Start menu problem
dassen_alex
Hello everyone!!
Recently I installed windows for the 21st time...(Yes it is 21)
It's all working out but i found a glitch.
When i changed the location of my pictures and music to an other location, all of them where working 100%.
But then i had to change the letter of the drive they were on.
Now when i click on them they don't do anything and if i right-click on it and go to properties it kind of freezes..
A properties window appears but it's almost all white.
Any suggestions on how i can reset this??
System restore doesn't work, nor changing the letter at the drive.
Thank you in advance.
Thank u for your time.
It's a really god tutorial but my problem is still here.
After doing the steps it feels more that the button is stuck than anything else.
So the button in the start menu from pictures and music doesn't respond...
You may need to restart again for the changes in the registry to be applied.
You can also try unchecking the button in the Start menu Customize area and click ok, then check them again and click ok to see if that will reset them.
Your welcome Dassen_Alex. I'm glad to hear it is running properly again.
