bassfisher6522
How do I change my fan speeds with the program speed fan? When I open it up and click configure, select fans and then it says select a fan to change speed. I do and nothing. I can't change anything. Need help with this program.
- Self built
- AMD Athlon 64x2 6000+ 3.0ghz
- Asus M4N78 Pro
- 3Gb PC2-5300 DDR2 @ 667mhz
- XFX Radeon HD 4770 512mb GDDR5
- VIA HD Audio
- Dual monitors: HP W1907 LCD 19" and Gateway HD Display 19" LCD
- 1440x900
- Barracuda 7200.10 SATA 3.0Gb/s 320 x 2-GB Hard Drive
- PSU
- Antec Earthwatts 80 plus 500 watts
- Case
- Ultra E-Torque ATX Mid tower clear side w/2 120mm fans
- Cooling
- Thermaltake MaxOrb cpu cooler w/120 mm blue led
- OEM HP
- OEM HP
- Download 6885 kb/s upload 367 kb/s
- Other Info
- Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
