Switching between x32 and x64 Java
manders
I need to access a server via Juniper Networks, but have been advised that the Secure Application Manager isn't compatible with 64-bit machines.
I have tried gaining access by using 32-bit IE8 from the same machine, but that did not work and am now looking at whether it is possible to actively select the 32-bit version of Java, as I have Java installed in both Program Files and Program Files (x86) suggesting that both versions are present.
Any ideas how I can force the use of Java x32?
