Solved System Restore
krd67
In the "task scheduler" the default setting is for "12:00am each day" and the second "trigger" is "upon comuter startup".These are in place and marked as "enabled" yet a "system restore point"is not automatically being created.The event log reads as follows:
Log Name: Microsoft-Windows-TaskScheduler/Operational
Source: Microsoft-Windows-TaskScheduler
Date: 3/19/2009 5:39:56 AM
Event ID: 114
Task Category: Missed task started
Level: Warning
Keywords:
User: SYSTEM
Computer: Ken-PC
Description:
Task Scheduler could not launch task "\Microsoft\Windows\SystemRestore\SR" as scheduled. Instance "{a1868f64-ed08-49a9-9f86-f62ed855affd}" is started now as required by the configuration option to start the task when available
    Acer 380
    AMD Athon 64 x 2 4000+
    2GB DDR2
    Realtek HD Audio
    TTX 17"
    800 x 600
    SCSI NTFS 320GB
    DSL
What you do is open system restore and click on "Open System Protection"
and when you look at System properties it will tell most recent restore point, date and time
Hope this helps
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
ACDC ...thanks for your prompt reply.When I checked it shows as "3/19/09 install:windows update" and the one prior to that is "3/16/09 again install:windows update".I have been able to come to one conclusion regarding the task\history\warning....that the failure to launch is referring to the default setting of 12:00am at which time my pc is always shutdown.However immediately following this history entry is the following:
Date: 3/20/2009 6:10:21 AM
Event ID: 118
Task Category: Task triggered by computer startup
Level: Information
Keywords:
User: SYSTEM
Computer: Ken-PC
Description:
Task Scheduler launched "{b21832ac-7c34-4e12-a89b-0cbe5b35a57f}" instance of task "\Microsoft\Windows\SystemRestore\SR" due to system startup.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-TaskScheduler" Guid="{de7b24ea-73c8-4a09-985d-5bdadcfa9017}" />
<EventID>118</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>118</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2009-03-20T11:10:21.072Z" />
<EventRecordID>292186</EventRecordID>
<Correlation ActivityID="{B21832AC-7C34-4E12-A89B-0CBE5B35A57F}" />
<Execution ProcessID="1152" ThreadID="1616" />
<Channel>Microsoft-Windows-TaskScheduler/Operational</Channel>
<Computer>Ken-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData Name="BootTrigger">
<Data Name="TaskName">\Microsoft\Windows\SystemRestore\SR</Data>
<Data Name="InstanceId">{B21832AC-7C34-4E12-A89B-0CBE5B35A57F}</Data>
</EventData>
</Event>
Hope this may shed a little more light on it for you.Just an added point I can do a "manual system restore point"
    Acer 380
    2GB DDR2
    Realtek HD Audio
    TTX 17"
    800 x 600
    SCSI NTFS 320GB
    DSL
I suggest you change the time to something more appropriate instead of 12:00AM...
Do you know how to do this?
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    5.1 surround sound
Thanks guys for the help and detailed instructions I will changing the "daily setting time".
    Acer 380
    2GB DDR2
    Realtek HD Audio
    TTX 17"
    800 x 600
    SCSI NTFS 320GB
    DSL
You're welcome Krd67.
