Hello,
I accidentally changed a part of a system variable for the CLASSPATH and Path
directory.
Can someone tell me what is supposed to be there?
You can get there by going to your control panel, then going to system, then
clicking on advanced system settings, then click on the advanced tab, and
finally click on the environment variables.
You should see CLASSPATH and Path in the top box, if not, scroll down under system
variables and you will in the variable side, CLASSPATH and Path, and if you could
tell me what the value is, it would be wonderful!
Thank you in advance!
Josh
directory.
Josh
