local Messages to Computers on LAN in Windows 7 and Vista
Message - Send to a User in Task Manager
How to Send a Message to Another User in Vista and Windows 7
Microsoft Account Aliases - Add or Remove
How to Add or Remove Aliases for your Microsoft Account
Microsoft Account "App Passwords" - Create or Remove
Create or Remove App Passwords in your Microsoft Account when Two-Step Verification is Turned On
Microsoft Account - Close
How to Close Your Microsoft Account
Microsoft Account Display Name - Change
How to Change your Microsoft Account Display Name
Microsoft Account Primary Alias Email Address - Change
How to Change your Microsoft Account Primary Alias Email Address
Microsoft Account Recovery Code - Set up or Replace
How to Set up or Replace your Microsoft Account Recovery Code
Microsoft Account - Sign up for and Create
How to Sign up for and Create a Microsoft Account
Microsoft Account "Two-step Verification" - Turn On or Off
How to Turn "Two-step Verification" On or Off for your Microsoft Account
Microsoft Fix it - Portable
How to Create a Portable Microsoft Fix it
Microsoft Safety Scanner
How to Use the Microsoft Safety Scanner
Microsoft Security Essentials
How to Install and Use Microsoft Security Essentials
Microsoft Security Essentials - Add or Remove "Scan with Microsoft Security Essentials" from Context Menu
How to Add or Remove "Scan with Microsoft Security Essentials" from Context Menu in Windows
Microsoft Security Essentials - Full Scan - Create Shortcut
How to Create a Microsoft Security Essentials "Full Scan" Shortcut
Microsoft Security Essentials - Settings - Create Shortcut
How to Create a Microsoft Security Essentials "Settings" Shortcut
Microsoft Security Essentials - Uninstall Completely
How to Completely Uninstall Microsoft Security Essentials
Microsoft Security Essentials - Update - Create Shortcut
How to Create a Microsoft Security Essentials "Update" Shortcut
Microsoft Security Essentials - Update & Quick Scan - Create Shortcut
How to Create a Microsoft Security Essentials "Update & Quick Scan" Shortcut
Microsoft Security Essentials - Quick Scan - Create Shortcut
How to Create a Microsoft Security Essentials "Quick Scan" Shortcut
Microsoft Services - Check Status
How to Check Status of and Report a Problem with Microsoft Services
Microsoft SpyNet for Windows Defender - Join or Unjoin
How to Join or Unjoin Vista Microsoft SpyNet for Windows Defender
Microsoft Standalone System Sweeper
How to Use the Microsoft Standalone System Sweeper
Microsoft XPS Document Writer - Print to XPS File
How to Print to the Microsoft XPS Document Writer
Military Time
How to Set the Clock to Military 24 Hour Time in Vista
MKLINK – Create and Use Links in Windows
How to Create and Use Links with MKLINK in Windows
MMC Console Settings - Reset to Default
How to Reset MMC Console Settings to Default in Windows
MMC Snap-in - Computer Management - Enable or Disable
How to Enable or Disable the Computer Management MMC Snap-in
MMC Snap-in - Device Manager - Enable or Disable
MMC Snap-in - Local Users and Groups - Enable or Disable
MMC Snap-in - Services - Enable or Disable
How to Enable or Disable the Services MMC Snap-in
MMC Snap-ins - Only Allow Explicitly Enabled MMC Snap-ins to Open
How to Only Allow Explicitly Enabled MMC Snap-ins to Open
Mouse Button - Reverse Left and Right
How to Switch the Functions of the Left and Right Mouse Buttons in Vista
Mouse ClickLock - Turn On or Off
How to Turn Mouse ClickLock On or Off in Vista
Mouse Hovering to Activate a Window
How to Activate a Window by Hovering Over it with the Mouse Pointer in Vista
Mouse Hover Time - Change
How to Change the Mouse Hover Time before Pop-up Displays in Vista
Mouse Keys
How to Use Mouse Keys in Vista
Mouse Pointer - Change
How to Change the Mouse Pointer in Vista
Mouse Pointer - "Snap to" - Turn On or Off
How to Set the Mouse Pointer to "Snap to" the Default Button Automatically in Vista
Mouse Properties Shortcuts - Create
How to Create "Mouse Properties" Shortcuts in Windows 7 and Vista
MP3 Metadata 0x8007000D Error When Editing - Fix
MSConfig - Add or Remove from Control Panel
How to Add or Remove "System Configuration" (msconfig) from Control Panel in Windows
msconfig (System Configuration) Shortcuts - Create
How to Create System Configuration (msconfig) Shortcuts in Windows
MSI File - Add "Extract ALL" to Context Menu
How to Add "Extract All" to the Context Menu of MSI Files
MSI File - Add "Run as administrator" to the Context Menu
How to Add "Run as administrator" to MSI File Context Menu
My Computer - Add or Remove "Advanced System Properties" from Context Menu
Add "Advanced System Properties" to "This PC" and "My Computer" Context Menu in Vista, Windows 7, and Windows 8
My Computer - Add or Remove "Device Manager" from Context Menu
How to Add "Device Manager" to "My Computer" Context Menu in Vista and Windows 7
My Computer - Add or Remove "Search" from Context Menu
How to Add "Search" to "My Computer" Context Menu in Vista and Windows 7
Mystify Screen Saver - Customize Settings
How to Customize the Vista Mystify Screen Saver Settings
N:
Narrator - Turn On or Off
How to Turn Narrator On or Off in Vista
Navigation Pane - Favorite Links in Windows Explorer
Navigation Pane - Favorite Links Empty in Windows Explorer - Fix
Navigation Pane - Favorite Links or Folders - Hide or Show
Navigation Pane - Simple Folder View
How to Hide or Show the Navigation Pane Folders Tree Lines in Vista
Navigation Pane - Turn On or Off in Windows Explorer
How to Turn the Navigation Pane On or Off in Vista
Navigation Pane Width Size - Reset to Default in Windows
How to Reset Navigation Pane Width Size to Default in Windows
Netplwiz - Add to Control Panel
How to Add "User Accounts Netplwiz" to the Control Panel in Vista
Network Adapter (NIC) - Enable or Disable in Windows
How to Enable or Disable a Network Adapter (NIC) in Windows
Network Connection - Delete
How to Delete a Network Connection in Vista
Network Connection Priority - Change in Windows
How to Change the Network Connection Priority in Vista, Windows 7, and Windows 8
Network Connection Status Shortcut
How to Create a "Local Area Network Connection Status" Shortcut in Vista
Network Connections Shortcut
How to Create a "Network Connections" Shortcut in Vista
Network Discovery - Turn On or Off
How to Turn Network Discovery On or Off in Vista
Network Drive - "Disconnect Network Drive" and "Map Network Drive" - Add or Remove
Network for Wireless - Allow or Block with Filter in Windows
How to Add or Remove Wireless Networks from Allowed or Blocked Filter List in Windows
Network - Hide or Unhide your Computer Name
Network Idle Session Time to Automatically Disconnect - Change
How to Change the Network Idle Session Time to Automatically Disconnect in Vista
Network Location Type - Change
How to Change the Network Location Type in Vista
Network User - Disconnect Connection in Task Manager
How to Disconnect a Network User Connection in Vista
Network - View and Browse Computers or Devices
How to View and Browse a Computer or Device on a Network in Vista
Network - QoS Bandwidth Reserve Limit - Change or Disable
How to Change or Disable the QoS Reserved Bandwidth Limit in Vista
New Batch File - Add to Context Menu
How to Add "New Batch File" to the Context Menu in Windows
"New Contact" and "New Contact Group" Button Missing
How to Restore the Missing "New Contact" and "New Contact Group" Button in Vista Contacts Folder
"New" Context Menu - Add or Remove a Item
How to Add and Remove a Item in the"New" Context Menu
"New" Context Menu Item - Restore or Remove
How to Restore or Remove "New" from the Context Menu in Vista and Windows 7
"New" Context Menu - Restore Default Menu Items
How to Restore Missing Default "New" Context Menu Items in Vista
New E-mail Message Shortcut
New Folder - Fix
How to Fix New Folder in Vista
New Registry File - Add to Context Menu
How to Add "New Registry File" to the Context Menu in Windows
New Shortcut - Fix
How to Fix the New Shortcut Context Menu Item in Vista
New VBScript File - Add to Context Menu
How to Add "New VBScript File" to the Context Menu in Windows
Norton/Symantec - Uninstall Completely
How to Completely Uninstall Norton/Symantec Products
Notification Area Balloon Tips - Enable or Disable
How to Enable or Disable Notification Area Balloon Tips in Vista
Notification Area - System Icons - Hide All
How to Show or Hide All Notification Area System Tray Icons in Vista
Notification Area - System Icons - Enable or Disable
