Solved System performance
hi all,
I have a gateway MD7818U notebook laptop that i bought for 600 about 2 months ago...i would like to know the best way to increase performance on this system...i am already using system mechanic and it is very fast running vista but i would like to squeezze the last bit of performance that i can out of this system
thanks
    Gateway
    Intel Core 2 Duo T6400
    4 Gigs
    Dell
    Q6600
    HP w2207h
If the SSD's are too expensive, you may want to try a 7200 rpm drive in your system. I switched to one on my Lenovo tablet and was favorably impressed with it's performance.
There's really only 3 things that you can do to a laptop to improve it's performance:
- add RAM
- get a faster hard drive
- tweak the heck out of the system (a lot of work, but very rewarding).
I'd check this site for suggestions on disabling services: Black Viper's Web Site
im not sure if my gateway MD7818U could take a sdd or my hp hdx it would be grate if someone could find this out for me
    Gateway
    4 Gigs
Hello William,
According to your laptop specs at Gateway, you currently have a 2.5" 500GB 5400RPM SATA hard drive. So yes, you will be able to use any SSD drive since they are all currently 2.5" and SATA. :)
