TightVNC problem
Ger0nim0
I just have installed on my computer TightVNC 1.3.9 on my Vista64 Ultimate. Install went fine but when im trying to connect to my computer from a remote one i receive the following message:
"This server does not have a valid password enabled.Until password is set, incoming connections cannot be accepted"
even if i set and re-set the password on the server the situation doesn't change and i receive the same message.
Any clues about what can i do?
Thank you
    INTEL X9650 3.0GHz
    ASUS Striker II NSE
    4GB DDR3 Corsair 1600
    ASUS 8800GTX 768Mb
    3x500Gb Raid5 Seagate Barracuda
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thank you for pointing me there....i should have looked there first.
Too bad there is no solution yet.
    INTEL X9650 3.0GHz
    ASUS Striker II NSE
    ASUS 8800GTX 768Mb
Here's an alternative solution that worked for me: seeing as there's a conflict with Vista/Win7 on port 5900, config VNC to use another port, eg 59xx. Don't forget to open this port in your firewall.
Hey presto, it works! At least it does on Win 7 beta.