How to Enable or Disable the Notification Area System Icons in Vista
Notification Dialog Boxes - Time to Stay Open - Change
How to Change How Long Notification Dialog Boxes Stay Open for in Vista
Notification Icons - Customize - Hide or Show
How to Hide or Show a Notification Icon in Vista
Notification Area Icons - Reset
How to Reset the Notification Area Icons Cache in Windows 7 and Vista
NTFS Compression - Disable or Enable
How to Disable or Enable NTFS Compression in Vista
Num Lock - Caps Lock - Scroll Lock - Enable or Disable at Windows Startup
How to Enable or Disable a Toggle Key at Startup in Vista, Windows 7, and Windows 8
Num Lock - Create Shortcut in Windows
How to Create a Desktop Shortcut to Turn Num Lock ON or OFF
Numerical Sorting - Change Sort Order of File and Folder Names
NVIDIA Control Panel - Add or Remove from Desktop Context Menu
How to Add or Remove "NVIDIA Control Panel" from Desktop Context Menu
NVIDIA Drivers - Avoid Problems
How to Avoid NVIDIA Driver Problems
NVIDIA GeForce Experience: A Beginner's Guide
NVIDIA GPU Overclocking
How to Overclock a NVIDIA GPU
NVIDIA Taskbar Notification Area Icon - Add or Remove
How to Add or Remove NVIDIA Taskbar Notification Area Icon in Windows
Nvidia Video Card - Test with OCCT
How to Test Nvidia Performance with OCCT
O:
OCX and DLL Files - Add or Remove "Register and Unregister" to Context Menu
How to Add a Register and Unregister Context Menu to DLL and OCX Files in Windows
OEM Support Information
How to Add a Logo and Support Information to Vista
Office 2010 - Perform Repairs
How To Perform Repairs in Microsoft Office 2010
Office 2010 Ribbon - Customize
How to Customize the Office 2010 Ribbon
Office 2010 - Slipstream with Service Pack 1
How to Slipstream Office 2010 with Service Pack 1 (SP1)
Office 2013 - Activate
How to Activate Office 2013
Office 2013 AutoRecover and AutoSave - Turn On or Off
How to Turn On or Off AutoRecover and AutoSave for Word, Excel, and PowerPoint 2013
Office 2013 - Recover Saved and Unsaved File Versions
How to Recover Saved and Unsaved Versions of Word, Excel, and PowerPoint 2013 Files
Office 2013 Ribbon Tabs - All CAPITAL Letters Fix
How to Fix All Capital Letters in Ribbon Tabs in Office 2013
Office 2013 "Sign in" and Cloud Capabilities - Turn On or Off
How to Turn On or Off "Sign in" and Cloud File Open and Save in Office 2013
Office 2013 Start Screen - Turn On or Off
How to Turn the Start Screen On or Off in Office 2013 Apps
Office 2013 Typing Animation - Turn On or Off
How to Turn Typing and Other Animations On or Off in Office 2013
Office 2013 - Use with SkyDrive Desktop App
How to Turn On or Off Using SkyDrive Desktop App with Office 2013
Office 2016 Theme - Change for Windows
How to Change Theme of Office 2016 for Windows
Office Toolbar - Rocketdock
How to Use Rocketdock to Create an Office Toolbar
Offscreen Window - Bring it back to desktop
How to Move a Offscreen Window Back to the Desktop in Vista
Online Scanners - Scan Suspicious Files on your PC
How to Scan Suspicious Files using Online Scanners
On-Screen Keyboard Click Sound - Turn On or Off in Windows
How to Turn On or Off On-Screen Keyboard Click Sound in Windows
How to Turn the On-Screen Keyboard On or Off in Vista and Windows 7
OneDrive Account - Reactivate when it has been Shut Down
How to Reactivate OneDrive Account when you get "Your account is currently unavailable"
OneDrive Desktop App - Add or Remove PCs from OneDrive
How to Add or Remove PCs with OneDrive Desktop App from OneDrive
OneDrive Desktop App - Allow or Prevent Start at Sign in
How to Turn On or Off OneDrive Desktop App to Start Automatically at Sign in to Windows
OneDrive Desktop App - Fetch Files on PC
How to Allow or Prevent Fetch Files on your PC with OneDrive Desktop App from OneDrive
OneDrive Desktop App - Install or Uninstall in Windows
How to Install or Uninstall OneDrive Desktop App in Vista, Windows 7, and Windows 8
OneDrive Desktop App - Start or Close in Windows
How to Start and Close OneDrive Desktop App in Windows
OneDrive Desktop App - Unlink OneDrive on your Windows PC
How to Unlink OneDrive on your Windows PC with OneDrive Desktop App
OneDrive Desktop app - Use with Office 2013
How to Turn On or Off Using OneDrive Desktop App with Office 2013
OneDrive - Share Files and Folders and Change Permissions
How to Share Files and Folders and Change Permissions in your OneDrive
OneDrive Storage Space - Manage and Buy more Storage
How to Manage and Buy more Storage Space for your OneDrive
Open and Close CD/DVD Tray - Add to Desktop Context Menu
How to Add "Eject/Close CD/DVD Tray" to the Context Menu in Windows
Open and Save As Common Item Dialog Boxes - Reset in Windows
How to Reset Open and Save As Common Item Dialog Boxes to Default in Windows
"Open Command Window Here" - Context Menu - Add or Remove
How to Add or Remove "Open Command Window Here" from the Context Menu
Open - Edit - Print : Fix Missing in Context Menu when more than 15 Files are Selected
Restore Missing "Open", "Print", and "Edit" Context Menu Items when more than 15 Files are Selected
Open File Dialog Boxes - Clear Dropdown List of Recent Files History
How to Reset and Clear Common Dialog Boxes Dropdown List of Recent Files History
Open File Dialog Boxes - Customize Places Bar
How to Customize Default Places Bar in Windows Common File Dialog Boxes
Open File Dialog Boxes - Enable or Disable Dropdown List of Recent Files
How to Enable or Disable Common Dialog Boxes Dropdown List of Recent Files
"Open File Location" - Add or Remove from Context Menu in Vista
How to Add or Remove "Open File Location" and "Open Folder Location" from the Context Menu in Vista
Open File - Security Warning : Allow or Prevent to Unblock File
Allow or Prevent to Unblock a File to Stop the "Open File - Security Warning" Prompt
Open File - Security Warning : Unblock File
Open Folder Icon
Open Folders in a New Process - Enable or Disable
Open Items with Single Click
How to Single Click to Open an Item in Vista
Open Shortcut Always in Normal window, Minimized, or Maximized
Always Open Shortcut Minimized, Maximized, or Normally in Vista, Windows 7, and Windows 8
Open with - Add Program
How to Add a Program to "Open with" in Vista and Windows 7
Open with - Add to Context Menu of BAT Files
How to Add "Open with" to Context Menu of BAT Files in Windows 7 and Vista
Open with - Add to Context Menu of URL Files
How to Add "Open with" to Context Menu of URL Files in Windows 7 and Vista
Open with - "Always use selected program" - Add or Remove
How to Add or Remove "Always use selected program" in Open with
Open with - "Always use selected program" - Always Checked or Unchecked
How to Have "Always use selected program" Always Checked or Unchecked in "Open with"
Open with - Clean Up and Remove Programs
How to Clean Up and Remove Programs from the "Open with" Context Menu
"Open with" Context Menu Item - Add or Remove
How to Remove or Restore the "Open with" Context Menu Item in Windows
Open with - Opening to Notepad or a Error Fix
Fix Open with "Choose default program" No Program Associated Error in Vista and Windows 7
Open Command Window Here - Add or Remove Shift + Right Click
How to Use "Open Command Window Here" Context Menu Item without Shift+ Right Click
Open with Notepad - Add or Remove from Context Menu of Files
How to Add or Remove "Open with Notepad" from the Context Menu of Files
Opera - Change Speed Dial Thumbnail Images
How to Change Thumbnail Images in Opera Speed Dial Page
Opera - Configure "Speed Dial"
How to Configure Opera's "Speed Dial"
Operating System - Change Default in Windows Boot Manager
How to Change the Default Operating System to Start in Windows 7 and Vista
Operating System - Change Display Time in Windows Boot Manager
How to Change Time to Display Operating Systems at Boot in Windows 7
Operating System - Change Order Listed in Windows Boot Manager Screen
How to Change the Listed OS Arrangement Order in Windows Boot Manager Screen
Operating System - Delete in Windows Boot Manager
How to Delete a Operating System Listed in Windows Boot Manager in Windows 7 and Vista
Operating System Name - Change in Windows Boot Manager
How to Change the OS Name in Windows Boot Manager
"Organize Favorites" in Internet Explorer Shortcut - Create
Outlook 2007 - Forward Mail Instantly
How to Instantly Forward Mail From One E-Mail Account to Another Using Outlook 2007
Outlook 2010 - Always Send from Default Account
