Spybot needs to be elevated to admin
Steveaa
Hello,
New here, and to Vista..........
Hp dv9580us laptop with lotso problems.
Right now I'll settle for a few progams working right.
Spybot needs to be elevated with admin rights to be fully functional?
Also Iobit defrag runs once the the program starts but the box is not up, its started but no visual box?
Thanks in advance,
Steve
For Spybot - go to C:\Program Filesx86, open Spybot Folder, right click SDMain.exe, click Properties , Compatibility, tick Run as administrator box, click Apply, then OK.
hope this helps
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Nope, tried that still getting the message:
You are missing administrator rights to peform this action.
If you need to do this, please run this application elevated as an administrator.
Now this is when trying to Immunize.
That did fix the Iobit Smartdefrag. thanks....
Glad it worked for the Iobit.
When you run Spybot, try right clicking it and run as administrator.
If that doesn't work, it may be that when you installed Spybot, you didn't right click and run as admin the setup file to start the installation. In that case, try uninstalling then reinstall using run as admin on the setup file.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Hi Steveaa,
Glad it helped
SIW2:D
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
