System Restore Task - Change Automatic Restore Point Schedule
How to Change the Automatic System Restore Point Settings in Vista Task Scheduler
By default System Restore is scheduled to create a restore point at 12 AM every day (Daily trigger) and at every system startup (At startup trigger) in Task Scheduler if any system changes were made from the last time it checked. This will show you how to change these schedule settings, or disable one or both triggers.
System Restore will need to be turned on for this scheduled task to be able to run.
1. Open the Start Menu.​
A) In the white line (Start Search) area, type taskschd.msc and press Enter.​
B) Go to step 3.​
OR
2. Open the Control Panel (Classic view).​
A) Click on the Administrative Tools Icon.​
B) Click on Task Scheduler.​
3. Click on Continue in the UAC Prompt.​
4. In the left pane click on the triangle next to Task Scheduler Library, Microsoft, and Windows to expand the folder tree. (See screenshot below step 5)​
5. Click on the SystemRestore folder.​
A) Choose a option or options below to do.​
OPTION ONE
To Disable or Enable this Task Completely
6. To Disable this Task Completely -
NOTE: This will disable both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers regardless of how they are set individually. You will not have anymore automatic restore points created with this task disabled. You can still manually create a restore point though. For how, see: How to Create a System Restore Point in Vista
A) In the middle pane, right click on the SR task and click on Disable. (See screenshot below step 5)​
B) Go to step 22.​
7. To Enable this Task Completely -
NOTE: Check to make sure that each Daily (step 12 in OPTION TWO) and At startup (step 17 in OPTION THREE) trigger is also set as Enabled.​
A) In the middle pane, right click on the SR task and click on Enable. (See screenshot below step 5)​
B) Continue to OPTION TWO.​
OPTION TWO
To Change Only the Daily Trigger Settings
NOTE: You will need to have the task enabled in step 7 to use this trigger. This is the trigger that creates a restore point at 12 AM every day by default. If you do not want to change these settings, then continue to OPTION THREE.​
8. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)​
9. Click on the Triggers tab. (See screenshot below step 10)​
10. Click on the Daily trigger to highlight it and click on the Edit button.​
NOTE: These are the default settings for the Daily trigger in the screenshot below.​
11. To Disable the Daily Trigger -
NOTE: This is if you only wanted to have restore points create with the At startup (OPTION THREE) trigger instead.​
A) Uncheck the Enabled box and click on OK. (See screenshot below step 12)​
B) Continue to OPTION THREE.​
12. To Enable the Daily Trigger -
A) Check the Enabled box. (See screenshot below)​
B) If the default settings for the Daily trigger schedule are not what you want, then make any changes that you would like.​
NOTE: For more details about each of these settings, see STEP FIVE here: How to Create a Task in Vista Task Scheduler
C) Click on OK.​
D) Continue to OPTION THREE.​
OPTION THREE
To Change Only the At startup Trigger Settings
NOTE: You will need to have the task enabled in step 7 to use this trigger. This is the trigger that creates a restore point at every system startup by default. If you do not want to change these settings, then continue to OPTION FOUR.​
13. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)​
14. Click on the Triggers tab. (See screenshot below step 15)​
15. Click on the At startup trigger to highlight it and click on the Edit button.​
NOTE: These are the default settings for the At startup trigger in the screenshot below.​
16. To Disable the At startup Trigger -
NOTE: This is if you only wanted to have restore points create with the Daily (OPTION TWO) trigger instead.​
A) Uncheck the Enabled box and click on OK. (See screenshot below step 17)​
17. To Enable the At startup Trigger -
B) To Speed Up Startup Time - Make sure that under Advanced Settings, the Delay task for box is checked and you have an amount of minutes set that you want for System Restore to run after startup.​
C) If the default advanced settings for the At startup trigger schedule are not what you want, then make any changes that you would like.​
D) Click on OK.​
E) Continue to OPTION FOUR.​
OPTION FOUR
To Change the Conditions for the Task
NOTE: You will need to have the task enabled in step 7 first. This will effect how both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers run. If you do not want to change these settings, then continue to OPTION FIVE.​
18. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)​
A) Click on the Conditions tab. (See screenshot below)​
NOTE: These are the default settings for the Conditions tab in the screenshot below.​
B) Make any changes you would like.​
NOTE: For more details about each of these settings, see STEP SEVEN here: How to Create a Task in Vista Task Scheduler
C) Continue to OPTION FIVE.​
OPTION FIVE
To Change the Settings for the Task
NOTE: You will need to have the task enabled in step 7 first. This will effect how both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers run. If you do not want to change these settings, then continue to OPTION SIX.​
19. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)​
A) Click on the Settings tab. (See screenshot below)​
NOTE: These are the default settings for the Settings tab in the screenshot below.​
NOTE: For more details about each of these settings, see STEP EIGHT here: How to Create a Task in Vista Task Scheduler
C) Continue to OPTION SIX.​
OPTION SIX
To See the Task History
NOTE: This will show you what the run and error history for this task is. This can be handy to help troubleshoot any problems with the task, or you just want to see when it ran. If you do not want to see the history, then go to step 21.​
20. In the middle pane, right click on the SR task and click Properties. (See screenshot below step 5)​
NOTE: You can also just click on the History tab in the bottom half of the middle pane instead.​
A) Click on the History tab. (See screenshot below)​
NOTE: In the bottom pane you can get more details about a selected history event listed in the top pane.​
B) Go to step 21.​
21. Click on OK. (See screenshots from below either steps 10, 15, 18B, or 19B)​
22. Close Task Scheduler.​
You're welcome Mike, and welcome to Vista Forums.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hi the.lost.one.,
It was suppose to be to check to make sure that the delay time is sufficient and enabled to help speed up startup time. I updated the tutorial to make this more clear.