How to Always Send New Email from Default Account in Outlook 2010
Outlook 2010 - Copy Existing PST Folders to New PST
How to Copy Existing PST Folders to New PST in Outlook 2010
Outlook 2010 - Import Windows Contacts
How to Import Windows Contacts into Outlook 2010
Outlook 2010 - Signatures - Backup and Restore
How to Backup and Restore Signatures in Outlook 2010
Outlook Autocomplete (.nk2 and .dat) Files - Move and Merge
How to Move and Merge Microsoft Outlook Autocomplete (.nk2 and .dat) Files
Outlook Email Account - Set Up Automatic Reply Message
How to Send Automatic Vacation Reply Message for your Outlook Email Account
Outlook - Fix MAPI32.DLL Error
How to Fix Microsoft Office Outlook MAPI32.DLL Error
Outlook - General Troubleshooting Guide for Issues
General Troubleshooting Guide for Issues with Microsoft Outlook
Outlook New Mail Desktop Alert
How to Create a Outlook New Email Desktop Alert
Outlook PST Data File - Backup
How to Backup Outlook PST Data Files
Outlook PST Data File - Move
How to Move your Outlook PST Data File to a New Location
Outlook PST File Corrupted - Repair
How to Repair a Corrupted Outlook PST File
Outlook.com - Import Email Accounts and Messages
How to Import Email Accounts and Messages at Outlook.com
Outlook.com - Opt-Out or Opt-In for personalized ads
Opt-Out or Opt-In for Personalized Ads and Set Personal Info and Interests on Outlook.com
Owner and Organization Registered in Windows - Change
How to Change Registered Owner and Organization Information in Vista, Windows 7, and Windows 8
P:
Page File - Change or Move in Windows
How to Change or Move Virtual Memory Paging File in Vista, Windows 7, and Windows 8
Page File "Clear at Shutdown" - Enable or Disable
How to Enable or Disable "Clear Virtual Memory Paging File at Shutdown" in Vista and Windows 7
Page File Encryption - Enable or Disable
How to Enable or Disable Page File Encryption in Vista and Windows 7
Paint White Background - Change Default Size in Windows
How to Change Default Size of Paint White Background in Windows
Panda - Uninstall Completely
How to Completely Uninstall Panda Antivirus
Parental Controls - Games
Parental Controls - Setup and Use
How to Setup and Use Parental Controls in Vista
Parental Controls - Specific Programs
How to Allow and Block Specific Programs in Windows Vista Parental Controls
Parental Controls - Time Limits
How to Setup Windows Vista Time Limits in Parental Controls
Parental Controls - Web Filter
How to Setup a Windows Vista Web Filter in Parental Controls
Partition - Mark as Inactive
How to Mark a Partition as Inactive in Windows 7 and Vista
Partition or Drive - Mount or Dismount to a Folder
How to Mount or Dismount a Drive or Partition to a Folder in Vista
Partition - Recover Deleted Partitions in Windows
How to Recover Deleted Partitions in Vista, Windows 7, and Windows 8
Password - "Change a Password" - Add or Remove from Ctrl+Alt+Delete
How to Add or Remove "Change Password" from the Vista Ctrl+Alt+Delete Screen
Password - Change from Win RE
How to Change the User Account Password if Unable to Login to Windows
Password - Create for a User Account
How to Create a Password for a User Account in Vista
Password - Create "Forgotten Password Wizard" Shortcut
Password Expiration in Vista
How to Change or Stop Password Expiration in Vista
Password - Prevent or Allow to Change
How to Prevent or Allow a User to Change their Password in Vista and Windows 7
Password Protected Sharing - Turn On or Off
How to Turn Password Protected Sharing On or Off in Vista
Password Protection on Wakeup
How to Disable or Enable Password Protection on Wakeup in Vista
Password - Remove
How to Remove or Change a Password for a User Account in Vista
Password Reset
How to Reset a User Account Password in Vista
Password Reset Disk
How to Create a Password Reset Disk in Vista
Password Reset Wizard Shortcut - Create
How to Create a "Password Reset Wizard" Shortcut in Windows 7 and Vista
Password - Set with SysKey to Lock or Unlock Windows at Startup
How to Set a Startup Password to Lock or Unlock Windows
Passwords and User Names - Manage
How to Manage Stored User Names and Passwords in Vista
PCIe Link State Power Management - Turn On or Off in Windows
How to Turn On or Off PCIe Link State Power Management in Windows
Performance Options Shortcut - Create
How to Create a Visual Effects Performance Options Shortcut in Windows
Permanently Delete - Add to Context Menu
How to Add "Permanently Delete" to the Context Menu of Files and Folders
Permissions - Allow or Deny Users and Groups
Personal User Folders - Restore Missing Folder
How to Restore a Missing Personal User Folder in Vista
Personal User Shell Folders - Restore Default Icons
How to Fix a Personal User Shell Folder Displayed as a Standard Yellow Folder Icon in Vista
Personal User Shell Folders - Move Location
How to Change a Personal User Folder Location in Vista
Photoshop - Change Splash Screen
How to Change Adobe Photoshop Splash Screen
Pin to Start Menu - Enable or Disable
How to Enable or Disable Pin to Start Menu in Vista
"Pin to Start Menu" Missing from Context Menu Fix
How to Restore Missing "Pin to Start Menu" Context Menu Item in Vista Shortcuts
Places Bar - Customize in Common File Dialog Box
Pointer - Change
Pop-Up Descriptions
How to Turn Pop-up Descriptions On or Off in Vista
Pop-up Descriptions - Change Text in Start Menu
How to Change Start Menu Descriptive Text Pop-up Information in Vista and Windows 7
Power Availability Requests - Manage in Windows
How to View and Override Power Availability Requests in Windows
Power Button- Change Action for Start Menu and Case
How to Change Power Button Settings for the Start Menu and Case in Vista
Power Management - Allow or Prevent Devices to Wake Up Computer
How to Allow or Prevent Devices to Wake Up Computer
Power Management - Create Task to Wake Up Computer
How to Create a Task to Wake up the Computer to Run in Vista and Windows 7
Power Management - Lastwake Command
Power Management - See Available Sleep States
How to See Available Sleep States on Your System
Power Management - See Devices that are able to Wake Up the Computer
How to See a List of Devices that are able to Wake Up the Computer
Power Management - Sleep Return Timeout for Unattended Wake Up - Change
How to Changed the Return to Sleep Timeout for a Unattened Wake Up in Vista
Power Management - Windows Media Center Updates - Enable or Disable Waking Computer
Power Options - Add or Remove "Allow Away Mode Policy"
How to Add or Remove "Allow Away Mode Policy" in Power Options in Windows
Power Options - Add or Remove "Allow wake timers"
How to Add or Remove "Allow wake timers" in Power Options in Windows
Power Options - Add or Remove "Dim display after"
How to Add or Remove "Dim display after" in Power Options in Windows
Power Options - Add or Remove "Enable forced button/lid shutdown"
How to Add or Remove "Enable forced button/lid shutdown" in Power Options
Power Options - Add or Remove "Hard disk burst ignore time"
How to Add or Remove "Hard disk burst ignore time" in Power Options
Power Options - Add or Remove "Hibernate after"
How to Add or Remove "Hibernate after" in Power Options in Windows
Power Options - Add or Remove Link State Power Management
How to Add or Remove PCIe "Link State Power Management" in Power Options in Windows
Power Options - Add or Remove "Min/Max processor state"
How to Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows
Power Options - Add or Remove "System cooling policy"
How to Add or Remove "System cooling policy" in Power Options in Windows
Power Options - Add or Remove "System unattended sleep timeout"
How to Add or Remove "System unattended sleep timeout" in Power Options
Power Options - Add or Remove "Turn off hard disk after"
How to Add or Remove "Turn off hard disk after" in Power Options in Windows
Power Options - Add or Remove USB Selective Suspend
How to Add or Remove "USB selective suspend setting" in Power Options in Windows
Power Options - Add or Remove "When sharing media"
How to Add or Remove "When sharing media" in Power Options in Windows
Power Options - Add or Remove Wireless Adapter Settings
How to Add or Remove Wireless Adapter Settings "Power Saving Mode" in Windows
Power Options and Sleep Mode Problems
How to Troubleshoot a Vista or Windows 7 Sleep Mode Problem and Find a Solution
Power Options Desktop Shortcut
How to Create a "Power Options" Shortcut in Vista
Power Plan - Restore Default Settings
How to Restore the Default Power Plan Settings in Vista
