System crashed during install
johnjosiah
Was installing service pack 2 and system crashed now can not even get back to my old vista.
Seems to be loading and then I get:
!!oxc 0190005!! 9293/45274 (registry\machine\schema\wcm.//microsoft-...)
Then it freezes. I let it stay here for 18 hours and nothing. Tried to boot with my old vista windows disk and can not get a fix or get back to loading anything. Latest error said windows can not fix problem. Frequant black screen of death after bios or it goes to above point and stops.
Any help would be appreciated.
I think your system have trouble with unload Schema hive - it is only temporary hive and after restart system never use it.Download MEPIS http://www.vistax64.com/tutorials/172852-bypassing-log-passwords-access-folders-drive.html
burn,boot it and navigate to folder C:\Windows\System32\config ->in this folder find SCHEMA file and rename to SCHEMA.OLD ,next run system normally.
Should I rename that dir?
No!Otherwise you will never log to system.Show (or type) contents in this folder.Isn't any file like SCHEMA.DAT,SETUP?
This folder content registry files:
main registry files:
BCD-Template
Components
DEFAULT
SAM
SECURITY
SOFTWARE
SYSTEM
there are also protocols from using these files by system like SAM.LOG and likely...of course don't touch these files.Are there any files with completly different name?
follow the instruction specified in method three in this link. U Your problem will be solved.
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
