Hello there, I'm not sure if this is the right place to post this but I cant find anywhere else to put it. If it is in the wrong place please move it to the right section thanks
Anyway, ever since I had reformatted and installed Vista Ultimate x64 again. Everytime I boot into windows i get this error come up with the message
The process cannot access the file 'C:\windows\system32\Syst32.exe' because it is being used by another process.
Then when i click on "more details" I get this:
It's been bugging me for days and I'm not sure how to fix it
Anyone have any ideas as to why this is happening? Also I'm not sure what process is using it and whats trying to use it either and I really dont want to have to reformat my pc again but I will if I have to.
Thank you for reading
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.IOException: The process cannot access the file 'C:\windows\system32\Syst32.exe' because it is being used by another process.
at Microsoft.VisualBasic.FileSystem.FileCopy(String Source, String Destination)
at Syst32.syst32.Form1_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
Syst32
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Windows/System32/Syst32.exe
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.1434 (REDBITS.050727-1400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Anyone have any ideas as to why this is happening? Also I'm not sure what process is using it and whats trying to use it either and I really dont want to have to reformat my pc again but I will if I have to.Thank you for reading
- Intel Core2Quad Q9450 OC @ 3.5ghz
- Asus Maximus Formula II
- 4GB Corsair XMS2 DDR2
- XFX GeForce 8800GT Alpha Dog Edition
- Creative X-Fi Sound Blaster Fatal1ty Edition
- Asus VW202s 20" Widescreen
- 1680x1050
- Seagate 160gb (main) Western Digital Caviar 320gb Iomega External Storage 500gb
- PSU
- OCZ ModXTreme 720watts
- Case
- Antec 900
- Cooling
- Zalman CNPS9500
- Razer Deathadder + Drivers
- Saitek Eclipse II
- Virgin Media 2b T_T
- Other Info
- Mousepad: Razer Goliathus speed alpha :)