Power Plan Settings - View in Text File in Windows
How to View Power Plan Settings in a Text File in Windows
Power Plan - Specify a Default for All Users
How to Specify a Default Power Plan for All Users in Vista and Windows 7
Power Point - make a flashy disco slide show
A PowerPoint picture show that is a little different
Presentation Settings - Turn On or Off
How to Turn Presentation Settings On or Off in Vista
Preview Pane - Enable or Disable
How to Enable or Disable the Preview Pane in Vista
Preview Pane - Hide or Show Preview Handlers in Windows
How to Hide or Show Preview Handlers in Preview Pane in Windows
Preview Pane Size - Reset in Vista and Windows 7
How to Reset Preview Pane Size to Default in Vista and Windows 7
Preview Pane - Turn On or Off in Windows Explorer
How to Turn the Preview Pane On or Off in Vista
Previous Opened Folders Windows - Restore at Logon
Previous Versions - Hide or Show from Backup Location
How to Hide or Show Previous Versions of Files from a Backup Location
Previous Versions - Hide or Show from File Shares
How to Hide or Show Previous Versions of Files from File Shares
Previous Versions - Shadow Copy
How to Restore Previous Versions of a File and Folder in Vista
Previous Versions Tab - Restore or Remove from Properties
How to Restore or Remove "Previous Versions" Tab from Properties
Print and View File Directory - Add to Context Menu
How to Add "View and Print File Directory" to the Context Menu in Vista and Windows 7
Print - Open - Edit : Fix Missing in Context Menu when more than 15 Files are Selected
Print Spooler Queue - Clear and Reset
How to Clear and Reset the Print Spooler Queue in Vista, Windows 7, and Windows 8
Print to XPS File - Microsoft XPS Document Writer
Printer - "Add Printer" Wizard Shortcut - Create
How to Create a "Add Printer" Wizard Shortcut in Windows 7 and Vista
Printer - Connect to Wireless Router
How to Connect a Printer to a Wireless Router
Printer Migration Wizard Shortcut - Create
How to Create a "Printer Migration Wizard" Shortcut in Vista, Windows 7, and Windows 8
Printer Share - Setup for XP and Vista
How to Setup a Shared Printer for XP and Vista
Printers Shortcut - Create
How to Create a "Printers" Folder Shortcut in Windows 7 and Vista
Priority Level - Add or Remove "Run with Priority" for EXE Files
How to Add or Remove "Run with Priority" to Context Menu of EXE Files in Windows
Private Character Editor
How to Open and Use Private Character Editor in Vista, Windows 7, and Windows 8
Process - End Task in Vista and Windows 7
How to End a Process Task in Vista Windows 7
Process - See if running as administrator (elevated)
How to See if Process is running as administrator (elevated) in Vista and Windows 7
Processes - Add "Kill Not Responding Tasks" to Desktop Context Menu
How to Add "Kill Not Responding Tasks" to Desktop Context Menu in Windows
Processes and Applications - Open and Close in Task Manager
How to Open and Close a Application and Process in Vista Task Manager
Processor Affinity
How to Set the Processor Affinity for a Application in Vista
Processor Affinity - Add Set CPU Affinity to Context Menu
How to Add or Remove "Run with CPU Affinity" to the Context Menu
Processor Affinity Shortcut for a Program - Create in Windows
How to Create a Shortcut to Run an Application with a Set CPU Affinity in Windows
Processor - Determine if x64 (64-bit) Capable
Know if you can upgrade or install Windows Vista x64 Edition
Processor Priority Shortcut for a Program - Create in Windows
How to Create a Shortcut to Run an Application with a Specific CPU Priority in Windows
Processor Scheduling - Adjust for Performance in Windows
How to Adjust Processor Scheduling for Best Performance in Vista, Windows 7, and Windows 8
Processors - Change Number Used in Boot Advanced Options
How to Change the Number of Processors Used at Boot Up in Vista
Product Key - Clear from Registry in Windows
How to Clear Product Key from Registry in Windows
Product Key Number
How to See The Product Key in Vista
Product Key Number - Uninstall and Deactivate in Windows
How to Uninstall the Product Key Number and Deactivate Windows 7 and Vista
Program Access and Computer Defaults - Enable or Disable
How to Enable or Disable the "Set Program Access and Computer Defaults" Page
Program - Add to "Open with"
Program Associations - Set in Default Programs
How to Set Default Associations For a Program in Vista
Program - Clean Up and Remove from "Open with"
Program Compatibility Assistant - Enable or Disable
How to Enable or Disable Program Compatibility Assistant in Vista, Windows 7, and Windows 8
Program - Create Keyboard Shortcut to Open
How to Create a Keyboard Shortcut for a Program in Vista and Windows 7
Program - Desktop Composition - Disable
How to Disable Desktop Composition for a Program
Program - Elevated Shortcut without UAC Prompt - Create
How to Create a Elevated Program Shortcut without a UAC Prompt
Program, File, Folder, or Drive - Create Shortcut of in Windows
How to Create a Shortcut of a File, Folder, Drive, or Program in Vista, Windows 7, and Windows 8
Program Installation "Temp Folder" Error - Fix
Program - Pin to Start Menu
How to Pin a Program to the Start Menu in Vista
Program - Remove from List in Default Programs
How to Remove a Listed Program in Default Programs for Windows 7 and Vista
Program - "Run as Different User" Shortcut - Create for Specified Program and User
How to Create a Shortcut to Run a Program as a Specified User
Program Shortcut- Add to Desktop Context Menu
How to Add an Application Shortcut to the Desktop Context Menu
Program - Turn DEP On or Off for
How Turn DEP On or Off for a Program in Vista
Program - Unable To Install Latest Version of in Vista
Install/Uninstall Problems with Vista
Program - Uninstall or Change
How to Uninstall or Change a Program in Vista
Programs and Documents - Run at User Logon
Programs and Features - Disable or Enable
How to Disable or Enable Programs and Features in Vista
Programs and Features - Restore Uninstall Confirmation Prompt
How to Restore the Uninstall Confirmation Prompt in Vista Programs and Features
Programs and Features - Remove Uninstall Entry
How to Remove an Uninstall Entry in Programs and Features for Vista, Windows 7, and Windows 8
Programs - Compatibility Mode
How to Use Compatibilty Mode in Vista
Programs - Compatibility Mode List of Programs
How to See and Change the List of Programs in Compatibility Mode in Vista
Programs - Prevent Running Specified Applications
How to Prevent Users from Running Specified Programs in Windows
Programs - Replace System Program without Modifying System Files or Permissions
How to Replace a System Program without Modifying System Files or Permissions
Programs - Run Only Specified Applications in Windows
How to Allow Users to Run Only Specified Programs in Windows
Programs - Uninstall using Command Prompt in Windows
How to Uninstall Programs using Command Prompt in Windows
PSU - Jump Start
How to Jump Start a Power Supply to Create a Test PSU
PSU - Test DC Output Voltage
How to Test PSU DC Output Voltages to Determine if Faulty
Public Folder - Add or Remove from the Desktop
How to Add or Remove the Public Folder Desktop Icon in Vista
Public Folder Icons - Restore Default Icon
How to Fix a Public Folder Displayed as a Standard Yellow Folder Icon in Vista
Public Folder Sharing - Turn On or Off
How to Turn Public Folder Sharing On or Off in Vista
A - B - C - D - E - F - G - H - I - J - K - L - M - N - O - P - Q - R - S - T - U - V - W - X - Y - Z
Q:
Quick Launch
How to Use Quick Launch in Vista
Quick Launch - Add to "Send to" Context Menu in Windows 8
How to Add Quick Launch to the "Send to" Context Menu in Vista, Windows 7, and Windows 8
Quick Launch - Icon Size
How to Change the Quick Launch Icon Size in Vista
Quota Entries for Disk - Export and Import
How to Export and Import User Disk Quota Entries in Windows
Quota for Disk - Set Space Limits for Users
How to Set Disk Quota Limits for Users in Windows
R:
Raid Install
Simple solution to avoid the common raid boot error
RAM Disk - Install for Browser Cache File Storage
How to Install a RAM Disk for Browser Cache File Storage
Read-only - Add "List Read-only Files" to Context Menu
How to Add "List Read-only Files" to Context Menu in Vista, Windows 7, and Windows 8
Read-only File and Folder Attribute
How to Set and Unset the Read-only File and Folder Attribute in Vista
Read-only for Disk - Enable or Disable in Windows
