GratefulDean
Hi gang,
I've been having an issue where my task bar becomes invisible. I can roll over it and get the open program previews, and any info off the system tray but I can't see what it is I am rolling over. All there is is a line where the top of where the task bar should be. I auto hide the task bar by the way.
Last night I figured out the issue and thought I had it licked. It seems to happen when I disconnect the monitor from my notebook. I thought it was happening because I was leaving the monitor on when disconnecting it but that doesn't seem to be the case. Tonight, I turned the monitor off, waited a few seconds, unplugged it my notebook screen goes dark for a second then "abracadabra-shala-bazoom" the taskbar vanishes (sort of)
Any ideas?
Any ideas?
- HP Pavillion dv3510nr
- Processor Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz, 2
- 4G
- NVIDIA GeForce 9300M GS
- SynchMaster2300sw
- 1280x800x60hz
- WD MyBookHome 1T external
- Fast yo
