greatbird451
Hey, I logged on to my computer on Sunday, and all of a sudden I see about 100 user names from my original 1 user name... Well whats wrong with that, just log in as your account and delete it right? The really bad thing is, is that my user name is not there! Even with Vista's scroll bar, they put in a user limit on how many can be displayed. Well as you might have already guessed, not a single user has access to Administrator abilities. That means all my user access abilities have been blocked. The good news is that I looked through all my accounts have found that my user was still there (with all my documents as I have checked using Ubuntu Linux)! Oh yea, all the users are random numbers, which is why all these new accounts are at the top of the list...
Indeed I can always wipe the computer if worse does get the better of me, but why jump to conclusions when someone might have found the solution!
Things I have already tried: (I will use user 10246 as an example user to delete)
Please, any positive posts of any kind will be greatly appreciated!!!
- <ctrl>+<alt>+<del> twice [nothing happened]
- control panel [blocked]
- netplwiz [depending on which one, but either returned to previous settings or returned in a pop-up that is was blocked]
- command prompt: net user 10245 /delete [blocked, system error 5], net user 10245 /active:no [same]
- safe mode [still have to log in as one of them]
- fixing user registry [must be hidden because the path was not there] (If anyone has more detail on how to do this, I'm all ears)
- changing login UI [blocked]
- repair when pressing f8 at windows start up (which for me is at the boot options) [did nothing]
- net user administrator /active:yes [blocked, system error 5]
- banged my head against the desk after realizing the effectiveness of this extremely simple virus (not really, but you get the point)