How to Enable or Disable Write Protection for a Disk Drive in Windows
ReadyBoost
How to Use ReadyBoost in Vista
Recent Items - Change Maximum Number to Display in Start Menu
How to Change the Maximum Number of Recent Items to Display in Start Menu
Recent Items - Clear Document History on Exit
How to Enable or Disable Clear Recent Document Items History on Exit of Vista
Recent Items - Enable or Disable
How to Enable or Disable Recent Items in Vista, Windows 7, and Windows 8
Recent Items List - Clear History
How to Clear the Recent Items List History in Vista
Recent Items List - Turn On or Off
How to Turn the Recent Items List On or Off in Vista
Recent Programs - Change Amount Displayed in Start Menu
How to Change the Number of Recent Programs to Display in the Vista Start Menu
Recent Programs Not Being Remembered - Fix
How to Fix Recent Programs Not Being Remembered in Vista
Recovery Disc - Create for Vista
How to Create a Vista Recovery Disc
Recycle Bin - Fix Icon Not Refreshing
How to Fix the Recycle Bin Icon Not Refreshing When Emptied
Recycle Bin - Add Program to Context Menu
How to Customize the Recycle Bin Context Menu in Vista
Recycle Bin - Add to Favorites in Navigation Pane
How to Add or Remove Recycle Bin from Favorites in Navigation Pane in Windows
Recycle Bin confirmation
How to Enable or Disable the Recycle Bin Delete Confirmation Dialog in Vista
Recycle Bin Corrupted - Cannot Delete File or Folder
How to Fix a Corrupted Recycle Bin in Vista and Windows 7
Recycle Bin Delete Confirmation Dialog Prompt Details - Customize in Windows
How to Customize Delete Confirmation Dialog Prompt Details in Windows
Recycle Bin delete immediately
How to Set Recycle Bin to Permanently Delete a Item Immediately in Vista
Recycle Bin Icon - Allow or Prevent to Display
How to Allow or Prevent the Vista Recycle Bin Icon to Display
Recycle Bin Properties - Add or Remove
How to Add or Remove "Properties" from Recycle Bin Context Menu
Recycle Bin - Replace "Delete" in Context Menu
How to Replace Delete in the Recycle Bin Context Menu in Vista
Recycle Bin - Restore
How to Restore the Recycle Bin back to the Desktop in Vista
Recycle Bin Storage Size - Change
How to Change the Recycle Bin Storage Size in Vista and Windows 7
Reduced Functionality Mode
Your Activation Period has Expired
Regedit - Enable or Disable
How to Enable or Disable Regedit in Vista and Windows 7
Region and Language - "Administrative" Tab - Add or Remove
How to Add or Remove the "Administrative" Tab in Region and Language
Region and Language - "Formats" Tab - Add or Remove
How to Add or Remove the "Formats" Tab in Region and Language
Region and Language - "Location" Tab - Add or Remove
Register and Unregister Context Menu for DLL and OCX Files
Registered Owner and Organization - Change
Registry - Backup and Restore
How to Backup and Restore the Registry in Windows 7 and Vista
Registry Cleaner program slow
How to Fix a Slow Scan in a Registry Cleaner Program in 64 bit Vista
Registry Editing
How to Use the Registry Editor in Vista and other Techniques
Registry Editor - Add to Control Panel
How to Add or Remove "Registry Editor" from the Vista and Windows 7 Control Panel
Registry Editor - Find and Find Next
How to Use "Find and Find Next" in Registry Editor in Vista, Windows 7, and Windows 8
Registry Favorites - Add or Remove in Windows
How to Add, Remove, Export, and Merge Registry Favorites in Windows
Registry File - Add to "New" Context Menu
Registry Key, File, Folder, or Drive - Take Ownership of
How to Take Ownership of a Item in Vista and Windows 7
Reliabilty Monitor
How to Troubleshoot the Computer with Reliability Monitor in Vista
Reliability Monitor - Reset
How to Reset Reliability Monitor in Vista
Remote Assistance
How to Use Windows Remote Assistance in Vista
Remote Assistance - Enable or Disable
How to Enable or Disable Windows Remote Assistance in Vista
Remote Computer Clients - Uninstall Product Key Number and Deactivate Windows
How to Uninstall the Product Key Number or Deactivate Windows 7 and Vista
Remote Desktop Connection Automatic Log On - Allow or Prevent
Allow or Prevent Remote Desktop Connection Clients to Automatically Log On to Host Computer
Remote Desktop Connection Automatic Log On - Turn On or Off
How to Turn On or Off Automatic Log On for a Remote Desktop Connection
Remote Desktop Connection Shortcut - Create for Specific Computer
How to Create a "Remote Desktop Connection" Shortcut to a Specific Computer
Remote Desktop - Set Time Limit for Active Sessions
How to Set Time Limit for Active Remote Desktop Sessions
Remote Desktop - Set Time Limit for Idle Sessions
How to Set Time Limit for Idle Remote Desktop Sessions
Remote Desktop - Terminate Session when Time Limits are Reached
How to Terminate Remote Desktop Session when Active or Idle Time Limits are Reached
Remote Server Administration Tools for Windows
Download Remote Server Administration Tools (RSAT) for Windows
Remote System Properties Shortcut - Create
Create a "Remote System Properties" Shortcut in Vista, Windows 7, and Windows 8
Remote Shutdown Dialog Shortcut - Create
How to Create a "Remote Shutdown Dialog" Shortcut
Removable Drives - Allow or Deny All Access
How to Deny or Allow Access to All Removable Drives in Vista and Windows 7
Removable Hard Disk Drives - Allow or Deny Read and Write Access
How to Deny or Allow Read and Write Access to Removable Hard Drives in Vista and Windows 7
Removable Media Shortcuts - Place On Desktop
How To Place Removable Media Shortcuts On the Vista Desktop
Remove Background Images (where available)
How to Remove Background Images to have Only Solid Colors in Vista and Windows 7
Repair Install For Vista
How To Perform a Repair Installation For Vista
Repair Vista Options - Preferred Sequence
What To Do When Vista No Longer Works For You
Reset User Account Password
Resource Monitor
How to Use the Resource Monitor in Vista
Restart - Add to Desktop Context Menu
How to Add "Restart" Computer to the Desktop Context Menu in Windows 7
Restart Automatically on System Failure - Enable or Disable
How to Enable or Disable Automatic Restart on System Failure in Windows
Restart Computer - Allow or Prevent Users and Groups
How to Allow or Prevent Users and Groups to Hibernate, Restart, Shut Down, and Sleep the PC
Restart Computer - Create Shortcut
How to Create a Restart Computer Shortcut in Vista
Restart Explorer
How to Restart Explorer in Vista
Restore Backup Files
How to Restore Backup Files in Vista
Restore Complete Computer
How to Restore the Complete Computer from a Complete Backup and Restore Image in Vista
Restore Files from Selected Backup Location - Create Shortcut
How to Create a "Restore Files from Selected Backup Location" Shortcut
Restore Point - Add "Create Restore Point" to Context Menu in Windows
How to Add "Create Restore Point" to Context Menu in XP, Vista, Windows 7, and Windows 8
Restore Point Automatic Creation - Disable in Windows
How to Enable or Disable Automatic System Restore Point Creation in Windows
Restore Points - Manually Extract Files and Folders
How to Extract Files and Folders from System Restore Points in Windows 7 and Vista
Restore Previous Opened Folders Windows at Logon
How to Restore Previous Opened Folder Windows at Logon in Vista
Restore Previous Versions - Add or Remove from Context Menu
How to Add or Remove "Restore Previous Versions" from Context Menu
Ribbons Screen Saver - Customize Settings
How to Customize the "Ribbons" Screen Saver Settings
RocketDock - Bypassing 'Show Desktop' bug
RSS Feeds - Import and Export in Internet Explorer
How to Import and Export RSS Feeds in Internet Explorer
RSS Feeds - Setup Windows Media Center to Read
RSS Feeds - Subscribe or Unsubscribe in Internet Explorer
How to Subscribe or Unsubscribe to a RSS Feed in Internet Explorer
How to use and subscribe to RSS feeds
Run as Administrator - Add or Remove from Context Menu in Vista
How to Add or Remove "Run as Administrator" from Context Menu in Vista
Run as administrator - Add to MSI File Context Menu
Run as administrator - Add to VBS File Context Menu
How to Add "Run as administrator" to VBS File Context Menu
Run as administrator - See if Process is Running Elevated
Run "Auto Suggest" History - Delete in Windows
How to Delete your Run Dialog Auto Suggest History in Windows
Run Command - Enable or Disable
How to Enable or Disable Run Command Box in Windows 7 and Vista
Run Commands for Vista
A List of Run Commands
Run Command - Turn On or Off
