trying to add hard drive. help please
krashx17
i have been searching everywhere and need some help. i have an older maxtor 250gb ide hard drive and i am trying to put it in my computer so i can reformat it and install vista ultimate, the thing is when i go to disk manager i can see the drve, feel the drive, but it wont let me initialize it or anything, it comes up as "the request could not be performed because of an I/O devise error, the disk was originally in my modded xbox and i could acces it with xp. please help as i have 1 gig left on my seagate 600g and i need more room. thanks in advance
I just put an old IDE HD in an old computer to install Linux. I almost forgot to check the jumper settings. Have you checked this? The jumper will need to be set @ slave (or master) depending on what you're doing. Good luck - hope this helps.
    The Terminator
    Core 2 Quad
    Gigabyte EP45-UD3P
    4X2GB GSkill 1066Mhz
    GeForce 9500 GT
    Realtek
    Samsung SyncMaster 932 bw 19" and Syncmaster 2033 20"
    1440 X 900 and 1600 X 900
    Patriot Torqx 128GB SSD WD Black 640GB
    Corsair 750HX
    Lian Li PC-B70
    Arctic Cooling Freezer Pro 7
    Microsoft wireless laser mouse 5000
    An old e-machines PS-2 (I have HUGE fingers and it works)
    7 Mps
i have tried every jumper setting but still no luck. thank you though
Does your drive show up in computer? If so try right clicking on it, click on properties, click on the tools tab, click on Check Now accept the UAC prompt make sure there is a tick in both boxes and click on start.
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
the thing im not getting is it is not showing up except for the disk manegment program
Yes my mistake, can you still right click on it
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
ya but it says i can go to help properties or initialize disk but it comes up with an error when i try to initialize it. i found out how to jump it as a slaveon the maxtor sight, i will try that and update. thank you
nope. didnt work. any other sugestions? remember, it was an xbox harddrive so im goingto see if i can find some software
as a rule a HDD is a HDD so it shouldnt make a difference
Try what I wrote before for computer, you said it allowed you right click and to select properties.
Is your other drive SATA or IDE?
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
One way to ensure the jumpers are correct is to enter Setup/bios. Depending on your machine, it's F2 or Esc or Del while booting. Usually a brief screen prompt tells you how.
Once in Setup, click the various tabs, there are only a few, to find the list of drives. If the jumpers and cables are correct, it should be there. If not listed, you will probably need to change something, motherboard port, jumper, cable, something.
    Asus G50Vt plus two XP shop machines used for trouble-shooting client problems
