SP2 Update Problem
Wingmaker
SP2 Update Problem (SP2 Already Installed???)
My SP2 installation have this error as below.
Now my laptop has this problem with SP3 indicated as below. Is the SP2 update fiasco due to this? How to solve the problem?? :mad:
Navigate to key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion
and check what you have in phrase CSDVersion ->it should be of course Service Pack 1 ->if you have 3 :D you have to correct it,restart system and repeat SP2 instalation
Navigate to key
Tried, didn't work. Already contact Microsoft through email for support on this.
I have similar problem and have also contacted Microsoft but the advice doesn't help at all:
"We believe that you have install a windows vista service pack 2 beta
version which have caused this issue. To be able to resolve this case,
please uninstall the Windows Vista Service Pack 2. For guided steps to
uninstall it, refer to the link below:
http://support.microsoft.com/kb/948537"
I never had SP2 beta installed.
Wingmaker, if you get more constructive advice please post it here.
Thanks in advance.
you know,
i have the beta sp2 thanks i will follow through
    homegrown
    intel core2 quad Q6600 2.4ghz
    gigabyte x38t-dq6
    4gb ddr3 Corsair TWIN3X2048-1333C9DHX
    nvidia geforce 8800gt 512mb
    Realtek ALC889A codec
    samsung 21.3 screen
    1024 by768
    500gb wd hd
    250gb wd hd
    Corsair CMPSU-750TX
    Arctic Cooling Freezer 7 Pro
    microsoft wireless keyboard 7000
    microsoft wireless mouse 7000
    cable 850
    pioneer dvd-rw dvr215d
    lite-on cd-rw sohr
    creative inspire pt7800 7.1
    plus 2.1 addtional speakers
    hp officejet j5750