How to Turn On or Off the Run Command Window in Vista
S:
Safe Mode
How to Start Vista in Safe Mode
SafeHouse Explorer - Create Password Protected USB
How to Create Password Protected USB Flash Drive with SafeHouse Explorer
Safely Remove Hardware - Add to Desktop Context Menu
How to Add "Safely Remove Hardware" to the Desktop Context Menu
Safely Remove Hardware - Create Shortcut
How to Create a "Safely Remove Hardware" Shortcut in Vista
Save As and Open Common Item Dialog Boxes - Reset in Windows
Scan and Fix Removable Disk Prompt - Disable in Windows
How to Disable "Do you want to scan and fix Removable Drive" Prompt in Windows
"Scan with Microsoft Security Essentials" - Add or Remove Context Menu
Scanner Use with Vista
How to Use a Scanner with Vista
Screen Refresh Rate
How to Change the Screen Refresh Rate in Vista
How to Change the Screen Resolution in Vista
Screen Saver
How to Use and Change a Screen Saver in Vista
Screen Saver - Add or Remove Option
How to Add or Remove the Screen Saver Option in Vista
Screen Saver - Customize "Aurora" Settings
How to Customize the Vista Aurora Screen Saver Settings
Screen Saver - Customize "Bubbles" Settings
How to Customize the Vista Bubbles Screen Saver Settings
Screen Saver - Customize "Mystify" Settings
Screen Saver - Customize "Ribbons" Settings
How to Enable or Disable Screen Savers in Vista, Windows 7, and Windows 8
Screen Saver Grace Period to Bypass Password - Change in Windows
How to Change Screen Saver Grace Period to Bypass Password Protection in Windows
Screen Saver at Log On - Change
Screen Saver at Log On - Enable or Disable
Screen Saver Settings Shortcut - Create
How to Create a "Screen Saver Settings" Shortcut in Vista, Windows 7, and Windows 8
Screen Saver Shortcut - Create in Windows
How to Create a Screen Saver Shortcut in Vista, Windows 7, and Windows 8
Screen Saver - Specify Default
How to Specify a Default Screen Saver for All Users in Vista
Screen Saver - Toggle On or Off - Add to Desktop Context Menu
How to Add "Enable/Disable Screen Saver" to Desktop Context Menu
Screenshots and Files - Upload and Post in Vista Forums
How to Upload and Post a Screenshot and File in Vista Forums
Scroll Lock - Num Lock - Caps Lock - Enable or Disable at Windows Startup
Search - Add or Remove from "My Computer" Context Menu
Search - Advanced Search Options
How to Use Advanced Search Options in Vista
Search - Advanced Searches
How to Use the Advanced Query Language to Improve Windows Search Results
"Search" Context Menu Item - Restore After Vista SP1
How to Restore the "Search" Context Menu Item after Installing the Vista SP1
Search Desktop Shortcut
How to Create a "Search Desktop" Shortcut on Vista
Search - Have More Accurate Search Results
How to Have More Accurate Search Results in Windows 7 and Vista
Search Index - Enable or Disable
How to Enable or Disable the Search Index in Vista and Windows 7
Search Index - "Windows Search" Service
How to Fix the Start Error For Windows Search Service to Enable the Index in Vista
Search Indexing Options
How to Use the Indexing Options in Vista
Search Options
How to Open and Change Search Options in Vista
Search Start Menu Button - Restore after SP1
How to Restore the Start Menu Search Button after Installing the Vista SP1
SeaTools for DOS and Windows - How to Use
How to Use SeaTools for DOS and Windows Disc Check Utility
Secure CTRL+ALT+DELETE Logon - Enable or Disable
How to Enable or Disable CTRL+ALT+DELETE Secure Logon in Vista
Security Center Alert Warning Notification - Enable or Disable
How to Disable or Enable the Security Center Alert Warning Notification in Vista
Security Center - Enable or Disable
How to Disable or Enable Security Center in Vista
Security Center - Not Reporting Correct Information
How to Fix the Vista Security Center Reporting Incorrect Information
Security Center Specific Alert Notification
How to Disable or Enable a Specific Security Center Alert Notification in Vista
Security Properties Tab - Restore or Remove
How to Restore or Remove the "Security" Tab in Vista
Select all - Add to Context Menu in Vista
How to Add "Select all" to the Context Menu in Vista
Select Files - Disable or Enable Full Row Select
How to Enable or Disable Full Row Select in Vista Windows Explorer
Select Files using Check Boxes
How to Select Files Using a Check Box in Vista Windows Explorer
Select more then 15 Items - Fix Missing Context Menu Items
Select Multiple Files Fix
Cannot Select Multiple Files and Folders Fix for Vista
Send To - Add or Remove from Context Menu in Vista
How to Add or Remove "Send To" from the Context Menu in Vista
Send To Context Menu
How to Customize the Send To Context Menu in Vista and Windows 7
Send To Context Menu - Add "Google Drive"
How to Add Google Drive to "Send To" Context Menu in Windows
Send To Context Menu - Add "Quick Launch" to in Windows 8
Send To Context Menu - Customize
How to Customize the Send To Context Menu in Vista, Windows 7, and Windows 8
Send To Context Menu - Remove or Show Drives
How to Remove or Show Drives in "Send To" Context Menu in Vista, Windows 7, and Windows 8
Send To Context Menu - Restore Default Menu Items
How to Restore Missing Default Send To Context Menu Items in Vista
Services
How to Disable or Enable Vista Services with an Advice Guide
Services - Add or Remove from Control Panel
How to Add or Remove "Services" from Control Panel in Windows
Services - Customize View of Window
How to Customize and Save the View in the Services Window in Vista
Services - Delete
How to Delete a Service in Vista and Windows 7
Services MMC Snap-in - Enable or Disable
How to Enable or Disable the "Services" MMC Snap-in
Set Program Access and Computer Defaults - Enable or Disable
Shadow Copies - Delete
How to Delete Shadow Copies in Vista and Windows 7
ShadowExplorer - Recover Lost Files and Folders
How to Recover Lost Files and Folders with ShadowExplorer
Shared Folders Shortcut - Create in Windows
How to Create a Shared Folders Shortcut in Vista, Windows 7, and Windows 8
Shared Printer Setting Up for XP, Vista, and Windows 7
Sharing Public Folders - Turn On or Off
Shell Command
How to Use the Vista Shell Command
Shortcut Arrow - Change or Remove
How to Remove or Change the Shortcut Arrow in Vista
Shortcut - Create Custom Comment Pop-up Description in Windows
How to Create a Custom Shortcut Comment Pop-up Description in Windows
Shortcut - Create for a File, Folder, Drive, or Program in Windows
Shortcut - Default Open Window Size
How to Change the Default Open Window Size for a Shortcut in Vista
Shortcut - Fix "New Shortcut"
Shortcut Folder and File Icon - Change
How to Change a Shortcut Folder or File Icon in Vista
Shortcut Icon - Change in Windows
How to Change the Icon of a Shortcut in Vista, Windows 7, and Windows 8
Shortcut - Open Normal window, Minimized, or Maximized
"Shortcut" Prefix Name - Change
How to Remove the "Shortcut" Prefix On the Shortcut Name in Vista
Shortcut - Target Path Location - Change
How to Change the Target Path Location of a Shortcut in Vista
Shortcut Tooltip Details - Customize in Windows
How to Customize Details of Shortcut Tooltips in Windows
Show Desktop
How to Create a "Show Desktop" Shortcut in Vista
Show Desktop - Bypassing bug in RocketDock
Show - Hide Hidden Files - Add to Context Menu
How to Add "Show/Hide Hidden Files" to Context Menu in Vista and Windows 7
Show - Hide Known File Extensions - Add to Context Menu
How to Add "Show/Hide Known File Extensions" to Context Menu in Vista and Windows 7
Show Translucent Selection Rectangle - Enable or Disable
How to Enable or Disable the Translucent Selection Rectangle in Vista
Show Window Contents or Outline While Dragging
Show Window Contents or Outline While Dragging in Vista, Windows 7, and Windows 8
"Show Windows Stacked" or "Show Windows Side by Side" - Create Shortcuts
How to Create a Shortcut for "Show Windows Stacked" or "Show Windows Side by Side"
Shut Down - Add to Desktop Context Menu
How to Add "Shut Down" Computer to the Desktop Context Menu in Vista and Windows 7
Shutdown - Speed up Time
How to Speed Up Shutdown in Vista
Shut Down Computer - Allow or Prevent Users and Groups
How to Allow or Prevent Users and Groups to Shut Down the Computer
Shutdown, Logon, and Logoff - Detailed Status Messages
Shutdown Options at Log On - Remove or Restore
Shutdown Options - Start Menu
How to Remove or Show the Start Menu Shutdown Options in Vista
Shutdown shortcut
How to Create a "Shutdown Computer" Shortcut in Vista
