Stuck in a loop after updates...
Luf
My setup:
Q6600 2.4GHz Quad
4GB G.Skill
8800GTX
EVGA 750i FTW
My Problem:
I believe I have a (Vista Ultimate x64 RC-1? Already has SP1) cd. I can install it fine. I can then install the correct drivers for my hardware. And all works well, until...
I use windows updates and select the 'important' only updates. After that, I'm stuck in a boot-loop. And by boot-loop, I mean I can't get into windows OR safe-mode. I have done this 2 times so far. It definitely only happens when I run the updates (can work perfectly fine for days w/o the updates). Any ideas? It's like I'm just now allowed to have an updated version of Vista.
I made a restore point prior to the updates, so I can get back to where I was, but I obviously can't run an outdated OS all the time. :P
thanks in advance.
One thing I've noticed, if I try to choose 'Last known good configuration', I get a blue screen with a USBPORT.SYS error.
So I just boot from the CD and restore back to a previous point.
That thought crossed my mind. But with 60+ updates, I wasn't really up for the task.
I took a look @ my system, and since I did a system restore after the updates....they aren't showing up as an option anymore. My update history just shows them as 'failed', but if I 'check for updates', they don't populate.
Let's say I completely reformat/reinstall. Should I try the windows updates right away? (before installing the Chipset & GPU drivers).
Can you verify your Vista version? You say RC-1 - and my understanding is that RC 1 support is over....and thus an update that is getting installed may be interfering with the RC 1 itself....
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I said RC-1 because I think that's what the download said. Sorry, can't remember. I downloaded the install from my TechNet subscription. I can check in a bit.
If I look @ my About Windows, it states...
Windows Vista Ultimate
Version 6.0 (Build 6000) (Debug)
That build has been causing more than one person problems. Download a *non* debug build.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Haha, oh jeez. So I'm just an idiot.
There were so many versions to download, it was overwhelming. It said something along the lines of "Checked & Debugged", sounded good to me. o.0
I'll give it a shot.
Thanks for the help.
You're not an idiot, it's just that they never bothered to clarify what that means....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
