I wanted to give my views with regards getting rid of System Restore points when dealing with spy/malware/virus.
Through being around forums and newsgroups for a few years it's my belief that it's best to leave whatever System Restore points you have until you have got rid of any virus's you may have.
I know it's more than likely that the virus will end up in a Restore point but it is harmless while in there if you don't Restore to that point and if while you are dealing with the virus and going through steps to rid yourself of it you happen to screw up your machine at least you'll have a System Restore point to get you back into a working system, even if it has a virus, you can then try again.
When you have a clean machine then you go in and turn off System Restore to get rid of all checkpoints and then go straight back in and turn it back on and make a manual Restore point while there.
Maybe some of you will not agree but those are my feelings with regards the subject.
- Operating System
- Windows 10 Home
- HP Envy x360 Convertible 15-bq0xx
- AMD A9 Stoney Ridge Technology
- HP 8312 (Socket FP4)
- 8.00GB Dual-Channel Unknown (?-0-0-0)
- Generic PnP Monitor (1920x1080@60Hz) 512MB ATI AMD Radeon R5
- AMD High Definition Audio Device Realtek High Definition Aud
- Generic PnP Monitor on AMD Radeon R5 Graphics
- 1920 x 1080
- 119GB SanDisk SD8SN8U-128G-1006 (SSD) 931GB Hitachi HGST HTS721010A9E630 (SATA
- Microsoft Optical Wheel Mouse
- Standard PS/2 Keyboard
- 62.86Mbps down 18.19Mbps up
- Other Info
- EPSON78D0CF (XP-332 335 Series) (Default Printer)