Shut Down - View Details of Last Shutdown of Computer
How to See the Last Shutdown Time of Your Windows PC
Shutdown Vista from the Keyboard
"Shutting down..." Text Message - Change
How to Change the "Shutting down..." Text Message at Shut Down in Windows 7 and Vista
SID (Security Identifier) of User - Find in Windows
How to Find Security Identifier (SID) of User in Windows
Simple File Sharing - Enable
How to Enable Simple File Sharing in Vista
Single Click to Open a Item
"SkyDrive" is now called "OneDrive"
Sleep - Remove in Shutdown Menu
How to Disable All Sleep Modes in Vista
Sleep Shortcut - Create
How to Create a "Sleep Shortcut" on the Desktop in Vista
Sleep shortcut simplified - Create
Sleep States - See Available Sleep States
Sliptream Office 2010 with Service Pack 1
Slipstream Vista SP1 - Create Installation DVD
How to Create a Vista SP1 Slipstream Installation DVD
Slipstream Vista SP2
How to Slipstream Vista SP2
Smooth Edges of Screen Fonts - Enable or Disable
How to Enable or Disable "Smooth Edges of Screen Fonts"
"Snap to" - Mouse Pointer - Turn On or Off
SnapShot Sound for PrintScreen Key - Add or Remove in Windows
How to Add or Remove SnapShot Sound for PrintScreen Key in Windows
Snipping Tool
How to use the Snipping Tool in Vista
Solid Colors - Remove Background Images (where available)
Sort Order - Numbers in File and Folder Names
How to Change the Sort Order for Numbers in File and Folder Names in Vista
Sound Recorder - Enable or Disable
How to Enable or Disable Sound Recorder in Vista
Sound Scheme
How to Change a Computer Event Sound in Vista
SP1 Disk Cleanup Tool
How to Use the Vista SP1 Disk Cleanup Tool
SP1 Hibernation Error: "System was shut down unexpectantly"
Fix Boot Configuration Data (BCD) store contains incorrect information for the Resume from Hibernate entry
SP1 Uninstall
How to Uninstall the Vista SP1
SP2 Disk Cleanup Tool
How to Use the Vista SP2 Disk Cleanup Tool
SP2 Prerelease Version - Uninstall
How to Uninstall the Vista SP2 Prerelease Evaluation Version
Speccy - Advanced System Information Tool
How to Use Speccy to View Your System Information in Windows
Speech Recognition - Language Configuration is Not Supported Error Fix
How to Fix the Speech Recognition "Language Configuration is Not Supported" Error
Speed Up Vista Boot Time
How to Speed Up Vista Boot Up Time
Speed Up the Performance of Vista
How to Speed Up the Performance of Vista
Start Menu All Programs List - Enable or Disable
How to Enable or Disable Start Menu "All Programs" in the Vista and Windows 7
Start Menu - All Programs Shortcuts - Add or Delete
How to Add or Delete a Shortcut or Folder From the Start Menu "All Programs" in Vista
Start Menu and Case - Change Action of Power Button
Start Menu and Taskbar Properties - Enable or Disable
How to Enable or Disable "Taskbar and Start Menu Properties" in Vista and Windows 7
Start Menu Auto Arrange by Name - Enable or Disable
How to Enable or Disable Start Menu Auto Arrange by Name in Vista and Windows 7
Start Menu - Backup and Restore Pinned Items in Vista
How to Backup and Restore Pinned Start Menu Items in Vista
Start Menu - Change Descriptive Text Pop-up Information
Start Menu - Change Maximum Number of Recent Items to Display
Start Menu Classic View
How to Change the Start Menu to Classic View in Vista
Start Menu - Context Menus and Dragging and Dropping - Disable or Enable
How to Disable or Enable Context Menus and Dragging and Dropping in the Start Menu
Start Menu - Customize
How to Customize the Start Menu in Vista
Start Menu - Customize Context Menu
How to Customize the Start Menu Context Menu in Vista
Start Menu - "Help and Support" - Add or Remove
How to Add or Remove "Help and Support" from the Normal and Classic Vista Start Menu
Start Menu - Highlight Newly Installed Programs
How to Enable or Disable "Highlight Newly Installed Programs" in Vista Start Menu
Start Menu - Lock and Switch User - Add or Remove
How to Add or Remove Lock and Switch User from the Start Menu in Vista
Start Menu - Pin Folder To - Enable
How to Pin a Folder to the Start Menu in Vista
Start Menu - Pin Program to
Start Menu - Pin to Start Menu - Enable or Disable
How to Enable or Disable Pin to Start Menu in Vista and Windows 7
Start Menu - "Pin to Start Menu" Missing from Context Menu Fix
Start Menu Power Button
Start Menu Properties Shortcut - Create
How to Create a "Start Menu Properties" Shortcut in Windows 7 and Vista
Start Menu - Recent Programs - Change Amount Displayed
Start Menu - Reset Pin To Area
How to Reset the Pin To Start Menu Area in Vista
Start Menu - Restore Missing Default Shortcuts
How to Restore Missing Default Start Menu Shortcuts in Vista
Start Menu Shortcut Program
Download a Shortcut that Opens the Start Menu in Windows
Start Menu - Small or Large Icons
How to Display Small or Large Icons in the Vista Start Menu
Start Menu - "Switch User" - Add or Remove
How to Add or Remove "Switch User" from the Start Menu in Vista
Startup Orb - Change
How To Change the Vista Startup Orb
Startup Programs - Enable or Disable
How to Check and Change the Startup Programs in Vista
Startup Repair
How to Do a Startup Repair in Vista
Startup Sound - Change in Vista
How to Change the Startup Sound in Vista
Startup Sound - Enable or Disable
How to Enable or Disable the Startup Sound in Vista and Windows 7
Status Messages - Verbose or Normal Logon, Logoff, and Shutdown
Enable or Disable Detailed Verbose Logon, Logoff, Startup, and Shutdown Status Messages in Vista and Windows 7
Sticky Keys - Turn On or Off
How to Turn Sticky Keys On or Off in Vista
Sticky Notes
How to Use Sticky Notes in Vista
Stop Errors - Troubleshooting Specific Stop Errors
Details on how to help narrow down specific stop errors
Stored User Names and Passwords - Manage
Superfetch (Memory Prefetcher)
How to Disable or Enable Superfetch in Vista
Superfetch - Change Preload Data
How to Change What Superfetch will Preload in Vista
Support Information
Switch User Desktop Shortcut - Create
How to Create a "Switch User" Desktop Shortcut in Vista
Sync Center - Disable Mobsync.exe
How to Disable Sync Center Mobsync.exe in Vista
SyncToy - Backup User Data
How to Use SyncToy for Data Backups
Synergy - One mouse & keyboard to control up to 15 computers
How to Use One Mouse & Keyboard on up to 15 PCs using Synergy without Additional Hardware
SysInfo Tool
VistaForums SysInfo Tool
SysKey - Create USB Key to Lock or Unlock Windows
How to Create a USB Startup Key to Lock or Unlock Windows
SysKey - Set Startup Password to Lock or Unlock Windows
System Configuration - Add or Remove from Control Panel
System Configuration (msconfig) Shortcuts - Create
System Configuration - Restore Restart Prompt
How to Restore the System Configuration Restart Prompt in Vista
System Failure Automatic Restart - Enable or Disable
System File Checker - SFC Command
How to Repair and Verify the Integrity of Vista System Files with System File Checker
System Health Report - Generate
How to Generate a System Health Report in Vista and Windows 7
System Image Backup of Complete Computer
How to Create a Complete Computer Backup and Restore Image in Vista
System Image - Extract Files Using Virtual PC 2007
How to Extract Vista System Image Files Using Virtual PC 2007
System Information
How to See System Information in Vista and Windows 7
System Information File - Create in Windows
How to Create a System Information File in Windows
System Performance Report - Generate and View in Windows
How to Generate and View a System Performance Report in Windows
System Properties - Add to Start Menu "Computer" Context Menu
How to Add "System Properties" to Start Menu "Computer" Context Menu in Vista
"System Protection Properties" Shortcut - Create
Create a "System Protection Properties" Shortcut in Vista, Windows 7, and Windows 8
System Recovery Options
How to Boot to the System Recovery Options in Vista
System Restore - Turn On or Off
How to Turn System Restore On or Off in Vista
System Restore - Disk Space Usage - Change
How to Change the System Restore Disk Space Usage Amount in Vista
System Restore - How to
How to Do a System Restore in Vista
System Restore Point - Add "Create Restore Point" to Context Menu in Windows
System Restore Point Automatic Creation - Disable in Windows
System Restore Point - Create
How to Create a System Restore Point in Vista
System Restore Point - Disable for Application Install
How to Enable or Disable Create Vista System Restore Point when a Application is Installed
