start up programs
I have a lot of programs that run at start up. How do I find out what they are and if they are nessacary to run at start up? I already know how to disable programs from starting up, I just want to know which ones are not needed or essentinal at start up? Thanks for the help.
ps
Is there a program or place on the web that can tell me what is running and what they are and do?
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
ps
Welcome to the Vista x64 Forums :party:
There's an excellent guide for Vista that includes a list of startup programs and what can be disabled.
You can download the guide here: TweakGuides.com - The TweakGuides Tweaking Companion
We also have a great guide to making Vista faster in our tutorial section. You can find the link here: http://www.vistax64.com/tutorials/81176-speed-up-performance-vista.html
Let us know if that helps you at all.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main 500 GB USB External 160 GB USB External 2TB USB External
    DSL 3MB
You can go to the run panel (Start >> Programs >> Accessories, or windows key + R), and type in msconfig, you may have to allow it (just click continue). Then go to the fourth tab called startup.
And if they're necessary or not, I do not know :).