Thank you for pointing this out to me.
You're welcome. Thank you for pointing this out and helping to make it more clear for others. :geek:
This was very useful. I hope that the error messages will slow down, now. I also get the MUI error even though I only need English. I used the same access to disable that option, too. Will any new issues be created by my disabling the MUI?
Thanks.
Randy
Hi Randy, and welcome to Vista Forums.
Since you only use one language, I do not believe you will have any problems with it disabled. Check your event viewer logs every so often. If you see any errors related to lpremove.exe, then just enable it again.
Description of the scheduled tasks in Windows Vista
Hello Shawn!
You directed me here from the System Restore Tutorial. I followed all steps in this tutorial but still can't figure out how to extend the time the restore points are saved from 1 day(current) to 4-5 days period. I'm not being very clear with my wordings. Sorry. What I mean is presently, SR only allow me to choose the restore points from today. What if I want to select yesterday's restore point? What must I do?
Thanks.
Hi Bennys,
In Option Two (step 12), you can change it to be something other than Daily (ex: Weekly), or change the recur every (how many days) instead.
I pretty much leave it alone but have changed the amount of drive space allowed for Windows to use for Restore Points.
Jim
    Custom - Built Myself
    E8400 Core 2 Duo @ 9 X 400
    ASUS P5E3 Deluxe WiFi X38
    4GB OCZ Platinum OCZ3P13332GK
    Gigabyte Radeon HD RX3850 775MHZ 512MB 1.4GHZ GDDR3
    On Board
    Dell SP2208WFP
    1680 X 1050
    1 X 640GB 7200 Western Digital
    2 X 500GB 7200 Seagate Barracuda
    All with cooling fans
    ENERMAX 1000W Galaxy DXX
    CoolerMaster CM690
    Zalman CNPS9700 NT / 4 X 120mm / 1 X 80mm Case Fans
    Microsoft Natural Ergonomic Comfort 4000
    Microsoft Comfort Optical 3000
    10mbps down / 1mbps up - Shaw Xtreme
    Lg GGC-H20L BLU-RAY HD-DVD Reader BD-ROM DVD+-RW 16X8X6 DL 4X
    Scythe Multi-Format Card Reader / Floppy Drive
You're welcome Bennys. I'm happy to hear that you got it sorted.
You're welcome Superneat. :)
Hello Oondric,
You have quite a few task folders missing there. Did you delete them?
Other than reinstalling Vista, you can see if doing a System Restore using a restore point dated when you thing they were still there. You might have to keep doing older restore points until you find one that they are there in afterwards.
lol.
thanks for the quick reply thar ;]
no. i didnt delete any folders. i reinstalled vista yesterday. i dont think system restore was installed with the vista i have. =\
no restore points have been made. even after before and after the installation of programs. i have tried to make restore points from the anitvirus program i'm using that automatically makes restore point before the clean up of the infected files/programs
an error comes up saying that the automatic system restore point option has been turned off. i have tried looking for the 'turn on automiatic system restore points' option but i cant find it.
heres a link to a thread that i have made.
Link:
Link to "A few missing .exe's"
thanks.
much appreciated for all your efforts ;]
I say that you may have a bad installation of Vista. You might consider formatting and doing a clean install of Vista to see if runs better this time. :(