System Restore Point - Disable for Device Driver Install
How to Enable or Disable Create Vista System Restore Point when New Device Driver is Installed
System Restore Point - Shortcut
How to Make a "Create System Restore Point" Shortcut in Vista
System Restore Points - Manually Extract Files and Folders
System Restore Points - Stop XP Dual Boot Delete
How to Stop System Restore Points from being Deleted in Vista when Dual Booting with XP
System Restore Shortcut
How to Create a System Restore Shortcut in Vista
System Restore Task - Change Automatic Restore Point Schedule
How to Change the Automatic System Restore Point Settings in Vista Task Scheduler
System Restore - Undo
How to Undo the Last System Restore in Vista
System Uptime
How to See What the System Uptime is in Vista
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
T:
"Take Ownership" - Add to Context Menu
How to Add "Take Ownership" to the Context Menu in Vista
Take Ownership - Allow or Prevent Users and Groups To
How to Allow or Prevent Users and Groups to Take Ownership
Take Ownership of a File, Folder, Drive, or Registry Key
Tape Drives - Allow or Deny Read and Write Access
How to Deny or Allow Read and Write Access to Tape Drives in Vista and Windows 7
Task - End Process in Vista and Windows 7
Task Manager - Always On Top
How to Turn On or Off Vista Task Manager Always On Top
Task Manager - Columns - Add or Remove
How to Add or Remove Columns in Windows Task Manager
Task Manager - Elevated Shortcut - Create
How to Create a "Elevated Task Manager" Shortcut
Task Manager - Enable or Disable
How to Enable or Disable Task Manager in Vista and Windows 7
Task Manager - Open and Close Applications and Processes
Task Manager - See if Process is Running as administrator (elevated)
Task Manager - Small Footprint Mode
How to Switch Between Normal and Small Footprint Mode in Vista and Windows 7 Task Manager
Task Manager - Users - Disconnect Network User Connection
Task Manager - Users - Log Off a Local User
How to Log Off a Local User in Vista and Windows 7
Task Manager - Users - Send Message to a User
How to Send a Message to Another User in Vista and Windows 7
Task Scheduler - Create Elevated Program Shortcut without UAC Prompt
Task Scheduler - Create Task
How to Create a Task in Vista Task Scheduler
Task Scheduler - Create Task to Display a Message Reminder
How to Display a Message Reminder in Windows with Task Scheduler
Task Scheduler - Create Task to Wake Up Computer
Taskbar - Always On Top - Enable or Disable
How to Enable or Disable Taskbar Always on Top in Vista
Taskbar and Start Menu Properties - Enable or Disable
How to Enable or Disable the Taskbar and Start Menu Properties Window in Vista
Taskbar - Auto-hide - Turn On or Off
How to Turn Taskbar Auto-hide On or Off in Vista
Taskbar Button - Show or Hide Folder Full Path
How to Show or Hide Folder Full Path in the Vista Taskbar Buttons
Taskbar - Context Menus - Enable or Disable
How to Enable or Disable the Vista Taskbar Context Menus
Taskbar - Group Similar Buttons
How to Turn Group Similar Taskbar Buttons On or Off in Vista
Taskbar Icons
How to Replace the Vista Taskbar Buttons with Icons
Taskbar - Lock - Enable or Disable
How to Enable or Disable Lock the Taskbar in Vista
Taskbar - Lock or Unlock
How to Lock or Unlock the Taskbar in Vista
Taskbar - Notification Area Balloon Tips - Enable or Disable
Taskbar - Notification Area Icons - Reset
Taskbar - Notification Area - System Icons - Hide All
Taskbar - Notification Area - System Icons - Enable or Disable
Taskbar - Notification Dialog Boxes - Time to Stay Open - Change
Taskbar - Notification Icons - Customize - Hide or Show
Taskbar - Resize
How to Resize the Taskbar in Vista and Windows 7
Taskbar - Resize - Enable or Disable
How to Enable or Disable Resizing the Taskbar in Vista and Windows 7
Taskbar Thumbnail Previews - Enable or Disable
How to Enable or Disable the Taskbar Thumbnail Previews in Vista
Taskbar Thumbnail Previews - Turn On or Off
How to Turn Open Window Thumbnail Previews On or Off for the Taskbar in Vista
Taskbar Toolbars
How to Add or Remove a Toolbar on the Taskbar in Vista
Taskbar Toolbars - Backup and Restore
How to Backup and Restore Taskbar Toolbars in Vista and Windows 7
Taskbar Toolbars - Disable Adding or Removing
How to Enable or Disable Adding and Removing Taskbar Toolbars in Vista and Windows 7
Taskbar Toolbars - Enable or Disable
How to Enable or Disable Taskbar Toolbars in Vista and Windows 7
Taskbar Toolbars - Reset and Clear in Vista and Windows 7
How to Reset and Clear All Taskbar Toolbars in Vista and Windows 7
TCP Chimney Offload State - Enable or Disable
How to Enable or Disable the Chimney Offload State in Vista
TCP/IP Receive Level Auto Tuning- Enable or Disable
How to Enable or Disable the Receive Window Auto Tuning Level in Vista
Temporary Files Folder - Change Location in Windows
How to Change Default Location of Temporary Files Folder in Vista, Windows 7, and Windows 8
Temporary Files - Temp Folder - Clear
How to Clear Vista Temporary Files in the Temp Folder
Temporary Internet Files of Internet Explorer - Browse
How to Browse the "Temporary Internet Files" of Internet Explorer
Temporary Internet Files of Internet Explorer - Disk Space Usage
How to Change Disk Space to be Used by Internet Explorer "Temporary Internet Files"
The User Profile Service failed the logon. User profile cannot be loaded.
How to Fix this Error in Vista and Windows 7
Theme - Add or Remove Option
How to Add or Remove the Theme Option in Vista
Theme Settings - Change
How to Change the Desktop Theme in Vista
Thumbnail Cache - Clear
How to Clear the Thumbnail Cache in Vista
Thumbnail Cache - Enable or Disable
How to Enable or Disable the Thumbnail Cache in Windows
Thumbnail Cache - Prevent Windows from Deleting
How to Stop and Prevent Windows from Deleting the Thumbnail Cache
Thumbnail Previews - Change Border
How to Change the Border for Thumbnail Previews in Vista
Thumbnail Previews - Windows Explorer - Turn On or Off
How to Turn Preview Thumbnails On or Off in Windows Explorer in Vista
Thumbnails - Enable or Disable - Add to Context Menu
How to Add "Enable/Disable Thumbnails" to Context Menu in Vista, Windows 7, and Windows 8
Time and Date - Additional Clocks
How to Add Additional Time Zone Clocks in Vista and Windows 7
Time and Date - Additional Clocks Shortcut - Create
How to Create a "Additional Clocks" Shortcut in Windows 7 and Vista
Time and Date - Allow or Prevent Users and Groups from Changing
How to Allow or Prevent Specific Users and Groups from Changing the Date and Time
Time and Date - Change
How to Change the Date and Time in Vista
Time and Date - View
How to See the Date and Time on the Taskbar in Vista
"Time and Date" Shortcut - Create
How to Create a "Date and Time" Shortcut in Windows 7 and Vista
Time - 24 Hour Military Time
How to Set the Clock to Military 24 Hour Time in Vista
Time Limits - Parental Controls
Time Zone
How to Change the Time Zone in Vista
Time Zone - Allow or Prevent Users and Groups from Changing
How to Allow or Prevent Specific Users and Groups from Changing the Time Zone
Time Zone - Restore Missing Time Zones
How to Restore Missing Default Time Zones in Vista
Toggle Keys at Startup - Enable or Disable
Toggle Keys - Beep Alert - Turn On or Off
How to Turn the Toggle Keys Beep Alert On or Off in Vista
Toolbar for the Desktop
How to Add or Remove a Desktop Toolbar in Vista
Toolbars - How to Use in Windows 7 and Vista
How to Use Toolbars in Windows 7 and Vista
Touchpad PalmCheck - Turn On or Off in Windows
How to Turn PalmCheck On or Off for Touchpad in Windows
Transient Multimon Manager (TMM) - Enable or Disable
How to Disable or Enable the Transient Multimon Manager (TMM) in Vista
Transparency - Enable or Disable Aero Glass
How to Enable or Disable Aero Glass Transparency in Vista
Troubleshoot Application Conflicts by Performing a Clean Startup
How to Troubleshoot a Problem by Performing a Clean Startup in Windows 7 or Vista
Trusted Platform Module (TPM) Chip - Verify on Windows PC
How to Check if Windows PC has a Trusted Platform Module (TPM) Chip
TrustedInstaller - Restore as Owner
How to Restore TrustedInstaller as Owner of a File in Vista and Windows 7
Turn Off All Unnecessary Animations
How to "Turn off all unnecessary animations" in Windows 7 and Vista
"Two-step Verification" - Turn On or Off for your Microsoft Account
How to Turn "Two-step Verification" On or Off for your Microsoft Account
Status
Not open for further replies.
