System unstable @ 1066
MOBY2800
I have just put myself a pc together and every time i put the memmory to 1066 the system becomes unstable keeps crashing locks up and will not let me input anything have to reset the pc works fine in 800 but when you pay more for the speed you what to use it.
im running: AMD 9950 runnig at 2.61
ASUS CROSSHAIR FORMULA 2 780A
8GB OF GELL BLACK DRAGON PC8500 5.5.5.15.t2 is what it says on the ram.
X2 IN SLI ASUS EN8800GT 1GB
    AMD 9950
    8BG GELL BLACK DRAGON PC8500
    2X ASUS EN8800GT 1GB
    SUPREME FX 2
    HP w2207H
    1680 BY 1050
    X3 MAXTOR 750GB SATA2 32MB CHA
    THERMALTAKE 1200W
    THERMALTAKE ARMOR LCS
    WATER
    MICROSOFT DESCKTOP 8000
    MICROSOFT DESKTOP 8000
    16MEG
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Id be interested in this. Ive tried setting the fsb to 1066 but it beeps and wont accept it. Its currently at default of 667.
Like Moby I used 5.5.5.15.t2.
See sig for specs.
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    Kingston PC3-10666 4Gb
    XFX 9800 GTX XXX
    Soundblaster X-Fi XtremeMusic
    2x Samsung SM-T220HD 22"
    1680x1050 on two monitors
    WD Raptor X/150Gb in RAID0 WD Raptor 36gb 3x Samsung F1 1Tb
    Thermaltake ToughPower 850w
    Thermaltake Armor
    Tuniq Tower 120
    Razer Diamondback 3G
    Dell Multimedia Enhanced USB
    Thermaltake Muse esata caddy
Not every mobo is equal. It is always good to do a bit of investigation before you buy something. Look at reviews, rants and raves. You will always get someone that has had a problem with a product but if the general concensus is the mobo is good or bad then you know wether to buy it or not.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
I'd try it with 4-4-4-12@800 and if that doesn't work go with 5-4-4-12@800, both at 2t, of course. Some mobos just have a rough time with 1066 in all 4 slots. Watch the voltage, too. Sometimes the mobos will set the voltage low. Usually 2.0 or 2.1 volts are required to hit 1066.
    Q9450 SLAWR
    XFX 780i
    8GB OCZ SLI 5-4-4-12@800
    XFX 8800 GTX 768MB (2)
    Auzen X-Fi Prelude / Logitech Z-5500 Digital 5.1
    Samsung Syncmaster 214T
    1600 x 1200
    300GB VelociRaptor / 750GB / 500GB / 750GB
    Antec 1000W TPQ
    Antec 900
    4 x 120mm, 1 x 200mm
    Logitech G7, Razer Lachesis
    Microsoft Entertainment Desktop 8000
    3Mb
Thanks for that. Would the fact I hav 4 sticks of 1gb make any difference?
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    XFX 9800 GTX XXX
    Thermaltake Armor
    Tuniq Tower 120
Ive managed to set it at 4-4-4-12-2t@800. Is the ram now running at full speed?
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    XFX 9800 GTX XXX
    Thermaltake Armor
    Tuniq Tower 120
Pretty much. DDR 800 is the top JEDEC DDR2 speed. 1066RAM just has chips that are rated to overclock. If you run your RAM at 800, it should be rock solid. Running at 1066 is an overclock (even if they're sold as 1066) and usually requires a boost in voltage to attain. With the boost in voltage comes an exponential increase in heat, causing instability unless you address the heat. That and some mobo voltage regulators may 'burn out' at that increased voltage. The 800 at 4-4-4-12-2t should be just as fast as 1066 at 5-5-5-15-2t.
And 4 sticks are always more taxing on the memory subsystem than 2 sticks. Adding 2 sticks will almost always lower the Vista WEI score for RAM, since that score is based on throughput and Vista has to access more RAM to test it. Average throughput will usually be lower the longer the test is run.
    Q9450 SLAWR
    XFX 780i
    1600 x 1200
    Antec 1000W TPQ
    Antec 900
    3Mb
Cool thanks for your help and reassurance.
    Self built
    Intel E8400 3GHz
    Intel DX48BT2
    XFX 9800 GTX XXX
    Thermaltake Armor
    Tuniq Tower 120
Anytime.
    Q9450 SLAWR
    XFX 780i
    1600 x 1200
    Antec 1000W TPQ
    Antec 900
    3Mb
