Trouble using my 7.1 speakers
tangster03
I just bought my new Creative T7900 speakers which is 7.1. I have DP35DP Media series board with a built-in 7.1 sound card that has a driver from SigmaTel (default). The problem is I can't use my 7.1 speakers. The only speakers working are the two front speakers and the subwoofer when I play Windows Media Player 11 and Windows Media Classic Player, but when I ran a test on the config settings of SigmaTel, this time 5.1 speakers worked (excluding the side pair speakers). That I discovered, the audio cable that was included in the T7900 package is for 5.1 speakers only. One end of the cable has 3 pins and the other end has 4 pins which is standard for 7.1 speakers (Black for rear speakers; Lime-green for front speakers; Grey for side speakers; Orange for center speaker/subwoofer). But when I checked the quick installation manual, the cable included with the package is correct (3-pins : 4-pins). I only want simple thing to happen. I want my T7900 work on my PC that has built-in 7.1 sound card. Can someone help me about my audio problem. Thanks a lot.
    Intel Q6600 Core 2 Quad @ 2.4 Ghz
    Intel DP35DP Media Series
    SimpleTech 4GB DDR2 PC-6400 Dual Channel Mode
    XFX GeForce 8800GT Alpha Dog Edition
    Creative Sound Blaster X-Fi Xtreme Gamer Pro Fatal1ty Series
    Samsung SyncMaster 226BW 22-inch LCD
    1,680 by 1,050 pixels
    Western Digital 500GB 7200 RPM Western Digital 80GB 7200 RPM
    Apex Power Supply 500-watts
    Mercury
    Intel
    Genius
    Genius
    DSL 512 kbps
    -Creative T7900 7.1 Speaker System -Logitech Dual Action Gamepad
Help me please! :(
    Mercury
    Intel
    Genius
    Genius
    DSL 512 kbps
What is it you're playing? Sounds to me almost like you're just playing a stereo file. The source has to be encoded for 5.1 or 7.1 to actually play all channels, otherwise you'll just hear stereo.
i.e. if you're just playing a CD, or MP3 or AAC of a CD all you'll get are the front two speakers and sub.
You said the test allowed you to hear the surround speakers, that should mean all is well.
    Q9450 @3.4Ghz
    Asus P5Q Deluxe
    8GB Corsair Dominator @ 1066
    Asus AH4850
    Samsung 2235BW
    2x Seagate 750GB 1x Seagate 160GB (IDE)
    Cooler Master Real Power Pro 850
    Cooler Master Cosmos
    Cooler Master V8
    Logitech WAVE Cordless
Games, movies, and music. I already set-up my speaker to 7.1 yet I can't still hear all my speakers when I am playing mp3s, and the audio in my movies sucks. Can you help me?
    Mercury
    Intel
    Genius
    Genius
    DSL 512 kbps
That's kind of what I was getting at. If you're playing an MP3 from a stereo source, all you're going to hear are the front left and front right speakers, unless your speaker set (or audio software) has some sort of simulated surround. For instance, on my Logitech set I have a "matrix" button I can press and it turns stereo feeds into simulated surround.
As far as movies, are you hearing dialog through the center channel speaker? For a good surround test there are movies that are better than others. The Lion King is a particularly good surround movie, so is Contact, Saving Private Ryan, or any of the LOTR movies.
Click here , this will take you to a page where you can download a sample 5.1 file and play in windows media player. Try it and let me know what happens.
    Q9450 @3.4Ghz
    Asus P5Q Deluxe
    Asus AH4850
    Samsung 2235BW
    Cooler Master V8
