Stuck Screen Resolution
shakured
Im running windows vista 32bit with a 22" wide screen monitor, i have a Nvidia Geforce GTX 285 graphics card. I cant remember the exact resolution i was running, but when i booted up this morning my resolution has gone down to 1024x768 and i cant adjust it any higher then that! Ive tried uninstalling the driver and re installing but same ol same ol. Any suggestions?
Thanks
Can you open up the Nvidia control panel and see if you can adjust the display resolution there?
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
