Is there anyway to start up the restore of a system that is on Drive D other than F11?
I was able to install Windows XP Pro and it runs fine.
However I feel the Bios is bad as when you power up those options for boot sequence and system restore appear but then the screen is frozen for time and then it brings the xp system.
I have downloaded an upgrade to the bios which is the same rel that came with the motherboard and wondering if I ran that exe from the running xp system if it might correct the bios? I need to have Vista installed and I can't get into setup to switch them as it appears that it is always going to the HDD first.
thank you.
Larry
thank you.
Larry
- Compaq SR5510F
- AMD Athlon 64X Dual
- MCP61PM-HM (irish8)
- 2 gig
- Nvidia GeForce 6150SE
- RealTech ALC888 audio
- Case
- Mid Size ATX
- Compaq
- Compaq
- none
- Other Info
- F11 will not function during boot.
