You should upgrade or use an
alternative browser .
Solved System slow after using winrar
After using winrar to extract a large file (1gb+) my computer becomes really slow. The only way to fix it is to restart it which takes about 10 mins! I have noticed in task manager that the Physical Memory is up over 90% after extracting a large file. I never used to have this problem how can I fix it? Thanks.
AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ @3.0GHz
Asus A8M2N-LA
4 x 1GB PC2-6400 DDR2-800
Sapphire HD 4850 512MB GDDR3
Realtek High Definition ALC883
Maxtor 500GB Hard Drive SATAII
Arctic Power 500W PSU
Logitech USB Trackball
Logitech UltraFlat Black
8mb/sec
Hi ToonArmy,
It may be something that WinRar has caused. As a test uninstall it, then try the free
7-Zip program instead to see how it runs on your system.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Staff member
Hi Toonarmy,
looks like a memory leak with winrar, expanding file to memory and not releasing after use. you could try checking that you're using the latest version if not try something like 7-Zip and see if it happens with that. not a cure but may implicate or clear Winrar
also is the 10min reboot a normal occurrence or only in this situation?
Operating System
2 x 1920x1080 @50Hz
Asus M5A78L-M USB3
32GB [4x8GB] DDR3 1600 MHz
Samsung 32" TV
Internal
Crucial CT256MX100SSD1 256GB SSD,
Seagate ST2000DM001-1CH1 2TB,
External (USB3)
Seagate Backup+ Hub BK SCSI Disk 8TB
2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
NAS 4TB
68 MB Down 18.5 MB Up
Cheers guys I will try the newest version of winrar now and the 7-Zip if that doesn't work.
@barman58- the 10 minute reboot is only after using winrar the mouse is so slow and it takes 5 mins just to get the start menu up!
Asus A8M2N-LA
8mb/sec
Staff member
ok, toonarmy,
try the options as you've said, hopefully correcting the main problem will also correct the slow boot :D
Operating System
2 x 1920x1080 @50Hz
Asus M5A78L-M USB3
Samsung 32" TV
Internal
External (USB3)
NAS 4TB
Cheers guys just uninstalled winrar and installed the newest version. Extracted a 4gb file much quicker and system is stable still so all looks sorted! Thanks!
Asus A8M2N-LA
8mb/sec
Staff member
Hi toonarmy,
glad it's sorted, no problems with reboot?
Operating System
2 x 1920x1080 @50Hz
Asus M5A78L-M USB3
Samsung 32" TV
Internal
External (USB3)
NAS 4TB
No problems at all mate. It wasnt just reboot it was getting the mouse to move properly and clicking the start button that was taking so long! Even clicking on 'My Computer' or something would take a few mins to open after using winrar! All seems fine now anyway so thanks for the help.
Asus A8M2N-LA
8mb/sec
ToonArmy, I'm happy to hear that everything is sorted out now. Thank you for posting back your results.
Operating System
Operating System
