Solved system tray
How do I turn off the icons in the system tray at the bottom right of screen, the number lock, scroll lock and caps lock? When I click on them nothing happens and when I right click on them nothing happens. I have checked the windows start up program in vista, I cant find any thing that remotely comes close to those icons. Why are they there? What do they do? They where there the day my computer arrived and set up and turned on for the first time. Do they take up system resources? Thanks you guys, cool forum, better than annoyances.org.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
Hi bassfisher6522
R. click on a empty space on the Tascbar> Properties>
Notification Area> Customize> Click on whatever you want to hide.
I'm not sure how to "remove" entries, that's something I was going to persue when I had more time.
Hope this helps.
P.S. maybe someone will answer the "Remove" question!
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
What programs are listed in the Startup tab of MSCONFIG?
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Hi bassfisher,
Those system tray icons are specific to some program that your OEM has installed on your computer's Vista. These are not a part of Vista. You will need to check to see what program this is part of in the computer's documents that was included with your computer to turn it off.
To simply hide just these icons, you can select Hide in the tutorial below as Bare Foot Kid has suggested.
http://www.vistax64.com/tutorials/76913-notification-icons-customize.html
If you would just like to hide all of the system tray icons except for the clock, then see:
http://www.vistax64.com/tutorials/138395-notification-area-hide-all-system-icons.html
bassfisher6522,
I was wondering if you were able to resolve? I have a new HP PC with the same situation. So far I haven't been able to find anything in task mgr or services that seems related. I'd like to kill (rather than hide) the process if possible.
Thanks!
-Mike
Its called HP On-screen cap/num/scroll lock indicator which can be removed in the Program and Features.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Welcome
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Dude, you don't know how long I have looked for that and to find it right under my nose. Couldn't see it for looking, thanks
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
